Bike of the Month. 02 Apr 2023 04:49 #882295
  • Wheelhop
  • Wheelhop's Avatar
  • Thank you received: 294
Hell of a bike you got there!  Beautiful
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
Bike of the Month. 07 Apr 2023 02:38 #882593
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1821
If you guys want this feature to continue I need you to jump in and send me pictures and a back story. I am looking for any of the below
  1. Restored
  2. Modified
  3. Survivor
  4. Rare
  5. Interesting story
Send your entries to guy.schornig-moore@ hotmail.co.uk
I have May already (that's you Rob) but after that the "well is dry"
Bike of the Month. 07 Apr 2023 03:07 #882594
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 660
Guy, if your struggling and didn't get to find all the info I sent previously I will re do something and send it over but given I did the month before last I don't want to hog the thread!
Can do any of the footer pics or if you want to go off piste got several race Ducati's but as this is a khi forum probably not or it may open some floodgates.
Z1000J2 somewhat modified!
Last edit: by Warren3200gt.
Bike of the Month. 01 May 2023 01:15 #884036
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Back to the UK this month for Rob’s (Zed1015) Z900 powered “1 of 1” all business “tarmac terrorist”. This monster has nothing that isn’t strictly needed for the purpose of “hauling ass” including lights (it has a brake light only which is the minimum requirement for a “day time” MOT here in the UK)So from the top, heavily modified 750 Zephyr frame, ZX10R front end (with the fork internals reworked to add 32mm to the length), GSXR swing arm with a Z750 wheel, R1 callipers all round and a Suzuki rear shock. So with the chassis boxed off let’s move on to the motor which started as a Z900 which has been bored to 1015 (no surprise there) welded Z1000A crank, Z1000 MKII transmission, ported Z1 head, fast road cams, custom exhaust and 26mm carbs which Rob has bored to 29.5mm. The engine is solid mounted as it now also fills the role of being a “stressed member” in the minimalist frame. On the topic of minimalist the bike is “kick” start only as the starter and generator have been replaced with a “race” generator and 8ah battery in the tail piece (Rob did experiment with a “self generating” race ignition in place of the generator but unfortunately the “kick start” doesn’t spin the motor fast enough to allow it to start) which ended up being a very expensive piece of R&D !! the bike also runs a high level oil cooler in place of the headlight. Rob has also build a one off clutch actuator to mount on the “outrigger” in place of a sprocket cover.This bike is completely self built with some fantastic engineering work but for me some of the most impressive workmanship is the all alloy bodywork (only the best fabricators can work to a high enough standard to run their sheet-metal work raw)I would recommend taking a look at the full build thread on this link Zed 900 road racer - Updated with fixed links. - Z1OwnersClub GB
The following user(s) said Thank You: willemZ900, daveo, Street Fighter LTD, Warren3200gt, howardhb
Bike of the Month. 01 May 2023 01:55 #884037
  • Warren3200gt
Some special work there Rob. Very nice!
I would love to know pilot and main jet sizes and if the needle needed to be changed? Also if you need to run hotter plugs?
Bike of the Month. 01 May 2023 03:18 #884038
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1470
Thanks.
Carbs are Suzuki gs750 vm26 bored to 29.5mm.
I jetted them to stock GS1000s vm28 specs using a complete Keyster kit with needles etc,  increased the mains to 117.5 and fitted my air correctors and it ran perfect first time out.
It would probably have been fine with the original 26 mm internals but the donor carbs had parts missing .
Plugs are B9ES which i tend to run in all my motors.
Engine size is actually 1075cc ( Wiseco's) .
The following user(s) said Thank You: willemZ900, Street Fighter LTD, Warren3200gt, Wookie58
Last edit: by zed1015.
Bike of the Month. 01 May 2023 04:28 #884040
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Thanks.
Apologies Rob, I got the 1015 from the Z1OC build thread
Bike of the Month. 01 May 2023 05:29 #884045
  • zed1015
  • zed1015's Avatar
Thanks.
No problem.
When i first decided to build this it was supposed to be a budget build ( wishfull thinking ) and when i first put the motor together i did fit some Honda CB500T pistons i used to run in my Z1R that took it to 1015 but a freak cam sprocket flange failure on first start had me pulling the head to repair a valve and while i was in there chucked in a fresh 1075 Wiseco kit and some Norris cams i scored on Ebay .
It's in the thread but tucked away at the end somewhere so easily missed.
Bike of the Month. 01 May 2023 05:38 #884047
  • Street Fighter LTD
  • Street Fighter LTD's Avatar Topic Author
  • Moderator
  • Thank you received: 1973
Wonderfull build Zed.
Congratulations  on a well deserved  BOTM
Bike of the Month. 01 May 2023 13:12 #884081
  • MLMG
  • MLMG's Avatar
  • See you in the wind.
  • Thank you received: 35
I see the experience, time, and effort invested in that machine. Congratulations on the hard work!
1977 Kawasaki KZ1000 A1
Bike of the Month. 01 May 2023 16:16 #884093
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
Has a subtle "TERMINATOR" kind of feel about it, IMO
1982 KZ1100-A2
Bike of the Month. 01 May 2023 16:59 #884097
  • riturbo
  • riturbo's Avatar
  • Thank you received: 277
Wow .. nice job
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
