new to me 1978 KZ 1000 05 Apr 2023 11:55 #882543
  • Treetall
  • Treetall's Avatar Topic Author
  • Thank you received: 11
Hello Everyone.
I acquired a 1978 KZ1000 back around the end of Jan. From a friend who's owned it since 1988. It's been park since 2011. He was going to restore it when he retired. But due to health issues that's not going to happen. I've been lurking here since.
The motor was seized. I got it to break loose. I cleaned the carbs, and cleaned and lined the gas tank.
I wanted to see if i could get it running before I got too carried away!  This I was able to accomplish !! She only runs for a minute or so and dies. So I know I need to redo the carbs, the o-rings are hard and brittle and also a number of other parts need replacing.
My Question is where can I source a set of o-rings to rebuild the carbs. Some of them seem to be reg. metric o-rings. But others are an odd size, ie: Pilot screw o-ring.
The rest of the carbs are in good shape. As mentioned here, I don't need new jets etc.
BTW There's a lot of really good info and write ups on this site.
Thanks
Conrad
new to me 1978 KZ 1000 05 Apr 2023 12:26 #882545
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1973
Welcome to KZRider
Ed  who's  screen name here is Nessium  will be a great source of information and probably parts for your rebuild
We also thrive on bike pictures and projects so give posting pictures a shot
new to me 1978 KZ 1000 05 Apr 2023 12:29 #882546
  • Warren3200gt
  • Warren3200gt's Avatar
  • Thank you received: 660
Welcome, plenty of info and advice here from seasoned Z/KZ riders/spanner men.
Best source for sparts  will be dependent on which side of the Atlantic you reside.
Oh, and pics, we love pics.
Z1000J2 somewhat modified!
new to me 1978 KZ 1000 05 Apr 2023 12:54 #882548
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1865
Welcome. Sounds like your a capable person. Good for you to here in run. That’s a big accomplishment. You really need to post pictures so we can identify parts and get you correct information and goodies. After 40+ years assuming is not a good tactic.
new to me 1978 KZ 1000 06 Apr 2023 10:24 #882566
  • Treetall
Thanks for the replies guys.
I tried to PM Ed ( Nessium)for O-Rings.  But I guess I haven't been here long enough or need to post a few first. So that was " NO TOUCHY"!
I live on this side of the 49th in this frozen tundra.
I've had my share of KZ's back in the 80's. I had a 1980 kz750, an 81 or 82 CSR 1000, and an 82 or 83 1100 LTD.
Here's a couple of pics. should be alright for size!
Last edit: by Street Fighter LTD.
new to me 1978 KZ 1000 06 Apr 2023 12:04 #882568
  • Moderator
Nice project treetall
Next time click the insert all tab and your pictures will appear fullsize
 If Nessium doesnt see this soon we will get you through to him
new to me 1978 KZ 1000 06 Apr 2023 17:03 #882578
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2681
Please post your email address and I'll get in touch regarding O-rings.
new to me 1978 KZ 1000 06 Apr 2023 23:19 #882587
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1820
Treetall I have sent Nessism your email so you don't need to post it on the forum
The following user(s) said Thank You: Treetall
new to me 1978 KZ 1000 07 Apr 2023 11:00 #882612
  • Treetall
So first on the list was to get er unseized. Not sure which cylinder was stuck. But there was no spark plug in hole # 2, and hole # 3 had a seized spark plug.
After several different attempts with penetrating oils and heat etc. We managed to snap off the seized plug!  PERFECT !!  But that's for later.
So after I got the plug out, I applied a number of different suggested penetrants and heat to break er loose. In the process I read  somewhere, to turn over the motor I should put a wrench on the 17mm nut on the ignition side of the motor. I was somewhat leery, so I put a short wrench on it for less torque. It doesn't take much to break this bolt. Don't ask me how I know!
I also tried breaking the engine loose using the back wheel on the center stand. In the end I dragged the bike back and forth over a rough patch of cement in my shop and Eureka it broke loose!
By the way, Drilling out the broken bolt on the ignition side was a bitch!
Attachment not found
new to me 1978 KZ 1000 07 Apr 2023 11:55 #882613
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 309
Do you have left handed drill bits? Most of the time (but not always) the remains of the bolt will unscrew before you go all the way through.
We recently had to drill out a dozen stuck case cover screws on the 78' KL 250. With the left handed bits every one them unscrewed just before the head popped off. A few months ago we had to drill a case cover screw all the way out on the 80' Suzuki GS 1100E. It was in a spot that couldn't be repaired with a Helicoil. It took 1 1/2 hours to get it out with no thread damage.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
new to me 1978 KZ 1000 07 Apr 2023 16:13 #882630
  • Buzz Nichols
  • Buzz Nichols's Avatar
  • Thank you received: 105
Welcome! Pretty bike; looks like it's more or less all there. Getting it to run is certainly the right first step. Just my 2c, a good second step might be disposing of that fairing...
1978 KZ1000 LTD
new to me 1978 KZ 1000 07 Apr 2023 20:29 #882651
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2076
If you plan on a lot of highway speed riding or taking any trips on the bike, you might just fall in love with that old Vetter fairing. It is a heavy beast, but is very well suited to its purpose. In cold or rainy weather, it will make a bigger difference than you might imagine.
