Desperate 17 Sep 2016 12:56 #742623
  • kaw-a-holic
  • kaw-a-holic's Avatar Topic Author
  • Thank you received: 248
:pinch: Long story short, the #1 Camshaft cap was snapped on the bike today. I know its not the right way to fix this but it will have to do for now. Does anyone have a cap off a bad head laying around? I have DGR next week end and this is the only fix. I don't have time or budget for a new head.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Desperate 17 Sep 2016 14:25 #742639
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
As long as the bolts are holding and it's just split between the two bearings, it should be OK. The smaller fours have separate caps. You could have it welded too.
The following user(s) said Thank You: kaw-a-holic
Desperate 17 Sep 2016 14:54 #742644
  • baldy110
  • baldy110's Avatar
  • Thank you received: 510
Like Steve said if it's just the bridge simply cut the bridge off both caps and bolt back on.
Desperate 17 Sep 2016 16:37 #742654
  • kaw-a-holic
Thanks guys, that makes me feel better.
Jon
1977 KZ1000a1
Mesa, AZ
Desperate 17 Sep 2016 17:29 #742657
  • SWest
  • SWest's Avatar
  • 10 22 2014
I wouldn't cut the "bridge". One locates the cam. It should be fine until you can have it welded. You can bolt two together with the locators in place and have the one welded. You have to grind the crack enough for the weld to fill all the way through and cool off.
Desperate 17 Sep 2016 18:16 #742662
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Careful with that one. It keeps the cam from traveling left and right in the bore.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Desperate 17 Sep 2016 18:24 #742665
  • bluezbike
  • bluezbike's Avatar
  • Thank you received: 104
I have a couple of spare cam caps.....let me know if you need them
You cannot miss DGR
79 KZ 1000 LTD
Desperate 17 Sep 2016 18:27 #742666
  • SWest
  • SWest's Avatar
  • 10 22 2014
They are line bored. No two are exactly the same. One can be too tight or loose. They could be made to work but that would take time.
Desperate 17 Sep 2016 19:53 #742676
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
Yes, they are line bored so each cap is unique however, there is a very good chance that a different random cap will work just fine.
Desperate 18 Sep 2016 06:02 #742701
  • LarryC
  • LarryC's Avatar
  • Thank you received: 309
swest wrote: I wouldn't cut the "bridge". One locates the cam. It should be fine until you can have it welded. You can bolt two together with the locators in place and have the one welded. You have to grind the crack enough for the weld to fill all the way through and cool off.
That is the correct answer to the situation. On two bolt caps like the 650 models, both bolt holes have a dowel pin. With a 4 bolt cap you only need two dowels in opposing corners because the bridge assures parallel alignment of the two bearings.
Larry C.
Desperate 18 Sep 2016 07:00 #742705
  • Old Man Rock
  • Old Man Rock's Avatar
  • Thank you received: 225
Jon.... I have a #1 cap off a 900/1000 head....
PM your phone # and address and I can drop it by this morning....
I'm in Glendale so will give me a chance to finally see this gorgeous build of yours.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Desperate 18 Sep 2016 07:06 #742707
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1973
Old Man Rock wrote: Jon.... I have a #1 cap off a 900/1000 head....
OMR
Now that is stepping up and helping !!!!!!!!!!!
OMR for BOTM :pinch:
Dave B) B) B)
