1982 KZ1000 Project 21 Apr 2016 15:25 #722245
  • pete greek1
  • pete greek1's Avatar
  • Thank you received: 185
Just thinking out loud, :unsure: wouldn't it look better if the blue fittings were black? to match the paint job, :unsure:
Pete
1982 KZ1000 Project 21 Apr 2016 15:51 #722246
  • jmartin1110
  • jmartin1110's Avatar Topic Author
  • Thank you received: 2
pete greek1 wrote: Just thinking out loud, :unsure: wouldn't it look better if the blue fittings were black? to match the paint job, :unsure:
Pete
I looked for all black connections. I got all of the fittings and braided hose as a kit for much cheaper then it would have cost me to piece it together.
1982 KZ1000 LTD (in progress)
1981 Honda CB750F
2010 Honda Stateline VT1300
1982 KZ1000 Project 21 Apr 2016 16:09 #722247
  • pete greek1
Pete
Black high temp. rattle can engine enamel,?
Pete
1982 KZ1000 Project 21 Apr 2016 16:19 #722250
  • Bozo
  • Bozo's Avatar
  • Ride it like u stole it
  • Thank you received: 104
Great progress, I'm also making up a GPZ1100 hybrid but the clothes on mine aren't as pretty, as mine is mostly assembled from spare parts I had in the shed (I had the push the redback spiders away to re-claim my stuff)
Third ride is now the Frankenstein 1981 GPZ1100B1, getting new/ refurbished 83-84 motor soon
Forth my work bike FJ1200 1989 (same type as above)
Last edit: by Bozo. Reason: punctuation
1982 KZ1000 Project 21 Apr 2016 16:30 #722253
  • jmartin1110
pete greek1 wrote:
Pete
Pete
That's a thought. I could use the same stuff that I painted the engine with. Satin black duracoat
1981 Honda CB750F
1982 KZ1000 Project 21 Apr 2016 17:18 #722264
  • pete greek1
jmartin1110 wrote:
pete greek1 wrote:
Pete
Pete
+1, B)
Pete
1982 KZ1000 Project 22 Apr 2016 06:26 #722323
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
this thing is looking evil .
keep us posted,
1982 KZ1000 Project 22 Apr 2016 06:41 #722324
  • rrsmsw9999
  • rrsmsw9999's Avatar
  • Thank you received: 67
Why do some 1000s have the oil cooler and some do not? My 80 1000E does not. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
1982 KZ1000 Project 22 Apr 2016 06:59 #722329
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2632
On a stock set up you shouldn't need one.
1982 KZ1000 Project 22 Apr 2016 07:33 #722337
  • jmartin1110
I had to buy a piece to replace the oil pressure sensor housing so I could run one
1981 Honda CB750F
1982 KZ1000 Project 01 May 2016 20:33 #724037
  • jmartin1110
Got the exhaust mounted for good. Also picked up a sprocket cover/clutch plate from Kipkawa. I widened the spot for the clutch release to fit a hydraulic clutch from a ZX7. I am also getting the wiring sorted bit by bit including getting the Dyna S wired up. I just ordered new 8mm wires to match my Dyna coils. Progress should pick up again. I took a break from the KZ to get my Honda painted and cleaned up. And since we all love pictures, I leave you with a picture of my 81 Honda Supersport
1981 Honda CB750F
1982 KZ1000 Project 18 Jul 2016 19:56 #735393
  • jmartin1110
1981 Honda CB750F
