  • Page:
  • 1
  • 2
leaky head gasket on gpz 1100 need advice 22 Nov 2015 14:24 #699988
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
I bought a Cometic graphite one piece for my ELR, unfitted as yet but I posted it here as a question and got a mixed bag of responses to went with my instincts, I guess we will soon find out.
leaky head gasket on gpz 1100 need advice 22 Nov 2015 15:27 #699997
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2632
Second one. No leaks.
leaky head gasket on gpz 1100 need advice 22 Nov 2015 17:48 #700037
  • car5car
  • car5car's Avatar
  • Banned
  • Thank you received: 20
z1kzonly wrote: Then there is the one peice Cometic versus two piece factory gasket debate...
Cometic! 4 layer stainless steel gasket for the Hemi 354! Melted down after 1st 1/8 mile pass, actually burnished the stainless steel into the cast iron Hemi block. Did not O-ring the block.
$180 for cometic gaskets
that was your fault, you were driving too fast! Next time drive slower! :)
96 Yamaha Royal Star
82 Yamaha Virago 920
leaky head gasket on gpz 1100 need advice 22 Nov 2015 17:54 #700041
  • SWest
  • SWest's Avatar
  • 10 22 2014
On the track? :huh:
leaky head gasket on gpz 1100 need advice 22 Nov 2015 17:59 #700045
  • Tyrell Corp
Yes, lucky you didn't get a speeding ticket. :cheer:
Seriously, Cometic seem to have a pretty good reptation, what did you use on the rebuild?
leaky head gasket on gpz 1100 need advice 26 Nov 2015 03:07 #700591
  • LarryC
  • LarryC's Avatar
  • Thank you received: 309
MattM wrote: Hi All,
I bought '81 gpz 1100 a few years ago and its been sitting, I've done a number bike projects in the mean time and now have dug this out to do a restomod. Its got mikuni carbs and really runs great, I had drained the float bowls and tank when I put it up and put fuel in it and it started up and runs great, so that's great. I steam cleaned the engine and then ran it and the cam cover gaskets leak as it looks like is somewhat expected, but also the head gasket leaks pretty good, oil is weeping down the engine and if you look close you can see tiny bubbles of oil coming from the head gasket. Is this common? Should I just replace the gasket, or is this an indicator of something bigger?
thanks, Matt
If you torque it and it still leaks, which I'm fairly certain it will, buy new gaskets and 0 rings and fix it properly. Get the head resurfaced while it's off and put valve seals in it. Would be foolish not to. As far as Cometic vs OEM, I'd go with Cometic. Just make sure you to torque the head again after the first full heat cycle and do it with the engine stone cold.
Oil leaking J motors were common issues when they were relatively new. 34 years of time passing hasn't magically cured them ;)
Larry C.
leaky head gasket on gpz 1100 need advice 26 Nov 2015 04:16 #700601
  • etbike3135
  • etbike3135's Avatar
  • Thank you received: 50
Ive bought lots of cheap J motor bikes because of the block o rings leaking. Theres no fixing them, replace only. I bought a GPZ for $150 that needed a oil pan underneath it when it ran, I could hear the guys wife laughing as I drove away with it on the trailer.
1973 Kawasaki Z1
18 years in dragbikes
  • Page:
  • 1
  • 2
