  • Page:
  • 1
  • 2
kz1000 manifold on kz650? 27 Sep 2015 13:11 #692176
  • pete greek1
  • pete greek1's Avatar
  • Thank you received: 185
blink543 wrote:
pete greek1 wrote:
blink543 wrote:
pete greek1 wrote:
blink543 wrote:
pete greek1 wrote: T:hose are carb holders, & if you have 26 mm carbs, many 1000s also had 26 mm carbs, but the spacing of the bolt holes are different, you can only use ones from a KZ 650 or a KZ 750, I believe
Pete
www.z1enterprises.com/ItemDetails.aspx?i...50&item=16065-1132X4
The ones in the link don't have the fitting for the vacuum hoses do I need that on the manifolds?
First of all QUIT calling them manifolds, you're making me laugh, :laugh: :laugh: ,Do your old ones have them? I don't think so, but I'll let one of the 650 guru's chime in
Pete
Ok? Well what are they then. And yeah the ones on my bike have them
If you read my previous thread, I told you they were CARB HOLDERS
Well when you type in kz650 manifold that's what comes up and what its listed as so don't tell me what to call them
& what cones up when you type in carb holders ? ....& don't worry, I wont tell you anything anymore, you seem to know it all, & with your cocky attitude I'm sure you'll get a lot of help, so good luck & ADIOS
Pete
Last edit: by pete greek1. Reason: adding more
kz1000 manifold on kz650? 27 Sep 2015 13:39 #692177
  • Thank you received: 2829
Pete,
For some reason he tends to ask questions and then argue quite rudely about the answers. I gave up on him too and he told me to stay off his posts, but I feel compelled to try to help him one last time. Of course you are correct in stating those are called "carb holders". You know it, I know it, Kawasaki knows it , and everyone on this forum knows it. Eventually, he may even believe it. B) Ed
Attachment 00003a-115.jpg not found
The following user(s) said Thank You: pete greek1
Last edit: by 650ed.
kz1000 manifold on kz650? 27 Sep 2015 13:57 #692178
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
650ed wrote: Pete,
For some reason asks questions and then argues quite rudely about the answers. I gave up on him too and he told me to stay off his posts, but I feel compelled to try to help him one last time. Of course you are correct in stating those are called "carb holders". You know it, I know it, Kawasaki knows it , and everyone on this forum knows it. Eventually, he may even believe it. B) Ed
I hear ya Ed...... you need to cool your attitude..... guys are just here to help ............... Kawasaki, Z-1 and 99% on here call em carb holders........ Ebay carb holders and Maniflods both but they don't count and I think they are wrong !! and ebay has a set with the nipples which you do need for sycronizing but you will have to buy all 4 with them coming out of the right side and flip the two on the left side ones up since the leftys are no longer made........ unless maybe after market.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
kz1000 manifold on kz650? 27 Sep 2015 14:19 #692182
  • RonKZ650
  • RonKZ650's Avatar
  • Thank you received: 237
My 650 in the avatar has KZ1000 carbs and intake manifolds on it. The KZ1000 bolt spacing is different, but only by a small percentage. The KZ1000 manifolds can be modified with a file or dremel to move the holes inward enough to fit them to a KZ650. I didn't do mine, but the original owner was a friend of mine and that's what he told me anyhow of how to fit the larger carbs.
kz1000 manifold on kz650? 27 Sep 2015 14:27 #692184
kz1000 manifold on kz650? 27 Sep 2015 15:57 #692207
  • KZB2 650
  • KZB2 650's Avatar
RonKZ650 wrote: My 650 in the avatar has KZ1000 carbs and intake manifolds on it. The KZ1000 bolt spacing is different, but only by a small percentage. The KZ1000 manifolds can be modified with a file or dremel to move the holes inward enough to fit them to a KZ650. I didn't do mine, but the original owner was a friend of mine and that's what he told me anyhow of how to fit the larger carbs.
This is whats needed to fit the 29m smooth bores.....900 manifolds (would need to look up the exact model) and then filing the holes with a round file to get the spacing right..... worked good for me and the ports match up (surprisingly) ........ but I think the carb opening would be too big for the stock 24mm carbs.
1978 KZ650 b-2
kz1000 manifold on kz650? 27 Sep 2015 17:39 #692225
  • blink543
  • blink543's Avatar Topic Author
Yeah I'll just send these back then. Maybe I can use liquid gasket to make them seal better because I think that's the problem.
Adam james
kz1000 manifold on kz650? 28 Sep 2015 05:09 #692273
  • KZB2 650
  • KZB2 650's Avatar
I've always read that liq gasket is a temporary fix and won't last....... I bit the bullet and bought a set for both my 24s and 29mm carbs.
1978 KZ650 b-2
  • Page:
  • 1
  • 2
