  • Page:
  • 1
  • 2
Engine locking up when cranking 27 Jul 2014 12:13 #641614
  • rustedcutlery
  • rustedcutlery's Avatar Topic Author
  • Thank you received: 0
Well I got my dyna on and seams to be working good, engine starts now, need to clean the flatslides due to a sticking float, but for all indented purposes, the ignition is fine now.
But, the main issue is still present. Before, engine and or trans would lock up while cranking. Now since it runs, you can hear metal on metal contact of some sort. I'm assuming its the same thing that was causing it to lock up by cranking, but it doesn't lock up because of enough momentum of the engine. It appears to be from the cutch side of the bike. I don't want to run the bike anymore than I have to besides for diagnosing purposes. Anyone have any ideas? I like a little insight before I go ripping anything apart.
Thanks, rusted
Engine locking up when cranking 27 Jul 2014 12:28 #641617
  • pete greek1
  • pete greek1's Avatar
  • Thank you received: 185
can you post a video so we can hear what it sounds like, also you should check your oil/ oilpan for pieces of metal or shavings
Pete
Engine locking up when cranking 31 Jul 2014 11:32 #642167
  • fastidiots
  • fastidiots's Avatar
  • Thank you received: 4
Since your say you couldn't move the kicker, but got it to spin with the starter, and now you say the noise is coming from the clutch area which its right next to the kicker; I'm thinking you may have something broken on the kick start shaft. maybe someone else can make a suggestion as to what to look for.
82 KZ1000 J
76 KZ750 B1
Last edit: by fastidiots.
Engine locking up when cranking 31 Jul 2014 19:54 #642216
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2081
Could it be a really loose cam chain? Maybe broken or missing tensioner or idler sprocket?
  • Page:
  • 1
  • 2
