  • Page:
  • 1
  • 2
Can a Z1300 engine fit into a KZP? 27 Sep 2015 22:37 #692251
  • yorkieUK
  • yorkieUK's Avatar Topic Author
  • Thank you received: 1
I've got a few unfinished projects due to arrive next week to see me through the winter, including 3 x KZP's and a Z1300 engine & frame.
Has anyone ever tried to, or does anyone know if it is possible to squeeze a Z1300 engine into a KZP frame?
Here is my daily ride that I toured around Europe on this year.
Attachment WP_20150823_003.jpg not found
Attachment WP_20150420_007.jpg not found
1982 GPZ1100 plunger chop
1990 KZ1000P-9 (ex San Diego P.D.)
Can a Z1300 engine fit into a KZP? 28 Sep 2015 03:54 #692258
  • Jussumguy
  • Jussumguy's Avatar
  • Thank you received: 11
Water cooled, shaft drive ect... How long is your winter? : )
Can a Z1300 engine fit into a KZP? 28 Sep 2015 04:43 #692268
  • Thank you received: 2829
Sure, all it takes is commitment, time, engineering skills, and lots of money. I figure if a guy can squeeze a V12 Lamborghini engine into a bike (see below) almost anything is possible ;) Ed
Attachment 00003a-116.jpg not found
Can a Z1300 engine fit into a KZP? 28 Sep 2015 04:58 #692269
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1978
650ed wrote: Sure, all it takes is commitment, time, engineering skills, and lots of money. I figure if a guy can squeeze a V12 Lamborghini engine into a bike (see below) almost anything is possible ;) Ed
I have to agree with Ed. Anything is possible . It is just a matter of cubic Dollars
Dave B) B) B)
Can a Z1300 engine fit into a KZP? 28 Sep 2015 07:16 #692301
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Hmmm... if they paint that thing to look like the Oscar Meyer Wiener Mobile, it could be the Weeny Cycle.
Last edit: by loudhvx.
Can a Z1300 engine fit into a KZP? 28 Sep 2015 09:28 #692316
  • Tyler
  • Tyler's Avatar
  • Thank you received: 92
Can it be done.. probably. The 1300 mil is probably too tall to fit inside the frame, that might be the most difficult part to contend with. Its a shaft drive, and I doubt a 1300 swing arm would fit on 1000 frame. Everything about the 1300 is big...
I'm sure it can be done, I just don't know why it would be worth all trouble. You could build a 4 cylinder with just as much power...
Here is an idea of what you are up against.
Attachment 11-2.jpg not found
"74 Yamaha DT 400 Enduro
The following user(s) said Thank You: yorkieUK
Last edit: by Tyler.
Re:Can a Z1300 engine fit into a KZP? 28 Sep 2015 10:01 #692322
  • StreetfighterKz
  • StreetfighterKz's Avatar
  • Thank you received: 117
The width of the entire drivetrain will be too wide without performing major surgery to the frame. Even a shaft drive Kz1000 has a pivot width of about 2" wider to allow room for the driveshaft and yoke. Then you may have interference issues with the #2 and #5 exhaust tubes and the frame down tubes. Then mounting the radiator, etc etc.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
Re:Can a Z1300 engine fit into a KZP? 28 Sep 2015 10:46 #692326
  • yorkieUK
Thanks Doug, that's the answers I was looking for.
I've had Kawasaki's since I was 12 years old but I've never managed to get my hands on the six-pot until now.
I've always fancied the idea of building a Z1300 chopper, but never wanted to cannibalise a good one.
Now I've got a Z1300 frame & engine amongst a deal on 3 x KZP's on it's way to me, so who knows, I might have that chopper done over the winter.
Cheers.
Can a Z1300 engine fit into a KZP? 28 Sep 2015 10:48 #692327
  • yorkieUK
Thanks for the heads-up Tyler.
Tyler wrote: Can it be done.. probably. The 1300 mil is probably too tall to fit inside the frame, that might be the most difficult part to contend with. Its a shaft drive, and I doubt a 1300 swing arm would fit on 1000 frame. Everything about the 1300 is big...
Can a Z1300 engine fit into a KZP? 28 Sep 2015 11:17 #692332
  • jackleberry
  • jackleberry's Avatar
  • Thank you received: 56
Seems like it would be easier to move the bags and fairing from the KZP to the 1300 frame...
1997 KZ1000P (P16)
2001 KZ1000P (P20)
Can a Z1300 engine fit into a KZP? 28 Sep 2015 14:43 #692373
  • floivanus
  • floivanus's Avatar
  • Thank you received: 116
ACK! Inline 4 choppers look like snot (no matter how it is done, the motor choice is wrong) chops are supposed to be long low and lean, a 4 cylinder kaw motor is wide, the six is definately gonna look way out of place.
Past; 78 kz1000, 83 kz550
Andrew
Can a Z1300 engine fit into a KZP? 28 Sep 2015 14:53 #692378
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2635
Why make something it is made for into something it's not? These things are made with power but not enough suspension to use it fully. The upgrade mods here are going in the right direction, making a 'Chopper" out of them seems to me to be going in the wrong direction for the wrong reasons. I guess you could pull a trailer with it. :whistle:
  • Page:
  • 1
  • 2
