1982 KZ1000 Project 30 Oct 2015 12:52 #696561
  • pete greek1
  • pete greek1's Avatar
  • Thank you received: 185
Welcome, & Yes, we like Pics, the more the merrier
Pete
1982 KZ1000 Project 01 Nov 2015 03:58 #696688
  • jmartin1110
  • jmartin1110's Avatar Topic Author
  • Thank you received: 2
So I found a small problem...
Attachment IMG_0090.jpg not found
No charging components at all. I have sourced a stator. Currently looking for a generator.
And some goodies...
Attachment IMG_0089.jpg not found
Got the matching rear wheel for a steal with rotor, cush drive and sprocket. Still waiting on the forks and swing arm.
1982 KZ1000 LTD (in progress)
1981 Honda CB750F
2010 Honda Stateline VT1300
Last edit: by jmartin1110.
1982 KZ1000 Project 01 Nov 2015 18:21 #696820
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2632
Oh crap. Disregard my comment on your other thread.
Re:1982 KZ1000 Project 01 Nov 2015 18:25 #696821
  • jmartin1110
No worries. Thanks for the reply. It looks like they took the generator and cut it down to save rotating weight. I found a used one on eBay so I guess that's my only option at this point.
1981 Honda CB750F
Re:1982 KZ1000 Project 02 Nov 2015 03:25 #696855
  • jmartin1110
Pulled off the valve cover today. Also took at look at the pickup and it appears that I have a Dyna pick up. Also cut the old foot peg mounts and started prepping the frame for the new ones.
1981 Honda CB750F
Re:1982 KZ1000 Project 02 Nov 2015 04:07 #696859
  • SWest
  • SWest's Avatar
  • 10 22 2014
That doesn't look like the right exhaust cam. No worm drive for the tach. The fitting is there. I'm afraid it's going to be up hill all the way on this one. I wouldn't even try it unless a Bobber is all you want.
Re:1982 KZ1000 Project 02 Nov 2015 04:28 #696864
  • jmartin1110
I'm wondering if they took another intake cam and swapped it out. I've seen threads here about that. I wasn't planning on using a mechanical tach so I'm not worried about it. What do you mean? I'm not looking for an easy project. If I was I would just buy all ltd parts and put it back together in its stock form.
1981 Honda CB750F
Re:1982 KZ1000 Project 02 Nov 2015 04:34 #696866
  • SWest
  • SWest's Avatar
  • 10 22 2014
They might be some other kind of cams. Measure them and let us know. As for the work, as long as you know what you're in for, it's your baby. :whistle:
Re:1982 KZ1000 Project 02 Nov 2015 04:48 #696868
  • jmartin1110
Will do. One of my other bikes is a heavily modified Honda CB750F. I've been working on it off and on since I got home from Iraq. I may not be the most skilled fabricator but I enjoy the challenge and the learning process. I didn't know anything about bikes until I decided to rip apart my CB. I've learned a lot over the last 5 or so years and want to learn more. One of the reasons I'm here is that this place is a wealth of knowledge on all things KZ.
1981 Honda CB750F
1982 KZ1000 Project 02 Nov 2015 04:54 #696869
  • kaw-a-holic
  • kaw-a-holic's Avatar
  • Thank you received: 248
I noticed you went with RFY shocks. from personal experience I can tell you in stock form they are not that great. Not horrible, and improvement over my stock shocks for sure. Chris Livengood rebuilds these shocks. He states the construction is good but the some of the internals need work. He replaces the internal spring, oil and then fills them with nitrogen. Even with is charge to rebuild them your cheaper than entry level progressives. Here is a link to his site.
chrislivengood.net/wp/product-category/shock-rebuilds/
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Re:1982 KZ1000 Project 02 Nov 2015 05:29 #696875
  • jmartin1110
I'll give the site a look bud. Thanks. I've got them on my Honda as well and they perform about as well as I expected since they are so cheap.
1981 Honda CB750F
1982 KZ1000 Project 02 Nov 2015 14:37 #696929
  • jmartin1110
My shaft (e model??) tank came in today. I was able to get it to fit with very minimal modifications. Just had to widen the tunnel a bit. Once I get my hand on some side covers and a seat I will know if its sitting low enough, It does hook right in to front of the frame so I know that the front is sitting right.
Attachment IMG_0104.jpg not found
1981 Honda CB750F
