KZombie 09 May 2016 23:20 #725467
  • wrenchmonkey
  • wrenchmonkey's Avatar Topic Author
  • Thank you received: 75
Oh. I almost forgot. Brett, you asked about the paint and if they have high temp versions?
I looked and only see they carry POR products for high temp (ie: not in the Spray Max cans). However, you can look for yourself to see if anything looks of interest here:
www.66autocolor.com/default.asp
The web site is pretty easy to navigate and they shipped fast.
KZombie 10 May 2016 05:24 #725490
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
The only one you'll have trouble with is the one behind the points cover. You have to split the cases to get to that one. You can tale out the bolts and pry the case open just enough to slide it out. The rest go in from the inside of the covers. I'd take out the clutch plates, wash them in diesel, then put them back in.
The following user(s) said Thank You: wrenchmonkey
Last edit: by SWest.
KZombie 10 May 2016 07:36 #725509
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
Would be a good idea to replace the springs for the clutch while you have it apart..... a lot prefer NOS ..... I like Barnett's ..... I need to read the manual more Steve.... I didn't split the case when I did my motor and figured the majority of the seals couldn't be replaced unless you did..... since the motor is on my bench for a bit yet I'm gonna look into it.... hopefully I can live without replacing the one behind the points cover for now............... am interested on seeing how many cans of blue you use for the panels and tank too Wrench when you get to that point.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
KZombie 10 May 2016 07:40 #725511
  • SWest
  • SWest's Avatar
  • 10 22 2014
Being it's on the bench, it would be a good idea. On the large fours the housing comes off. I just replaced mine after 40 years. :lol:
KZombie 10 May 2016 07:51 #725513
  • wrenchmonkey
Good point. I meant to tell how many cans i've been using as a reference. I used 1.5 cans of primer on the frame with full coverage.
I expect to finish the 2nd can of primer on the few frame elements i have left to do.
Also, as i will be painting tank, sides, rear ducktail, front fender, headlamp bucket & dial bodies, i expect 2 cans of blue & 2 cans of clear based on my son's results on his HD 883 job.
KZombie 10 May 2016 08:28 #725525
  • Irish-Kawi
  • Irish-Kawi's Avatar
  • Thank you received: 37
wrenchmonkey wrote: Oh. I almost forgot. Brett, you asked about the paint and if they have high temp versions?
Killer Wrench thanks so much for the help!!!
Thanks,
Brett
All the gear all the time!
1985 Kawasaki GPz 750 (ZX750-A3) 15,000 original miles www.kzrider.com/forum/11-projects/601230...z750-refresh-project
Father - Husband - Bourbonr - Rider
KZombie 10 May 2016 14:09 #725569
  • OnkelB
  • OnkelB's Avatar
  • Thank you received: 80
wrenchmonkey wrote: .... And the big question is which seal goes where?
Here's my seals:
Off the top of my head (and I could be wrong, it has happened :whistle: ) :
1: Output shaft seal, sitting in the mission cover.
2 and 3: Crankshaft end seals. If so, they should have a ridge around the outside that fits into a groove in the crankcase halves.
Unlike the rest you need to split the cases to replace these (and also remove the flywheel/rotor from the crank to replace the left one). They are not the same, so take note of which goes where.
4: Kickstart shaft seal, sitting in the clutch cover.
5, 6 and 7: Gearshift lever shaft, one seal in the mission cover and two in the sprocket cover, one on the outside facing out and one on the inside facing in. (Edited per Steve's post below).
8: Clutch pushrod seal, sitting in the mission cover.
9: Tach drive seal
As mentioned, I could be wrong but at least it should give you somewhere to start.
77 KZ 650 B1, 82 GPz 1100 B2.
The following user(s) said Thank You: KZB2 650, wrenchmonkey
Last edit: by OnkelB.
KZombie 10 May 2016 14:19 #725571
  • SWest
  • SWest's Avatar
  • 10 22 2014
There are two in the sprocket cover. One on the outside facing out and one on the inside facing in. The other goes to the tranny cover over the shift linkage. Three in all.
The following user(s) said Thank You: OnkelB, KZB2 650
KZombie 10 May 2016 14:33 #725576
  • OnkelB
  • OnkelB's Avatar
You're right Steve, there are indeed two seals in the sprocket cover as you say, never noticed the inside one.
That accounts for the third seal, I edited my post above accordingly, thanks.
KZombie 10 May 2016 14:47 #725578
  • SWest
  • SWest's Avatar
  • 10 22 2014
They are there more for support than sealing.
KZombie 10 May 2016 14:50 #725579
  • OnkelB
  • OnkelB's Avatar
Yeah, guess the two in the sprocket cover should be called bushings rather than seals.
KZombie 10 May 2016 14:56 #725582
  • SWest
  • SWest's Avatar
  • 10 22 2014
Mine were worn out for years. Finally replaced them. Now I have a different cover. Lucky they are in good shape. Have to destroy them to get them out. :dry:
