  • Page:
  • 1
  • 2
Kerker Baffle-ectomy 14 Feb 2015 18:45 #661633
  • Glenn
  • Glenn's Avatar Topic Author
  • 1984 KZ1100R, 2015 Versys650 LT, 2008 KLR685
  • Thank you received: 13
I want to repack my Kerker K baffle for my ELR. I removed the megaphone and the bolt that retains the baffle in place. I then took a piece of wood and started to try and bang the baffle out. I finally took out my mallet and really pounded that sucker! Thankfully, no damage... but no movement either. I sprayed a bunch of Moovit, (penetrating oil), at the end of the baffle and I'm letting it soak overnight. My question is, does anybody know of any other tricks that might move that thing out?! :angry:
I would rather wake up in the middle of nowhere than in any city on earth.
Steve McQueen
Last edit: by Glenn.
Kerker Baffle-ectomy 14 Feb 2015 18:48 #661635
  • floivanus
  • floivanus's Avatar
  • Thank you received: 116
If it's not a chrome baffle, heat is a great idea, there's a good chance you have at least some rust or corrosion holding that sucker in. The aluminum endcap is great for being a corrosion magnet
Past; 78 kz1000, 83 kz550
Andrew
The following user(s) said Thank You: Glenn
Kerker Baffle-ectomy 14 Feb 2015 18:54 #661637
  • Glenn
floivanus wrote: If it's not a chrome baffle, heat is a great idea, there's a good chance you have at least some rust or corrosion holding that sucker in. The aluminum endcap is great for being a corrosion magnet
Thanks, I wondered about using heat. It is the painted black one so I don't mind hitting it with a benzene torch for a while. Wow, I wondered why they even bothered with the retaining bolt, this bugger is fused onto the megaphone! :ohmy:
Steve McQueen
Kerker Baffle-ectomy 14 Feb 2015 19:09 #661639
  • floivanus
Once you get it out, do yourself a favor wire wheel the outside of the cap and coat it in high temp grease or antisieze for the next time. Just go easy, soak, heat and tap (okay, not tap, but dont murder the thing either.)
Andrew
Kerker Baffle-ectomy 14 Feb 2015 19:24 #661644
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
That bolt isn't for keeping in in. It's a tapered fit. It's supposed to be tight. I'd heat the out side where it seats, then pop it out. I've had baffles fly out on the FWY. I disfigured the lip so I had to drive it back in. If it rattles, it's too loose.
If it's chrome, use dry ice on the baffle.
Kerker Baffle-ectomy 16 Feb 2015 14:42 #661798
  • Glenn
Thanks for all of the suggestions guys. I soaked the area where the baffle contacts the inside of the megaphone for 36 hours with Moovit penetrating oil. I took my benzene torch and heated the area where the baffle is against the megaphone. I beat the living snot out of that sucker and nothing! :angry: I'm nearing the threshold of damaging the pipe, so I'm going to try and find a professional somewhere that has the proper tools and experience with this type of problem.
Funny, but even after this frustrating fiasco, I still love that Kerker! B)
Steve McQueen
Kerker Baffle-ectomy 16 Feb 2015 14:56 #661800
  • SWest
  • SWest's Avatar
  • 10 22 2014
Are there any tack welds visible?
Kerker Baffle-ectomy 16 Feb 2015 15:25 #661804
  • spdygon
  • spdygon's Avatar
  • Thank you received: 117
Remove it from the middle and tap on the baffle end.
This will work if you have the original street baffle . The baffle is longer then the exhaust end
Did the same to mine when replacing the street baffle with the 2" race baffle
And the bolt is to hold the baffle in place so it won't blow out
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Last edit: by spdygon.
Kerker Baffle-ectomy 16 Feb 2015 16:22 #661811
  • Glenn
Definitely no tack welds anywhere. I replaced the stock baffle with a 1.5 inch baffle that is in there now. A couple years ago I had a 2" competition baffle installed, but that was way too loud and I had difficulty tuning the engine properly with it. At the start of last year I had the 1.5 inch put back in. The bike was in the shop for some repairs so I had them do it. With the megaphone off you can see the end of the baffle at the elbow of the bend of the megaphone. The baffle end is laying flush along the inside of the megaphone so it is difficult to get any bite at the end of it to force it out.
Steve McQueen
Re:Kerker Baffle-ectomy 16 Feb 2015 17:06 #661812
  • StreetfighterKz
  • StreetfighterKz's Avatar
What about using a slide-hammer at the outlet end?
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Re:Kerker Baffle-ectomy 16 Feb 2015 17:19 #661814
  • SWest
  • SWest's Avatar
  • 10 22 2014
You could wrap the outside with tape pretty thick and tap around the outside where the flange is with a hammer. Better yet a lead one. I use to have one but it disappeared. Maybe a block of wood or rubber mallet just to get it loose.
Kerker Baffle-ectomy 17 Feb 2015 04:03 #661843
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 377
Yep. Slide Hammer will do it. If you don't have one you can make one easily enough or go to your friendly neighborhood Auto Zone and rent it for $0.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Page:
  • 1
  • 2
