1978 KZ1000-A2 "Barn find" 09 Apr 2022 05:54 #865153
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
  • Thank you received: 518
before my new Z900RS SE shows up...
Seems like you buried the lede there a bit. Of the 4 (!) versions of the 900RS they are selling this year I think the SE is the coolest. How did you find one? Did you have to special order it? I looked around a bit and didn't see any listed at dealers.
My dad's '74 Z1
'00 ZRX1100
1978 KZ1000-A2 "Barn find" 09 Apr 2022 07:53 #865160
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
I think we had a wolf in sheep’s clothing here. Look at this guy go. Great work on the 1000. Looking good. I have stalled out on my 76 project looking for a crankshaft. 3 on the bench so far and not one good on. Taking one last chance on used. Another member Wheelhop and I bought some parts in Florida. Wheelhop is driving down the end of this month to pick them up. Fingers crossed.
1978 KZ1000-A2 "Barn find" 09 Apr 2022 09:41 #865164
  • Kaylinator
  • Kaylinator's Avatar Topic Author
  • Thank you received: 74
 I put a deposit down on an SE from Blackfoot in Calgary, but Kawasaki is several months behind. Their January allocation showed up in March. I put a deposit down on their Feb allocation. Still waiting...
I have seen about 3 SEs at various dealers across Canada - Edmonton, Winnipeg, Montreal.
I actually almost prefer the paint on the blue model that's out this year, but to upgrade the shock, front brake caliper, brake lines, etc, it wasn't even close to worth it.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
1978 KZ1000-A2 "Barn find" 09 Apr 2022 15:54 #865182
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1042
Mikaw, Do you want me to check with my friend in Chilliwack?
Last edit: by hardrockminer.
1978 KZ1000-A2 "Barn find" 09 Apr 2022 16:34 #865185
  • Kaylinator
Can you give me some more details one how your cranks were bad. I had to get a different for reasons I don't really want to get into (stupidity) and now I'm concerned...
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
1978 KZ1000-A2 "Barn find" 09 Apr 2022 16:50 #865188
  • Mikaw
  • Mikaw's Avatar
HRM, thanks, the crankshaft I bought in Florida is from a very respected Kz guy. Hopes are high this will be the one. If not I might take you up on your offer. Thanks a bunch.
1978 KZ1000-A2 "Barn find" 09 Apr 2022 17:04 #865191
  • Mikaw
  • Mikaw's Avatar
Kay, two of the cranks have bad rod small ends. Galled up and out of spec. The third has notchy bearings. According to Pearson racing it’s commen for a crankshaft that has sat a while. The roller bearings have no inner race, the bearings ride on a machined surface of the crank. The rollers will rust and they will need to be disassembled to properly inspected to determine if the crank surface is good.
Good rod small end
Bad
The following user(s) said Thank You: BCScott
