  • Page:
  • 1
Folding oil rings on install into sleeve 19 Dec 2014 19:24 #656476
  • chconger
  • chconger's Avatar Topic Author
  • Thank you received: 14
Hi All
I am getting close to sliding my block over my pistons in the next few days...first time at it.
Was planning to compress the rings in some plastic cut from oil containers/jugs that is bound by adjustable hose clamps.
I See "kaw-a-holic" had trouble with folding oil rings. So wondering if there are any tips on how to prevent / mitigate it?
Thanks
Chris
1977 KZ 1000-A
Folding oil rings on install into sleeve 19 Dec 2014 21:12 #656482
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2651
I've used beer can metal. There has to be a lot of clearance for the ring to fold over. Check them with a feeler gauge. It might be too much.
Folding oil rings on install into sleeve 19 Dec 2014 21:16 #656483
  • kaw-a-holic
  • kaw-a-holic's Avatar
  • Thank you received: 248
chconger wrote: Hi All
Thanks
Chris
My problem was that I used just the hose clamp itself, that was a bad idea in retrospect.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Last edit: by kaw-a-holic. Reason: spelling
Folding oil rings on install into sleeve 19 Dec 2014 21:38 #656484
  • SWest
  • SWest's Avatar
  • 10 22 2014
The beer can trick works of course with a hose clamp. Still a pain in the ass.
Folding oil rings on install into sleeve 20 Dec 2014 05:52 #656495
  • fordtruck
  • fordtruck's Avatar
  • Thank you received: 6
I used popsicle sticks to gently compress the rings to get them in the sleeves. It worked, but it helps to have another person to work on one piston while you do the other.
'77 KZ1000-MTC 1075 kit. Stage 1 port
Folding oil rings on install into sleeve 20 Dec 2014 06:06 #656497
  • KZB2 650
  • KZB2 650's Avatar
fordtruck wrote: I used popsicle sticks to gently compress the rings to get them in the sleeves. It worked, but it helps to have another person to work on one piston while you do the other.
This is what Jay from APE recommended to me and it worked like a charm. Gotta admit though I was worried sick till I was sure all were good.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Re:Folding oil rings on install into sleeve 22 Dec 2014 04:47 #656700
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
  • Thank you received: 75
They have the compressors come up on eBay from time to time. In the near future I'll be doing this to at least one of my bikes. Good to know about the Popsicle sticks.
79 LTD B3
Folding oil rings on install into sleeve 22 Dec 2014 11:22 #656720
  • MDZ1rider
  • MDZ1rider's Avatar
  • Thank you received: 118
Check my $6.00 DIY Ring Compressor post in the tools section
www.kzrider.com/forum/21-tools/596235-6-...-ring-compresser-set
  • Page:
  • 1
