77 kz1000 engine build
03 Feb 2016 22:58 #709304 by jowek70
77 kz1000 engine build was created by jowek70
Decided to make a thread after lots of research on this site and several others
My dad has an old kz my brothers and I are gong to make into a great sleeperish street bike
I have access to a great engine builder and want to solidify a few things before dropping the engine off to him
We are running the wiseco 1075 piston kit, porting the head, bigger carbs (not sure which yet), web cams (rec grind #110) and possibly welding the crank.
Am I missing anything ?
This bike will never see the drag strip but will be mainly a stop light racer.
Feel free to share info and knowledge in any form
Look forward to working with you guys
Oh and we added a dynatek ignition already
04 Feb 2016 01:25 #709307 by PLUMMEN
Replied by PLUMMEN on topic 77 kz1000 engine build
Clean/check everything internally for wear,including the crank. ;)
04 Feb 2016 03:35 #709324 by Brady 154
Replied by Brady 154 on topic Re:77 kz1000 engine build
Degree the cams. Makes a big difference IMO.
1976 KZ900 LTD, resto-mod
-1075 Piston Kit
-PSP 3X Cams (degreed to 106)
-Mikuni RS34 Carbs
-Pod Air Filters
-Dyna S Coils and Ignition
-Race Tech Valve Cartridge Emulators up Front
-Ohlins Shocks out Back :)
  • SWest
  • 10 22 2014
04 Feb 2016 03:43 #709326 by SWest
04 Feb 2016 04:40 #709334 by jowek70
Replied by jowek70 on topic 77 kz1000 engine build
Good to know
Thanks
Only pics we've got so far
  • SWest
  • 10 22 2014
04 Feb 2016 04:49 #709336 by SWest
Replied by SWest on topic 77 kz1000 engine build
I like the Z1 styling. If you really want a sleeper, go with the 4/4 pipes then leave em in the weeds. :woohoo:
Steve.
  • Nessism
  • Away
04 Feb 2016 04:51 - 04 Feb 2016 04:52 #709337 by Nessism
Replied by Nessism on topic 77 kz1000 engine build
Heavy duty clutch hub rebuild. Check KZ Zone at APE.
Oh, and send the crank to Pearson or Gardner (spelling?).
Last edit: 04 Feb 2016 04:52 by Nessism.
04 Feb 2016 11:31 #709381 by DFIGPZ
Replied by DFIGPZ on topic 77 kz1000 engine build
cam Rollers
HD Clutch Basket.
Backcut Trans.
Weld Crank.
1984 750 Turbo
04 Feb 2016 12:23 #709389 by pete greek1
Replied by pete greek1 on topic 77 kz1000 engine build
I guess it all depends on how much you want to spend, I have a 1075, back cut trans, ported head, Mikuni RS 34's, Dyna ignition, wires & coils
& stock cam"s, V/H header, K& N pods, & it's plenty fast, & I have sprockets geared for the highway , if you do what your planning on doing so far, & just change your sprockets to 1/4 mile gearing you'll be surprised at how fast it'll be,
& if it's not fast enough , go for a Turbo kit, B)
Pete
05 Feb 2016 04:48 #709471 by jowek70
Great to hear
A more acceleration oriented gear ratio is what we were planning on doing
26 Feb 2016 12:28 #712603 by jowek70
Any recommendations for clutch plates?
  • 9er rider
  • Keep a cool tool
26 Feb 2016 18:50 #712662 by 9er rider
Replied by 9er rider on topic 77 kz1000 engine build
HD camchain HD valve springs
