acceleration hesitation 31 Jul 2015 18:02 #683666
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
blink543 wrote: thanks. if i wanted to soak my carbs what would u suggest? they say certain solutions eat at rubber o rings and stuff.....or should i just try to keep them together and clear up the junk inside by hand?
Berryman's Chem-Dip Professional Parts Cleaner (1 gal). It's a chlorinated product, and it will ruin plastic & rubber parts, so you have to take everything apart.
Last edit: by martin_csr.
acceleration hesitation 31 Jul 2015 18:40 #683667
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
  • Thank you received: 443
This may help, Patton's carb cleaning diagram.
www.kzrider.com/forum/3-carburetor/48928...pilot-circuit#489287
I had cleaned my carbs thoroughly and shot all the passages. But still wasn't running quite right. Used this diagram to spray the passages again then followed by air. Some kind of glob shot out. Never expected that considering how well I thought I had cleaned them previously.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
The following user(s) said Thank You: missionkz
acceleration hesitation 31 Jul 2015 18:56 #683669
  • blink543
  • blink543's Avatar Topic Author
  • Thank you received: 2
swest wrote: You're right they aren't CV carbs. My mistake. :blush:
Cv?
Adam james
acceleration hesitation 31 Jul 2015 19:57 #683675
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2642
Constant Velocity. They're more forgiving of elevation changes and stingy on gas. A bitch to tune with performance changes.
acceleration hesitation 31 Jul 2015 21:11 #683688
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
Come on Blink, sort it out mate. Don't you have the internet where you live?
2 sec google search on CV carbs... inquisitive questioning welcome, spoon-feeding those too lazy to even bother thinking, forget it.
The following user(s) said Thank You: 650ed, SWest
acceleration hesitation 31 Jul 2015 21:13 #683690
  • SWest
  • SWest's Avatar
  • 10 22 2014
B)
