  • Page:
  • 1
  • 2
VIDEO 9 Country KZ/Z Camping Adventure VIDEO 20 Feb 2021 00:34 #843760
  • Ian T-J
  • Ian T-J's Avatar Topic Author
  • Thank you received: 17
Grab a beer
and take a look at this KZ/Z adventure :)
The following user(s) said Thank You: mopguy, Grcko, howardhb
VIDEO 9 Country KZ/Z Camping Adventure VIDEO 20 Feb 2021 05:22 #843763
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 437
Simply marvelous!
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
The following user(s) said Thank You: Ian T-J
VIDEO 9 Country KZ/Z Camping Adventure VIDEO 20 Feb 2021 05:29 #843765
  • ayeckley
  • ayeckley's Avatar
  • Thank you received: 29
Very nice. Did you wind up reworking the petcock?
1976 KZ900A4 (1105 Project)
1976 KZ900A4 (Stock Project)
1978 KZ1000A2 (Completed Project)
1983 ZX750 A1 aka GPz 750 (Completed Project)
1983 ZX750 A1 (Almost Road-Ready)
1973 CL350K4 (Completed Project)
VIDEO 9 Country KZ/Z Camping Adventure VIDEO 20 Feb 2021 06:20 #843769
  • Ian T-J
ayeckley wrote: Very nice. Did you wind up reworking the petcock?
The short answer is "No"
I kept getting asked this question on the YouTube video so I've written a detailed reply within the listing text.
"I've had so many questions asking if I fixed the high speed power loss issue.
During the trip provided I kept my speed below 65mph the bike was fine, so I tried to use smaller road and therefore slower speeds.
I was also scared if I tried to fix the issue I would waste half a day on the roadside, and perhaps make the issue worse.
Basically I could live with a slow top speed, its my riding style.
I still haven’t fixed the high speed power loss issue,
2020 and the Covid pandemic restrictions meant the Old Zed had very little use, simply short local low speed Sunday afternoon trips.
When Covid restrictions are lifted I’ll fix the issue"
VIDEO 9 Country KZ/Z Camping Adventure VIDEO 20 Feb 2021 06:47 #843770
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2071
Cool trip. Did you perform a valve clearance check before leaving?
Last edit: by TexasKZ.
VIDEO 9 Country KZ/Z Camping Adventure VIDEO 20 Feb 2021 08:03 #843775
  • mopguy
  • mopguy's Avatar
  • Thank you received: 168
Great video..
VIDEO 9 Country KZ/Z Camping Adventure VIDEO 20 Feb 2021 08:31 #843778
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
I'm surprised no one suggested you connect the vacuum line to one of your test ports. A piece of vacuum line would be an easy fix and answer the question. Cool video. B)
VIDEO 9 Country KZ/Z Camping Adventure VIDEO 20 Feb 2021 10:49 #843784
  • Ian T-J
TexasKZ wrote: Cool trip. Did you perform a valve clearance check before leaving?
Time to confess, this old Z650 runs on a cocktail of Love and Neglect :(
I've owned this bike for over 30 years and always serviced it myself.
I can only once remember adjusting the valve clearances, buckets and shims.
Although the top end isn't too noisy !
The engine is leaking oil like an old English motorcycle, one day I will have to take it out and give it a very big over hall.
VIDEO 9 Country KZ/Z Camping Adventure VIDEO 20 Feb 2021 10:55 #843785
  • Ian T-J
SWest wrote: I'm surprised no one suggested you connect the vacuum line to one of your test ports. A piece of vacuum line would be an easy fix and answer the question. Cool video. B)
Thanks Steven
Only 2 days ago on YouTube a Gerald Scott who uses this forum gave me the same advice :)
(Test Ports = Vacuum Gauge Ports)
He's the reason I've just restarted visiting this forum :)
VIDEO 9 Country KZ/Z Camping Adventure VIDEO 20 Feb 2021 10:58 #843786
  • Thank you received: 2829
Ian T-J wrote: .......................
Leaking oil? From where? I bought my 1977 KZ650 new in 1977 and with more than 62,000 miles it doe not leak a single drop of oil. Is the oil leak where the tachometer cable attaches to the engine? If so, that's very easy to fix. BTW, I owned a BSA for many years, so I know how an old English motorcycle can leak. :laugh: :laugh: :laugh: :laugh: Ed
Last edit: by 650ed.
VIDEO 9 Country KZ/Z Camping Adventure VIDEO 20 Feb 2021 11:17 #843787
  • Ian T-J
Leaking oil? From where? I bought my 1977 KZ650 new in 1977 and with more than 62,000 miles it doe not leak a single drop of oil. Is the oil leak where the tachometer cable attaches to the engine? Ed
Hi Ed
It's mainly leaking from the gasket between the barrels and head.
It's leaked for years and years.
I wear black jeans and boots and simply top up the oil !
I do recall replacing this gasket at one point and have torqued down the head several times subsequently.
VIDEO 9 Country KZ/Z Camping Adventure VIDEO 20 Feb 2021 11:24 #843788
  • SWest
  • SWest's Avatar
  • 10 22 2014
Thanks Steven
It's Steve. I changed it when I turned 18. They only used it when they were mad or wanted something from me. I got my family to stop calling me Steven but some still did when they wanted my attention. My reply was YEAH WHAT DO YOU WANT? That would shut them down. :lol:
If you open the petcock (I'm not suggesting it) you'll find a small hole where the fuel bypasses the valve to fill the bowls. When vacuum is applied the valve opens allowing full flow of fuel. Never liked them. If it were me I'd use two ports with a tee so the petcock gets a constant vacuum signal. Having just one seems to me would overwork the diaphragm at idle. I know they only use one port usually on the #3 carb just in front of the slide and my 33's have it not my 28's.
Give it a shot and let us now how it worked out for you.
Last edit: by SWest. Reason: sp
  • Page:
  • 1
  • 2
