Z1 Enterprises website
  • missionkz
  • missionkz's Avatar Topic Author
03 Dec 2015 19:24 - 04 Dec 2015 05:03
#701805
I guess they have changed it to some other name
Looks like the shopping cart isn't working though and they killed all my "waiting to buy" items in the shopping cart.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 04 Dec 2015 05:03 by KZQ.
  • floivanus
  • floivanus's Avatar
Re: Z1 Enterprises website
03 Dec 2015 19:25
#701806
Different companies as far as I know.
Z1E still pulls up for me
Past; 78 kz1000, 83 kz550
Andrew
  • missionkz
03 Dec 2015 19:55
#701808
Yeah, the old Z1 site is where my shopping cart was dumped..... :(
I'm still looking for a couple 2.20 and 2.25 29mm shims.
I had bought these 29mm shims off the old website earlier this summer and was waiting to pickup a couple other small parts before ordering more.... snooze ya loose.
Bruce
1977 KZ1000A1
  • Kapahulu
  • Kapahulu's Avatar
03 Dec 2015 19:59
#701810
Both are good companies. Z1 Enterprises has more parts, especially engine parts. Z1Parts is mostly bodywork, decals, clutch and brake levers.
Z1Parts is having a 15% off sale now. Use this code: "3 days only" it's good until 12/7/15.
2strokeworld.com
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Dec 2015 04:48
#701844
JetsRus has shims.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
04 Dec 2015 05:04
#701846
I understand there are some changes going on over at Z1 Enterprises but I assure you they are still a going concern.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • missionkz
04 Dec 2015 08:53
#701872
:( Yes I got the two confused. The two are not the same and I got an email from Z1Parts.... but went over to Z1 Ent, Inc and found my shopping cart had been emptied for some reason... I incorrectly assumed Z1 Ent had dumped the old site for a new one called Z! Parts... etc etc etc.... my bad.
Anyhow... still am not sure why my shopping cart on Z1 Enterprise, Inc was emptied and I need a few 29mm shims for the old KZ1000 to get them perfect.... but I really don't think they should be costing $9.00 to $12.00 each!! LOL
Bruce
1977 KZ1000A1
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
04 Dec 2015 09:14 - 04 Dec 2015 09:15
#701874
Call up a couple of Kawasaki dealers in you area. Ask to talk to the service department, not the parts counter. Ask them if they sell shims (usually with the exchange for your old shims). May charge you anywhere from $2.00 to $5.00 per shim. Or in my case, the guys just traded them free of charge. These dealers really don't use the 29mm anymore since the modern bikes use different size. So in my case, they just had them sitting around. An old school shop, unlike the dealer, will of course still have a need for them. One suggestion if you do go this route. Take a digital caliper with you to measure the diameter and thickness. Since I was given 29.5 Suzuki shims by mistake. Hart to see the size difference between the two. Also, the thickness is printed on the back of the shim is not always easily visible. The caliper helps.
Old Yamahas and BMW's also use the 29 mm shims. So can always try those dealers as well.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 04 Dec 2015 09:15 by KZJOE900.
  • floivanus
04 Dec 2015 09:31
#701875
Ford taurus SHO used the shims as well.
Seems z1e is just having site issues. They were outta town a few weeks, so things may have been askew when they came back
Andrew
  • zukdave
  • zukdave's Avatar
04 Dec 2015 15:55
#701955
I've read that the SHO shims come in smaller steps then the .5 the kaw. shims do
as in you need a 22.3 and so on.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Dec 2015 16:04
#701957
Kawasaki wants $20 a shim.
  • floivanus
04 Dec 2015 17:13
#701970
zukdave wrote: I've read that the SHO shims come in smaller steps then the .5 the kaw. shims do
The times I reshimmed an SHO, I just called up kawasaki... They got them faster Ford gave me the duhurrr treatment. BUT they showed more sizes that kaw doesn't.
Andrew
