I'm sorry my post have been a little vague, iv been trying to type with one contact in and in the process iv sped things up and not been clear.
The starter turns it over just fine, until the engine itself locks up. When I said moving the bike, I meant rocking it back in fourth, although I'm not sure what that does being its in neutral, but it seams to help.
I'm located in South Dakota. I bought the bike from a Harley guy who got the bike as payment for fixing a Harley for a guy. It was kept in a garage and he too knew of the issue, weather he looked into it or not is another story.
I took the points cover off and the cranks turns fine, but is there suppose to be a spark at the actual points? Also, the spark at the plugs is very weak looking and inconsistent. After messing around with it I noticed that it doesn't lock up anymore. I have a dyna 2000 I might put on to try and eliminate the spark issue, along with a set of 34mm flat slides so I know I have a good set of carbs.
Also, I checked compression with a drop or two of oil and 1-3 were from 100-150, and 4 was just about 200. Maybe I got more oil in 4 than the rest?
I know a lot of this is off topic, but my initial issue seams to be resolving itself, and I figured why make a new thread.
