GPZ750/810 racer running....
  • turboguzzi
  • turboguzzi's Avatar Topic Author
Re: GPZ750/810 racer marching on
23 Jan 2011 09:07
#424669
a few hundred bucks saving in there ;)
  • turboguzzi
23 Jan 2011 09:10
#424670
i'll be using the complete ignition system of a 90's gsxr
as it has only one pickup no problems with the timing of the two pairs not matching
it'll be mounted to a honda sohc4 plate....
  • turboguzzi
23 Jan 2011 09:11
#424671
...because it simply bolts on to the kawi fixing posts :)
  • turboguzzi
23 Jan 2011 09:13
#424672
peek through the hole and you'll see the rotor and pickup coil...
  • turboguzzi
23 Jan 2011 09:16
#424675
and its going to be capped off by my DIY heavy duty, crash resistant cover.
made it originally for my sohc4 but turns out it works well also on the Kawi. RSC stands for Racing Service Corporation, Honda's sporting arm before it became HRC.
  • turboguzzi
23 Jan 2011 09:17
#424676
another angle
  • turboguzzi
23 Jan 2011 09:31
#424681
dutchz wrote:
Coming along nicely! Are you going to run it naked or with a fairing?
hei dutch, gonna run it naked,
Save for one circuit, we dont have too many tracks with long straights, so hope that up to 130-140 mph my head will stay put :)
  • thompsonmx100
  • thompsonmx100's Avatar
23 Jan 2011 10:48
#424714
Looking good Turbo. I really like the motor mounts. Should be a good handling bike.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
  • bwaller
  • bwaller's Avatar
23 Jan 2011 16:21
#424808
Hey TG,
I feel like a brother from another mother. I hope that RSC ignition cover doesn't melt off it's new home!
Regardless, your ride is coming together nicely. Still no news about the Ti retainers, do you want to forget them for now?
What are you hoping to produce on the dyno?
  • turboguzzi
23 Jan 2011 21:58
#424905
Hei Brent, welcome to the Klub ;)
will run stock retainers for the time being, being a DOHC dont think it's super critical, and a bigbore is not going to be a screamer either.
Seen some dyno's where people got round 90 hp from just the 810/ 10.25:1 piston kit, degreed stock GPZ cams and carbs, so who knows what happens with 12.5:1, some mild porting and hotter cams? ::)
to be honest, 90 will do for the first few races till i get used to it. This wil be just the start of development
  • PLUMMEN
  • PLUMMEN's Avatar
23 Jan 2011 22:26
#424911
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
24 Jan 2011 04:57
#424925
It's all about corner speed. Sure you can have power down the straights, but there will be bike that have 1/2 the rear wheel horsepower you have go right around you in the corners. Happens to me all the time.
I have seen from others, that with just the big bore kit, it will increase peak torque, but the compression, valve size, porting, carburetion, and exhaust outlet are the limiting factors in making more power. My race bike is top end limited for now, but from where I started, I've increased torque almost 10 ft. lbs. from a stock engine.
Good luck, and always remember to have fun first. It's a blast racing. :woohoo:
'85 GPz550(ZX550-A2)
