  • Page:
  • 1
Engine rebuild 18 Dec 2014 16:19 #656379
  • bromz
  • bromz's Avatar Topic Author
  • 1981 kz1000 csr
  • Thank you received: 1
Ok guys i posted asking if I can rebuild my engine in the frame and everyone says yes. Question is is there a benefit for doing so? Will I save any more time? Would it just be easier for me to pull it where I can get at it?
Just the top end and head gaskets
Last edit: by bromz.
Re:Engine rebuild 18 Dec 2014 16:20 #656380
  • bromz
  • 1981 kz1000 csr
By the way 81 csr 1000
Re:Engine rebuild 18 Dec 2014 17:50 #656381
  • chconger
  • chconger's Avatar
  • Thank you received: 14
If all you intend to do is the top end, then there is nothing to be gained by pulling the engine out of the frame.
Pull the engine only if you need to split the crankcase open for some reason. (a very stupid reason in my case)
One step at a time...
1977 KZ 1000-A
Re:Engine rebuild 18 Dec 2014 19:40 #656389
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
Ditto.
Re:Engine rebuild 19 Dec 2014 03:40 #656398
  • bromz
  • 1981 kz1000 csr
Thanks guys that is what I was thinking just wanted to hear it!
Re:Engine rebuild 21 Dec 2014 16:50 #656652
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
  • Thank you received: 75
Split the cases when you want to do a serious build.
79 LTD B3
Re:Engine rebuild 21 Dec 2014 18:21 #656669
  • SWest
  • SWest's Avatar
  • 10 22 2014
That was a selling point in the day. The Honda's you had to pull the motor to fix a valve cover gasket.
  • Page:
  • 1
