chef79rick wrote: Thank you all for your input. The culprit was the 20 amp fuse, it was fried. Replaced it bike has power and all systems go! I looked for wiring issue cannot find one. Turned the handle bars fully left and right new fuse still good. When I get more time I will remove tank and headlight to check all wiring. Also the plastic black fuse box doesn't seem very user friendly, does anyone else agree with me or understand how to get into it? It is surrounded by 3 unfriendly steel clips, am I missing something as far as ease of getting into?
It sounds like a previous owner messed with it. To my knowledge it should be the same or very similar to the one on my KZ650-C1 (see image below). The fuse case just slips onto a tab on the bracket; no muss / no fuss, and it just snaps shut. It has no clips of any kind involved. Can you post a picture of yours? Ed
Attachment ElectricsRightSide-2.jpg not found
