New project.1428 turbo or supercharged, Who knows? 05 Sep 2010 03:52 #396230
  • zed1015
  • zed1015's Avatar Topic Author
  • Away
  • Thank you received: 1474
Started work on the frame bracing.
Headstock first.
Before and after removing horrid factory bracketry
Frame under boxed in bracing has never seen paint and was full of rust
New improved bracing plates. (3mm -(1/8th inch)- steel sheet from old bus stop :laugh: )
These will be seen as fuel tank will sit on the top frame tubes so need to look the part
Several hours and burnt fingers later.
Rest of the frame will get the same treatment in due course.
New project.1428 turbo or supercharged, Who knows? 05 Sep 2010 05:07 #396232
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
  • Thank you received: 109
Excellent work.
Tally Ho
B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
New project.1428 turbo or supercharged, Who knows? 05 Sep 2010 17:17 #396340
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
youve got my undevided attention! B) B) B) B) B)
New project.1428 turbo or supercharged, Who knows? 06 Sep 2010 15:29 #396585
  • zed1015
  • Away
Another section of rust harbouring bracketry bites the dust
To be replaced by more swiss cheesed bus stop
This also provides space to hide a reg/rec in case i don't accuire a magneto or fit a belt drive alternator
New project.1428 turbo or supercharged, Who knows? 07 Sep 2010 09:41 #396746
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Thank you received: 797
really nice work there zed thanks for sharing the pics.
keep us posted,
New project.1428 turbo or supercharged, Who knows? 07 Sep 2010 13:41 #396824
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
  • Thank you received: 59
I'm following this with interest, especially as I'm modifying the frame on my 750 turbo and using ZX10R forks.
I'm surprised at the differences between the Zephyr frame and the old 750 frame. The Zephyr frame is much chunkier. The 1100 motor would go in the 650/750 frame without removing the downtubes, but you couldn't get the cam cover off :laugh: . I'm not against removing the downtubes in principle, it looks nice.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
New project.1428 turbo or supercharged, Who knows? 07 Sep 2010 14:43 #396841
  • jordan
  • jordan's Avatar
I really like this project, ile be watching it closely
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
New project.1428 turbo or supercharged, Who knows? 07 Sep 2010 15:00 #396843
  • zed1015
  • Away
Yeah i've done the 650/1000 thing a couple of times but it's not really worth the hassle.
Couldn't believe that they hid a frame like this under all that bland bodywork.
As soon as i saw it i knew it had to be done, Didn't plan on loosing the frame tubes though but that's projects for you, They always turn into something bigger :laugh: (and better ?)
It is a tight fit, 2mm clearance front and back , Just enough to squeeze in some paint but the head etc can be removed in situ and just pushing it around it FEELS right,
The frame hugs the motor and it's hard to tell by the pic's but it is small, only 5 inch between the cases and the front tyre so i'll have to be inventive with the exhaust to avoid restricting the 1428 block whilst keeping it all in proportion.
Fingers crossed ;) .
New project.1428 turbo or supercharged, Who knows? 07 Sep 2010 17:44 #396879
  • Thank you received: 2098
hocbj23 wrote:
...Zundapp built a lovely 250 two stroke with the motor as a stressed member.There was no front downtube at all.As best I can remember,the motor was "slung" underneath the top tubes and attached there plus at or near the rear swing arm.Looked a little funky but very rigid and handled very well....
Evokes fond memories. :cheer:
Good Fortune! :)
New project.1428 turbo or supercharged, Who knows? 07 Sep 2010 19:26 #396904
  • timebomb33
  • timebomb33's Avatar
take a look at any old harley sprint or even a 750 to 1100 virago they used the engine as a stressed member. lots of other examples makes it way easier to pull the engine which is cool when your building crazy hot rods.
I THINK MY POWERBAND BROKE
New project.1428 turbo or supercharged, Who knows? 11 Sep 2010 05:22 #397610
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
i just love the way u redid the gussets. u managed to blend form and function perfectly, and came out with a lighter, and stronger frame to boot.
Way to go man.B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
New project.1428 turbo or supercharged, Who knows? 11 Sep 2010 12:52 #397680
  • zed1015
  • Away
More welding and bus stop butchery today :).
Got the subframe mounts done and some stainless rose joints fitted waiting for an ally subframe
Don't know if they will go on the inside or the outside of the mounts till i start playing about
The threaded spacers between the plates are stepped and a press fit as well as being welded
Outer top plates follow the lines of the top frame tube so that they will blend with the fuel tank ( once i've made it ) and double as an external brace for that bend in the frame (Every little helps :) )
Couldn't get a decent pic under the flourecent lighting and it was raining outside :( .
