And finally, Wookie's 82 begins ! 07 Feb 2024 13:31 #894950
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Away
  • Moderator
  • Thank you received: 1897
Cool cowling  i am trying to find one like that .I saw another member here had one on his light blue kz650 ?  i wonder if the diameter on the light house fit a oem kz900 headlamp
This is the same cowl that rstnick is using on his 650, it is made to fit a 7" light so should fit fine (I am using the LED unit in the stock bowl and frame) best part is they are ABS plastic and CHEAP on evilbay
The following user(s) said Thank You: Rolf1976_KZ900
And finally, Wookie's 82 begins ! 07 Feb 2024 16:51 #894959
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
The 650s have a 7" headlight.
An Ebay fairing with yellow shield, painted to match the bike.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
The following user(s) said Thank You: howardhb, Wookie58, Rolf1976_KZ900
And finally, Wookie's 82 begins ! 08 Feb 2024 04:12 #894975
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
  • Away
  • Thank you received: 131
Yes there it was ! wery nice bike and color ! thanks
And finally, Wookie's 82 begins ! 08 Feb 2024 04:14 #894976
  • Rolf1976_KZ900
  • Away
Thanks for the link  and info wokie58 !
And finally, Wookie's 82 begins ! 10 Feb 2024 14:39 #895100
  • Wookie58
  • Away
  • Moderator
I've been pressing on with the nose cone today, got the top mount done now (welding needs cleaning up but none of the bracketry will be visible when the instruments are reinstalled   I didn't want and visible fixings on the outside of the cowl once fitted. It's getting real busy in there
Last edit: by Wookie58.
And finally, Wookie's 82 begins ! 11 Feb 2024 10:34 #895129
  • Wookie58
  • Away
  • Moderator
More work done on the nose cone today (there is light at the end of the "fab" tunnel finally) I have built an inner structure at the bottom which has added rigidity and given me somewhere for "captive" fixings which are discreet. I have also added some material to the side opening (only done one side so far) so that I could reshape the opening to replicate the line of the front edge of the fuel tank. It's very raw at the moment but hopefully these kind of details will help achieve the "could have always been that way" look that I am trying to achieve. These side pieces are a PITA as they curve in multiple directions, I found the best way was to get it somewhere near, bond it in then reheat it and clamp it to a steel rule which then achieved the required curvature along the edge. Will just need a light skim to level it off and should be good to go
The following user(s) said Thank You: Injected, ThatGPzGuy, howardhb, Rolf1976_KZ900, Quofan
And finally, Wookie's 82 begins ! 24 Feb 2024 13:47 #895571
  • Wookie58
  • Away
  • Moderator
I have managed to get the nose cone wrapped up today   (only needs final bodyworking for paint) I'm glad I went to the trouble of re-shaping the sides to match the tank as I think it really looks like it belongs there now. I have also added a flange around the openings which I think gives the appearance of a quality part and does a reasonable job of hiding it's "humble origins". A lot of work but can't complain at $50 including the materials to do the mods
The following user(s) said Thank You: Mcdroid, ThatGPzGuy, Nessism, Stereordinary, MLMG, Rolf1976_KZ900
And finally, Wookie's 82 begins ! 24 Feb 2024 15:27 #895575
  • RedPill
  • RedPill's Avatar
  • Thank you received: 10
Looks great. The curve matches the lines of the tank well, and the concave surface with the mini signals poking out looks really clean.
And finally, Wookie's 82 begins ! 26 Feb 2024 10:29 #895614
  • howardhb
  • howardhb's Avatar
  • God, I trust
  • Thank you received: 444
I like it!
What colour do you envisage?
H.
'81 GPz 550 D1 Click this link: www.kzrider.com/gallery/kz-550/1981-gpz550d1-9094#joomimg
'81 GPz 1100 B1 ELR "Tribute" www.kzrider.com/forum/11-projects/617040-1981-gpz1100-b1-rst
'82 Yamaha YB100 Fizzie
And finally, Wookie's 82 begins ! 26 Feb 2024 10:41 #895615
  • Wookie58
  • Away
  • Moderator
I like it!
H.
Thanks Howard, regards colour I have multiple ideas raging in my head. Now the bodywork is pretty much wrapped up I will try drawing out a few ideas (might post it for a second, third, fourth etc opinion)
And finally, Wookie's 82 begins ! 26 Feb 2024 12:39 #895624
  • howardhb
  • howardhb's Avatar
  • God, I trust
You going to do a "Chip Foose" drawing
I use a free PC paint program called "PaintDotNet" to "visualise"...
www.getpaint.net/
And finally, Wookie's 82 begins ! 27 Feb 2024 00:10 #895648
  • Wookie58
  • Away
  • Moderator
www.getpaint.net/
Thanks Howard, my drawing is more "Big Bird" than "Foose" so I will give the link a try
