76 KZ900 upgrade
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
Re: 76 KZ900 upgrade
16 Mar 2008 06:02
#200278
easy for u .lol.how did u get it turned? when i turned it in my photo program it changed back when i posted it???:side:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mark1122
  • Keep twisting it
16 Mar 2008 16:05
#200441
show off! so , smarty pants,how do i do that?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • btchalice
  • btchalice's Avatar
17 Mar 2008 05:25
#200524
i use adobe cs3
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • rstnick
  • rstnick's Avatar
17 Mar 2008 06:39
#200534
Can't wait to see it again this comming season.
You've been very busy.
Too bad on your ebay deals.
Some pix from last season:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • mark1122
  • Keep twisting it
18 Mar 2008 18:30 - 09 Oct 2008 06:43
#200847
I just finished sand blasting my cases and zx9 brake calipers’ got my trees for a test fit and to fit the stops. Here is a pic of the trees so far. lots of finish grinding and polish work to do yet. i had the gauge supports cut off the old kz tree and welded on the zx9 tree.
The KZ stem is smaller OD than the ZX9’s. So the stems must be swapped to allow the use of the zx9 tree’s.
Just remember that the zx9 stem has a circlip in the bottom. You can’t see it as it is inside. You could turn or grind it down first. Then you must press the stem out from the top down. I found this out the hard way. My machinist pressed it out with out removing the clip. We did not know it was there. It did work though.
The KZ stem can be pressed out from the bottom up, after grinding off the weld on the bottom..
He put the zx9 stem in the lathe and drilled a hole in the bottom, the size of the KZ stems bottom OD. Then he cut the bottom off the zx9 stem. This bottom piece will act as a sleeve, and be pressed over the bottom of the KZ stem. The KZ stem can now be pressed into the zx9’s lower tree. I then drilled and tapped through the stem, and tree. I put a bolt through the stem and tree just as a precaution.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 09 Oct 2008 06:43 by mark1122.
  • madderkaw
  • madderkaw's Avatar
19 Mar 2008 03:35
#200903
Call me crazy, but I have a KZ 900, KZ650, and a ZRX1100 and I'm messing around with all three of them. I guess I must be smarter than everyone who has worked at Kawasaki for the past 35 years. Or maybe that's dumber.
  • zzrmkII
  • zzrmkII's Avatar
27 Mar 2008 06:29
#202459
Wait til ya see my zrx 1100 in a couple of more weeks....:woohoo:
In the middle of town with my
74 750 triple dragbike
78 KZ1000 dragbike
80 KZ1000 MKII
81 KZ1000 J model
00 ZRX1100
and my 97 Dyna
  • RoyNor
  • RoyNor's Avatar
20 May 2008 01:42
#214679
Shit!
These thread I just have missed. :blush:
Nice work. :P
I have to study closely your pictures. :woohoo:
What paint did you use on that big bore barrel?
  • mark1122
  • Keep twisting it
20 May 2008 10:34
#214752
Dupli-color Engine enamel 500*F,260*C. Low gloss black. after 1 season it has held up well.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
21 May 2008 19:34 - 07 Feb 2013 03:20
#215001
79 KZ1000ST
Past:
Many.
Last edit: 07 Feb 2013 03:20 by KZ250LTD.
  • mark1122
  • Keep twisting it
26 May 2008 10:22 - 03 Jan 2010 14:57
#215947
i guess i wont have to worry about wiping it off in the morrning then , since thats not my bike.lol.
that is 1 i saw on the net that had a big flat spot on the bottom of the header. this made me beleive i should go with the longer zx9 forks.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 03 Jan 2010 14:57 by mark1122.
  • CruisingRam
  • CruisingRam's Avatar
06 Jun 2008 15:38
#218407
Man, looking good- riding it yet? B)
1975 Z1 B 900- soon to be heavily modded
Pahoa, Hawaii is my new hom
I am working hard to save up the shipping money to get my shop opened here in Hawaii
I hate electrical stuff.
