And finally, Wookie's 82 begins ! 04 May 2024 10:55 #898457
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Away
  • Moderator
  • Thank you received: 1885
I wonder what other surprises await me
And finally, Wookie's 82 begins ! 04 May 2024 11:08 #898460
  • Cra-z1
  • Cra-z1's Avatar
  • Thank you received: 94
In general I like surprises but not that kind
And finally, Wookie's 82 begins ! 04 May 2024 11:21 #898461
  • Wookie58
  • Away
  • Moderator
I'm telling myself that the PO lost the correct bolts and the only ones he had where "too long"
And finally, Wookie's 82 begins ! 04 May 2024 15:29 #898476
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 262
At least they're still metric threads !
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
And finally, Wookie's 82 begins ! 04 May 2024 15:44 #898477
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1920
Now it´s time to make a Kawa bike/engine lift adapter for my ABBA bike lift!
And finally, Wookie's 82 begins ! 04 May 2024 16:16 #898483
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2643
The black bolts seem to be very brittle. Never had one snap like they did.
And finally, Wookie's 82 begins ! 04 May 2024 16:21 #898485
  • Wookie58
  • Away
  • Moderator
I am staying optimistic that is was a "bolt" issue
The following user(s) said Thank You: Injected, Rolf1976_KZ900
And finally, Wookie's 82 begins ! 04 May 2024 18:24 #898486
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2089
I am surprised those new bolts Dod not interfere with the cam cover
And finally, Wookie's 82 begins ! 04 May 2024 18:40 #898488
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 313
Nice job on the engine hoist. We usually just lay the motor on the right side and lower the empty frame over it. The only thing on the frame is the center stand so we can stand it up right away.
Like the others said at least they used metric bolts. On our 80' Suzuki GS 1100E the two center exhaust ports have each had both holes fixed using 5/16" SAE Helicoils. The two outer ports still have original metric threads. We converted it over to studs so now it has 4 - 8mm x 1.25 studs and 4 - 5/16" x 18tpi studs, what a pain.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
And finally, Wookie's 82 begins ! 05 May 2024 05:04 #898498
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
  • Thank you received: 127
Have you had the camcap off to check if it is helicoiled ? Was it on this engine you made studs for the caps?
And finally, Wookie's 82 begins ! 05 May 2024 07:43 #898508
  • Wookie58
  • Away
  • Moderator
Not yet Rolf, I just dropped the cover off for extra clearance when removing the motor. I will be using "stud and nut" to remove the caps as it's the kindest to the threads. The studs are simply a tool for diasasswmbly and reassembly as they would be too long to be a permanent fixture. The advantage of doing this is there is no pressure on the bolts until they are fully "in" so less risk of pulling threads. (I have used this method previously on other motors)
The following user(s) said Thank You: Rolf1976_KZ900
And finally, Wookie's 82 begins ! 05 May 2024 09:00 #898514
  • Rolf1976_KZ900
aha now i understand thanks for explaining.That was a smart way to do it.
