  • Page:
  • 1
.50 mm oversize rings for kz1000 J and kz1000 P ?? 29 Aug 2015 07:38 #687587
  • barney
  • barney's Avatar Topic Author
  • Thank you received: 36
So my dilemma is that I have what looks to be a .50 Oversize bored situation. Cylinder bores are straight and all measure 2.7515
Can't seem to find the .50mm oversize rings anywhere for the 81-83 Kz1000j motor. Looks like Kawasaki still offers the 2000 Police 1000 oversize rings with a slightly different part #.
My question is "They should be exactly the same dimensions right?" And I could use them right?
Barney
Last edit: by barney.
.50 mm oversize rings for kz1000 J 29 Aug 2015 07:56 #687591
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2631
Put the pistons in their respective bores and measure with a feeler gauge. max clearance is 0.003. If over that, new bore and pistons are called for.
.50 mm oversize rings for kz1000 J 29 Aug 2015 08:19 #687596
  • barney
At .0027 now that's not an issue.
My question is about Kawasaki availability of the year 2000 police 1000 oversize rings and the apparent non availability of the J motor oversize rings
.50 mm oversize rings for kz1000 J 29 Aug 2015 08:23 #687597
  • SWest
  • SWest's Avatar
  • 10 22 2014
What makes you think you need oversized rings if stock will do?
.50 mm oversize rings for kz1000 J 29 Aug 2015 08:53 #687603
  • barney
Steve The motor is at .5mm. over at this point with factory.50 OS Pistons. The previous owner must of had it done. I needed to take it all apart for a base gasket failure and want to replace the rings and a light honing of the bores
So a set of Kawasaki .50mm OS rings are what I'll need since putting old (although good) rings back in won't always seat properly.
.50 mm oversize rings for kz1000 J 29 Aug 2015 09:09 #687606
  • SWest
  • SWest's Avatar
  • 10 22 2014
I bought a used set of stock barrels and pistons. Low mile so I honed them with a good cross hatch. They seated better than I thought. I'm going to break it back down to put in my 10.25/1 pistons soon. Too bad, it's not smoking and burning oil anymore.
.50 mm oversize rings for kz1000 J 29 Aug 2015 09:29 #687607
  • TexasKZ
  • TexasKZ's Avatar
  • Online
  • Thank you received: 2076
I wonder if a local shop has a set you can measure? It may be nothing more than an updated part number.
.50 mm oversize rings for kz1000 J 29 Aug 2015 11:27 #687628
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
I had a similar issue like this happen once upon a time... I couldn't find a .5mm over size set of rings for a 750cc English twin bike... but I could find 1mm overbore everywhere.
So... after a few frustrating days we bought the 1mm overbore rings set from a local dealer, did a light, reseating hone on the cylinders, cleaned them spotless, then fitted the 1mm over bore rings into the .5mm over bore cylinders, gapped them all a little wider gap then the traditional stock +.004"-.006" per inch of bore and installed them on to the pistons.
I put the whole thing back together, had my buddy break in the engine over 500-600 miles using the "accepted method of the day".
It did not burn oil, had great compression and he sold the bike two years later with about +6,500 more miles on it then before the goofy re-ring job.
As far as I know it was never the worse for wear using the +.5mm (.020") over sized rings for the actual pistons.
I wouldn't tell you to do that.... this was just a comment.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: by missionkz.
.50 mm oversize rings for kz1000 J 30 Aug 2015 08:13 #687811
  • barney
Come on you Police bike owners. Any suggestions?
.50 mm oversize rings for kz1000 J 30 Aug 2015 09:20 #687820
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
Come on you Police bike owners. Any suggestions? Call 911 :laugh:
I think the later part number rings were revised to reduce ring tension - I had just this dimema with Nos zx1100 rings bought in error for an earlier GPz1100 17mm pin motor. In the end I went with an 1170 kit.
I have this problem again on a bored out 550 project, new rings navailable now.
Maybe try these : www.totalseal.com/ (not everything listed in their catalouge is still available - certainly for what I need anyway.
I was advised by their rep that using this 'Quickseat' lube and non synthetic 10/40 oil gives the best chance of sealing used rings.
Finding +1 mm Nos rings and filing the ring gaps might work but seems a bit dodgy to me.
.50 mm oversize rings for kz1000 J and kz1000 P ?? 04 Sep 2015 10:01 #688629
  • barney
So my problem is gone since I found probably the last set of Kawasaki .5mm. Oversize rings(4) . I got them at a place called Niagara Race Crafters in Canada(Nice guy named Larry). They have a "obsolete parts section"that is awesome but has been picked apart pretty well
The other big issue is to confirm the Police ring with conflicting part# will work on all KZ1000J motors
barney
The following user(s) said Thank You: missionkz
  • Page:
  • 1
