  • Page:
  • 1
Z 750 Twin Working uneven! I think! 11 Feb 2016 06:17 #710419
  • LuckyBike´s
  • LuckyBike´s's Avatar Topic Author
  • GravelRiders who love Road warriors RW
  • Thank you received: 0
Hello am new here on the forum and has a twin Z 750 LTD
Do not know where to start now, so maybe there is someone out there who has some ideas!
The engine is not working properly! Taking time at cold start to go clean, close to clean .... goes uneven at 3500-4500 revolutions and does not sound really good, I think. Is tricky under load.
Has made clean the entire fuel system, the carburetors and the tank
Replacing all fuel and vacuum hoses (also blocked the second vacum pipe when vacum valve to the crankcase vetelationen was broken)
Changed the plugs
I have the original exhaust system installed, there've been around a few years now, how important is the resistance of the exhaust gases of this engine.
Thank you for existing!
YouTube: 59fursten
webbgalleri.swedishline.com
Last edit: by LuckyBike´s.
Z 750 Twin Working uneven! I think! 11 Feb 2016 08:16 #710436
  • Rainman
  • Rainman's Avatar
  • and a little Kaw shall lead them
  • Thank you received: 75
Check for leaks between the head and carb holder and carb holder to carb body.
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
The following user(s) said Thank You: LuckyBike´s
Z 750 Twin Working uneven! I think! 11 Feb 2016 09:28 #710452
  • LuckyBike´s
Rainman wrote: Check for leaks between the head and carb holder and carb holder to carb body.
Jim
Thanks Jim!
You want me to check the carburetor rubber! (This part of the picture), if it is tight against both the cylinder head and the carburetor? And to look for cracks and damage them?
YouTube: 59fursten
Z 750 Twin Working uneven! I think! 11 Feb 2016 12:07 #710479
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2627
If old, replace them.
Z 750 Twin Working uneven! I think! 11 Feb 2016 12:45 #710484
  • Bowman
  • Bowman's Avatar
  • Thank you received: 36
You should be able to (carefully) pass a lit cigarette or something else that smokes in a place where there is no wind like inside a garage all around the joining parts and see if the cigarette smoke gets blown away or sucked in.
Honda 55 Trail don't ask me what year, 65? (sold)
79 Yamaha XS400 (sold)
76 KZ750B Twin (project)
72 Honda CT70 (project)
Z 750 Twin Working uneven! I think! 11 Feb 2016 12:53 #710485
  • Rainman
  • Rainman's Avatar
Yes.
Jim
Quincy,IL
Z 750 Twin Working uneven! I think! 11 Feb 2016 13:01 #710487
  • Bowman
  • Bowman's Avatar
Just don't forget to shut the bike down before you finish the cigarette. Smoking will kill you but carbon monoxide will kill you quicker.
Z 750 Twin Working uneven! I think! 11 Feb 2016 15:23 #710507
  • bountyhunter
  • bountyhunter's Avatar
  • Thank you received: 337
LuckyBike´s wrote: goes uneven at 3500-4500 revolutions and does not sound really good!
Some ideas:
1) run cleaner in the fuel system like Seafoam or Gumout or similar.
2) Check the timing advancer. They can cause all kinds of problems.
3) Is coil original? Old coils cause a lot of rough running problems too.
The following user(s) said Thank You: Bowman, LuckyBike´s
Z 750 Twin Working uneven! I think! 11 Feb 2016 16:14 #710516
  • Bowman
  • Bowman's Avatar
Some ideas:
What kind of coil would you recommend bountyhunter for these old twins? I'm thinking mine might be a bit tired after 40 years.
Z 750 Twin Working uneven! I think! 12 Feb 2016 13:50 #710606
  • bountyhunter
Bowman wrote:
Some ideas:
Any good coil with resistance of four to five Ohms will work fine.
I am running this one and it works great.
www.z1enterprises.com/product/EM24-72451
They are out of stock at Z1, but any similar coil should work.
Amazon has them.
www.amazon.com/Emgo-Ignition-Coil-Kawask..._product_top?ie=UTF8
Last edit: by bountyhunter.
Z 750 Twin Working uneven! I think! 16 Feb 2016 05:46 #710870
  • LuckyBike´s
Thanks for the help, you guys are the best !! Now she runs properly again!
Took off and made clean, has not changed the coil, to run a turn as soon as the ice is gone :)
[img size=1.9 ]iloapp.swedishline.com/data/_gallery/pub...dth=1920&height=1440[/img]
How!!?? Do I add pictures here?
YouTube: 59fursten
  • Page:
  • 1
