Doctorot's '78 KZ1000 build 18 Oct 2016 13:07 #745595
  • DoctoRot
  • DoctoRot's Avatar Topic Author
  • Thank you received: 664
i'm down in San Jose for the school year, so the riding weather is year round!
Doctorot's '78 KZ1000 build 24 Oct 2016 23:25 #746151
  • DoctoRot
The front wheel spacer My buddy turned for me left a little to be desired, but at the time this was the only stock we had so not his fault. I remade it to cover the oil seal and make it a bit more sanitary.
I got a start on the brake mounts. I bored all the holes and then used a thread former to cut M10x1.25 threads. It was my first time using a thread former, and man they are trick. produces no chips, so no backing up every quarter turn, longer tool life. better in every way. I'm never going to by a traditional tap again. I also bored the recesses for the caliper and cut them out of the plate. II still need to clean up theoutside and I want to do some pocketing, How much material do you think i can safely remove? I was thinking about having 1/4" think walls and bottom.
Last edit: by DoctoRot.
Doctorot's '78 KZ1000 build 24 Oct 2016 23:25 #746152
  • DoctoRot
Doctorot's '78 KZ1000 build 25 Oct 2016 05:17 #746162
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
i think leaving everything a 1/4 inch thick will be plenty strong with the structure that the walls and floor create.
imho
Doctorot's '78 KZ1000 build 30 Oct 2016 00:19 #746509
  • DoctoRot
Brake mounts are finished. I started planning out to do the pocketing cuts and shit started getting way too complicated so I just eyeballed em, having a CNC here would be awesome. I'm not a fan of tooling marks unless they are super even (like a CNC), so I blasted the pockets and gave everything else the brushed treatment. I noticed one of the forks is weeping fluid so rebuilding those will be up next.
Doctorot's '78 KZ1000 build 30 Oct 2016 12:24 #746569
  • spdygon
  • spdygon's Avatar
  • Thank you received: 117
wow....that is nice. do those calipers use original kz pads?
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Doctorot's '78 KZ1000 build 30 Oct 2016 13:56 #746589
  • DoctoRot
Thank you. These Grimeca calipers use a different pad. I'm planning on running Ferrodo Platinum pads
Doctorot's '78 KZ1000 build 30 Oct 2016 14:50 #746599
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
HOT :evil:
Doctorot's '78 KZ1000 build 30 Oct 2016 15:04 #746603
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
Very nice work....!!
Doctorot's '78 KZ1000 build 31 Oct 2016 06:34 #746673
  • Ed_in_Miami
  • Ed_in_Miami's Avatar
  • Thank you received: 46
Wow!! Excellent work, beautiful bike!
This is my build:
kzrider.com/forum/11-projects/600312-ano...rtment-build?start=0
There are many more like it, but this one is mine... news to come!
Doctorot's '78 KZ1000 build 31 Oct 2016 09:26 #746702
  • 531blackbanshee
  • Vendor
those caliper brackets came out nice.good job :evil:
Doctorot's '78 KZ1000 build 08 Nov 2016 00:04 #747540
  • DoctoRot
Got the paint cut and buffed. I burned through a tiny spot on the tail but it polished out well enough that I'm cool with it, also some flaws in the stripes on close inspection but not bad for first time doing that or the polish.
