  • Page:
  • 1
stock 1000j with header and jet kit 29 Mar 2015 18:57 #665690
  • harleeblue
  • harleeblue's Avatar Topic Author
  • Thank you received: 1
wont rev up off an idel with out choke half way on ? i got 40 pilot jets in now 138 manes second notch from the top clip on needels. floates set. delevac pipe with vance and hines open drage tip , no baffle in it . off idel it will just shut off if I toutch the gas. but I pull the chok half waye it will rev right up . quick too.. any ideas ... pointers
bradley frantz
Last edit: by harleeblue. Reason: typo
stock 1000j with header and jet kit 29 Mar 2015 19:02 #665692
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2635
What do your plugs look like. Pic?
stock 1000j with header and jet kit 29 Mar 2015 19:08 #665695
  • harleeblue
lean grey but trying to tune it on vp fuel 4.4
bradley frantz
stock 1000j with header and jet kit 29 Mar 2015 19:52 #665717
  • SWest
  • SWest's Avatar
  • 10 22 2014
What is it driving?
stock 1000j with header and jet kit 30 Mar 2015 03:23 #665746
  • harleeblue
Can't run it down the road its on a tractor frame with paddle tires on it.the dyno jet kit requires drilling out the air jet on the intake side of the carbs.im thinking there's a shaving I can't get out. Would this explain why I cant rev it up unless it's half choke? Also it's open pipe no baffel.
bradley frantz
stock 1000j with header and jet kit 30 Mar 2015 03:29 #665748
  • SWest
  • SWest's Avatar
  • 10 22 2014
With no baffle you lose top end.
stock 1000j with header and jet kit 30 Mar 2015 03:33 #665749
  • harleeblue
Ok but it won't rev off idel
bradley frantz
stock 1000j with header and jet kit 30 Mar 2015 16:11 #665827
  • harleeblue
I put a baffel in the pipe now it runs perfect thanks!!!
bradley frantz
  • Page:
  • 1
