85 GPz750 Refresh Project 10 Jun 2016 20:47 #730896
  • riturbo
  • riturbo's Avatar
  • Away
  • Thank you received: 277
swest wrote: Are those badges on the calipers available?
Theres a guy on the turbo site that sells them . He has two different styled for different years they come in silver and black . Bought a set off him the quality is excellent . Just like siock . Forget how much they were . I can find out if you want . They weren't that much . They are made out of aluminum I think . He also sells the sticker kits for the forks and all the safety stickers .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Last edit: by riturbo.
85 GPz750 Refresh Project 10 Jun 2016 20:50 #730898
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2633
If you can find a link that would be cool. B)
85 GPz750 Refresh Project 10 Jun 2016 20:57 #730899
  • rinferno
  • rinferno's Avatar
  • Thank you received: 3
No eBay APP ID and/or Cert ID defined in Kunena configurationCheck Ebay, UK dealer, sells them.
1982 gpz 750
85 GPz750 Refresh Project 10 Jun 2016 21:56 #730902
  • riturbo
  • riturbo's Avatar
  • Away
Heres the link www.750turbo.com/forum/viewtopic.php?f=4...liper+decal&start=15
Scroll down there's pics and prices
Those ebay ones are just stickers not the alloy ones jez sells
Sorry for the hijack Brett :P Bikes coming along great.
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
85 GPz750 Refresh Project 11 Sep 2016 09:14 #741841
  • Irish-Kawi
  • Irish-Kawi's Avatar Topic Author
  • Thank you received: 37
Hey Guys, been a while since I posted sorry about that! Life got in the way and a lot happened but still been riding and wrenching as time allows. Here is a brief wrap up of what has been done so far while I've been away.
1. Did some aesthetic work on the heads and sanded/fiiled the fins and some raised section on the cam cover to expose the aluminum
2. Got the customer fender eliminator that I designed and was professionally built from my buddy in, he made me two identical copies in case I ever need a second one!
3. Adjusted steering stem nut that was causing nasty headshake and fixed that, rides like a dream now!
4. Got in my replacement tail light today and going to start that process of getting installed, will need help on getting it wired as it is meant for a 1998- 2002 Ninja ZX6R
Some pics now:
Before:
After:
Brett
All the gear all the time!
1985 Kawasaki GPz 750 (ZX750-A3) 15,000 original miles www.kzrider.com/forum/11-projects/601230...z750-refresh-project
Father - Husband - Bourbonr - Rider
85 GPz750 Refresh Project 11 Sep 2016 09:16 #741842
  • Irish-Kawi
Oh almost forgot also got the new tank cleaned inside and ready to head to the paint shop to have the dents pulled, just need to save up a bit of $$ to do that, hopefully in a few weeks since I am working 12 hr OT shifts for 3 weeks straight ugh!
Fender Eliminator Pics, multiple posts due to link limitations:
85 GPz750 Refresh Project 11 Sep 2016 09:18 #741843
  • Irish-Kawi
85 GPz750 Refresh Project 11 Sep 2016 09:21 #741844
  • Irish-Kawi
85 GPz750 Refresh Project 11 Sep 2016 09:22 #741845
  • Irish-Kawi
Ok so surprisingly enough even though it was only 9am my time my tail light showed up, now I have a few questions and was hoping for a bit of insight here. This tail light is meant for a 1998-2008 Ninja ZR73, ZX6R, ZX9R, ZX600 or ZZR600 and has connectors for it. It also came with two resistors. There are ZERO directions included with these, so my questions are fairly straight forward I hope. Which direction do the resistors go in (does it even matter), and how would I wire in the turn signals when there are only two cables compared to the 4 that came off of my bike? I figure I have some wiring work ahead of me, on my bike I already pinned out which wire is what and have the + and - turn signal wires for left and right figured out, brake light wire, and running light and ground. Those will be easy enough to figure out I think, on the new tail light there is white, red and black. Black will be ground, red will be constant hot and white will be switched hot I think? Any input and suggestions would be appreciated. To clarify, there are 2 wires for each turn signal, + and - if that helps. Now for some pics to help explain what I am seeing:
Brett
Last edit: by Irish-Kawi.
85 GPz750 Refresh Project 11 Sep 2016 09:42 #741850
  • Irish-Kawi
Holding the light up to see how it will look, liking it a lot but will likely trim off the two lower mounting tabs to clean up the look and smooth it out, thoughts?
Brett
85 GPz750 Refresh Project 15 Sep 2016 06:55 #742332
  • Irish-Kawi
Well yesterday was very productive and got everything installed! A few notes before some pics though, I am not all together pleased with the license plate, it comes too close on heavy bottom out bumps to hitting the rear tire so it is going to be relocated eventually probably this off season but I just have to figure out how and where :(
Otherwise the install went very well and came out so clean I love it! The relay will need to be ordered as the lights even with the resistors still flash too fast but that should be an easy fix. All together though it is super bright and really a nice unit! Used some grommets when routing wiring through the pieces and came out slick. Everything was soldered and heat shrink tubing applied to all connections and I even heat shrinked the resistors so they don't come apart too. :iconclap:
Brett
85 GPz750 Refresh Project 15 Sep 2016 06:55 #742333
  • Irish-Kawi
Brett
