  • Page:
  • 1
Engine rebuild question 20 Mar 2015 11:27 #665035
  • 83KZ750LTD
  • 83KZ750LTD's Avatar Topic Author
  • Thank you received: 1
During the process of removing the cylinder head on my bike, my cylinder block came loose from the base gasket. I currently have about a 1.5mm gap. What should be my next step? Remove the cylinder block entirely and replace the gasket? Or should I push the block back down and reinstall the head when ready?
The engine has 8k miles and I don't have new rings or a hone. Just thought I'd throw that out there for consideration...
1983 KZ750-F1 LTD - 8000 miles - 2/2015 - Head gasket time!
Engine rebuild question 20 Mar 2015 11:44 #665036
  • eisenherz
  • eisenherz's Avatar
i just redid mine, if you are able to see with a flashlight and its not damaged. but i would replace it,
1984 Kawasaki ZN750A1 (750 LTD)
The following user(s) said Thank You: PLUMMEN
Engine rebuild question 20 Mar 2015 12:25 #665041
  • bountyhunter
  • bountyhunter's Avatar
  • Thank you received: 337
Depends. Can you see the gasket surface? If the gasket is separating (breaking apart), should be replaced. If it came off clean and looks good, you might be able just to torque it all back down.
What I would do: if the cylinder head is free from the gasket (and the gasket looks OK) I would carefully lift the cylinder up a little bit being careful not to raise it high enough that the rings come out. Then I would apply a thin bead of sealer like yamabond or Ultra Black on top of the base gasket then set the cylinder down and use the head to apply a little pressure to seat everything. Let it cure.
YMMV.
Last edit: by bountyhunter.
Engine rebuild question 20 Mar 2015 12:57 #665044
  • 83KZ750LTD
I'm not sure if your suggestion is possible. Despite draining the oil, the gasket became completely saturated with oil when the block pulled away.
Engine rebuild question 20 Mar 2015 13:11 #665047
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
If it's not torn, I'd just bolt it back down.
Engine rebuild question 20 Mar 2015 15:45 #665062
  • bountyhunter
83KZ750LTD wrote: I'm not sure if your suggestion is possible. Despite draining the oil, the gasket became completely saturated with oil when the block pulled away.
Was there a leak there before? I just wonder how it became saturated with oil.
If not, it might seal by re torqueing.
Engine rebuild question 20 Mar 2015 17:25 #665071
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2677
No way I'd even consider reusing that gasket. The old gasket is guaranteed to be hard as a rock and brittle. VERY likely to leak in the near future. Regarding replacement gaskets, OEM Kawasaki gaskets are far superior to aftermarket. Particularly Athena brand gaskets which are pure junk (the green gaskets). Not worth the risk.
Last edit: by Nessism.
Engine rebuild question 20 Mar 2015 17:51 #665073
  • 80B4
  • 80B4's Avatar
  • Thank you received: 105
Replace the base gasket. I would find a new set of rings and have the cylinders honed so the rings seat quickly. Use genuine Kawasaki gaskets, o-rings and valve seals. It's always cheeper to do this work correctly.
1980B4 1000
1978 Z1R
1978 B3 750
  • Page:
  • 1
