  • Page:
  • 1
  • 2
Can a Z1300 engine fit into a KZP? 28 Sep 2015 15:06 #692383
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2071
Making something into something it is not? Sounds like a definition of custom to me.
www.kz1300.com/index.php/forum/daily-cha...-s-1300?limitstart=0
www.kzrider.com/forum/11-projects/598446...r-build?limitstart=0
Last edit: by TexasKZ.
Can a Z1300 engine fit into a KZP? 29 Sep 2015 05:21 #692470
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
Seems like it would be easier to move the bags and fairing from the KZP to the 1300 frame...
Also a bare frame and motor, on it's own without about 2000 other parts numbers, a lot of them unique to z1300 is a difficult/uneconomic proposition to restore, so making something out of the existing frame and motor would be more feasible.
Can a Z1300 engine fit into a KZP? 29 Sep 2015 05:42 #692474
  • floivanus
  • floivanus's Avatar
  • Thank you received: 116
Correct definition of custom, BUT a long spindly chopper with a wide inline 4 never looks right, an even wider 6 will most likely make the power plant look like an afterthought no matter how much work and planning go in.
IMHO
Past; 78 kz1000, 83 kz550
Andrew
Can a Z1300 engine fit into a KZP? 29 Sep 2015 07:43 #692481
  • Tyler
  • Tyler's Avatar
  • Thank you received: 92
floivanus wrote: Correct definition of custom, BUT a long spindly chopper with a wide inline 4 never looks right, an even wider 6 will most likely make the power plant look like an afterthought no matter how much work and planning go in.
IMHO
This guy pulled it off....
Attachment Chopper.jpg not found
"74 Yamaha DT 400 Enduro
Re:Can a Z1300 engine fit into a KZP? 29 Sep 2015 07:53 #692484
  • GPzMOD750
  • GPzMOD750's Avatar
  • Thank you received: 148
I vote street fighter. That lump is too big for a cafe as well.
Can a Z1300 engine fit into a KZP? 29 Sep 2015 08:21 #692490
  • jackleberry
  • jackleberry's Avatar
  • Thank you received: 56
Hard to believe, but this BMW K100 cafe racer looks less ridiculous...
1997 KZ1000P (P16)
2001 KZ1000P (P20)
Can a Z1300 engine fit into a KZP? 29 Sep 2015 09:23 #692495
  • floivanus
IMHO
Pulled it off is up to interpretation; cafe, bobber, chopper is supposed to be a bike you make lighter with less BS, and to look right, I hate to say it chops are supposed to be narrow, ala a v-twin, a vertical twin also works if done right. Also choppers with a huge gap under the tank look wrong to me as well. Not to say it cannot be done. Just that the powerplant doesn't fit the end goal
Andrew
Can a Z1300 engine fit into a KZP? 29 Sep 2015 14:52 #692540
  • TexasKZ
  • TexasKZ's Avatar
Maybe a power cruiser, ala VMax.
Can a Z1300 engine fit into a KZP? 29 Sep 2015 15:04 #692541
  • TexasKZ
  • TexasKZ's Avatar
  • Page:
  • 1
  • 2
