1983 kz550 ltd 29 Nov 2014 04:25 #654899
  • fastdave
  • fastdave's Avatar Topic Author
  • Thank you received: 4
I will be restoring this bike. Where should I start? Im thinking about taking it apart to restore all the chrome and aluminum. Take off the carb, clean it and replace any rubber parts. New battery and tires obviously. Also new paint on the tank which is showing some surface rust. Im not sure if I should just get a new tank. I dont want a problem in 2 years after doing all the work to make it look good. This bike has 6500 miles and I got it from the original owner.
Attachment 20141128_162118.jpg not found
Faster is more fun
1983 kz550 ltd 01 Dec 2014 02:12 #655031
  • fastdave
So far just taking things apart and doing my homework.
I didnt get an overall view of what I took apart so far but I will for the next round of pictures. Lots of painting and polishing to do!
Attachment 20141129_100050.jpg not found
Attachment 20141130_103430.jpg not found
Attachment 20141130_093053.jpg not found
Faster is more fun
1983 kz550 ltd 01 Dec 2014 04:42 #655033
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
  • Thank you received: 80
Are you really going to keep the emission air valve system? It tens to be a great source for possible vacuum leaks, and doesn't guarantee you any better gas mileage.
'85 GPz550(ZX550-A2)
1983 kz550 ltd 02 Dec 2014 02:02 #655124
  • fastdave
Is that what all the tubes are on top? How would you eliminate them? Is there a thread with that kind of information? :huh:
I will be uploading some pictures when my internet is upgraded sat. It has been runningat .15 mbps. Lol, good bye at+t.
Faster is more fun
1983 kz550 ltd 02 Dec 2014 05:42 #655135
  • CoreyClough
  • GPz550 Addiction
if you remove that valve, you can either cap off the valve cover fittings, or buy a set of APE Reed Cover Caps.
kzzone.com/billet.html
This would free up room for valve clearance checks too.
1983 kz550 ltd 03 Dec 2014 02:44 #655221
  • fastdave
Nice idea. Does the bike run the same? The biggest challenge right now is learning to polish chrome and aluminum. I can paint really well already. Any tips on that would be appreciated too
Mouse house! :ohmy:
Attachment 20141201_182340_2014-12-06.jpg not found
Faster is more fun
Last edit: by fastdave. Reason: picture did not attach
1983 kz550 ltd 03 Dec 2014 04:30 #655223
  • CoreyClough
  • GPz550 Addiction
Yes the bike will run the same, just disable the vacuum hoses from the carbs, that operate this valve system. Easily overlooked.
1983 kz550 ltd 03 Dec 2014 05:08 #655225
  • CoreyClough
  • GPz550 Addiction
No eBay APP ID and/or Cert ID defined in Kunena configurationTo add, there is this Ebay Seller that seems to be parting out a 1983 KZ550:
1983 kz550 ltd 03 Dec 2014 05:21 #655229
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
Be sure to install new brake shoes.
I would get oem or Vesrah (e.g., VB-412). Z1Enterprises.com may have them.
It has been reported that some EBC brake shoes don't fit right.
The following user(s) said Thank You: fastdave
Last edit: by martin_csr.
1983 kz550 ltd 04 Dec 2014 14:33 #655358
  • fastdave
Thanks good to know, I just ordered the rears. What about the fronts. What is good price/quaility? I also need a battery if there are any suggestions on that.
Faster is more fun
1983 kz550 ltd 04 Dec 2014 15:00 #655361
  • CoreyClough
  • GPz550 Addiction
Do not get the battery that you hve to add the acid, and charge, it's better to buy a sealed maintenance free battery. These are available a lot of places. Check with some of the vendors on this site.
EBC Brake Pads are good for me.
1983 kz550 ltd 05 Dec 2014 16:46 #655441
  • fastdave
Some more pics...
Attachment 20141201_182247.jpg not found
Attachment 20141201_084544.jpg not found
Faster is more fun
Last edit: by fastdave. Reason: photos did not attatch
