  • Page:
  • 1
Strange Hole in Crankcase 30 Jul 2015 18:59 #683526
  • aphex
  • aphex's Avatar Topic Author
  • Thank you received: 0
I've got a hole in my crankcase just where the left side cover mates with the block. It looks like it could be a factory cut but I can't figure out why the manufacturer would put a hole in this location, especially since it's a prime spot for collecting water. No dice when I look through the manual and forums.
Anybody know what this is?
Has a PO messed something up here? Please say no... :(
Tried to take a better closeup but the camera is acting up.
Attachment IMG_1.jpg not found
Attachment IMG_2.jpg not found
Attachment IMG_3.jpg not found
Attachment IMG_4.jpg not found
{Edit} Bike is a 1980 KZ1000 G1 Z1 Classic.
1980 KZ1000 G1 Classic
1982 Yamaha XZ550, decommissioned
Last edit: by aphex.
Re:Strange Hole in Crankcase 30 Jul 2015 19:40 #683530
  • StreetfighterKz
  • StreetfighterKz's Avatar
  • Thank you received: 117
Hard to tell but it could be put there to drain water as the part of the upper crankcase is like a basin of sorts. I haven't paid attention to that spot on my bikes in some time but can take a look tomorrow to compare.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Re:Strange Hole in Crankcase 30 Jul 2015 19:45 #683533
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
Doesn't look right to me, has a chain gone awol and knocked a chunk out of it? What is it like under the chain cover, epoxy or welding there will tell a story...
Re:Strange Hole in Crankcase 30 Jul 2015 20:00 #683537
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
My Z1 has it too. Just lower. It's a drain hole.
The following user(s) said Thank You: PLUMMEN
Re:Strange Hole in Crankcase 30 Jul 2015 20:00 #683538
  • StreetfighterKz
Looked at some cases for sale on eBay. Appears that hole is common on 73-80 900/1000's. I think it is for draining water or leaking fuel from the top of the cases.
I took these pics from two different auctions.
Later, Doug
1989 Vmax
Strange Hole in Crankcase 30 Jul 2015 20:13 #683544
  • JimB
  • JimB's Avatar
  • Thank you received: 9
I thought it looked strange also but I just looked at my 77KZ1k engine and there is a similar hole. Your inside hole looks misshaped but there is a drain hole in that area.
Attachment 77KZ1KHOLE.jpg not found
Attachment 77KZ1KHOLE1.jpg not found
Jim
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
Strange Hole in Crankcase 30 Jul 2015 21:53 #683558
  • Tyrell Corp
Interesting, I never knew that. Seems like an idea that got dropped in the later models.
Last edit: by Tyrell Corp.
Strange Hole in Crankcase 31 Jul 2015 06:29 #683581
  • aphex
Ok, good to hear! I was worried for a minute. Didn't notice the hole until I started cleaning up the air box and my heart sank.
So seeing how this appears to be a drain of some sort, any ideas where fluid could drain to from this point? I haven't found another drain hole in the side cover....trying to avoid pulling it off if it's not necessary. Water/fuel buildup in that side cover doesn't sound good, so it's gotta go somewhere, right?
Strange Hole in Crankcase 31 Jul 2015 06:33 #683583
  • SWest
  • SWest's Avatar
  • 10 22 2014
It's open on the bottom. Do you have a manual?
Strange Hole in Crankcase 31 Jul 2015 06:45 #683586
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
  • Visitor
Who knew? ..... my 80 MKII doesn't have the cut out or hole. Just goes to show, we haven't seen it all and new can be found.
Strange Hole in Crankcase 31 Jul 2015 15:07 #683640
  • SmokyOwl
  • SmokyOwl's Avatar
This is a pretty interesting thread I must say. I thought it might be an auto oiler for the chain at first but it's nowhere near that. Perhaps for ventilation cooling? Maybe it was for some super-rare accessory, or for an accessory that was never put into production.
1982 Kawasaki KZ1100 A2, Shaft
Never trade the thrill of living for the safety of existance.
  • Page:
  • 1
