76 KZ900 upgrade
  • Old Man Rock
  • Old Man Rock's Avatar
Re: 76 KZ900 upgrade
29 Jun 2008 06:57
#222785
Damn your bike is looking mighty sweet... Envious!
You're single right? hahahahhaha
My wife is so sick of my affair with the old girl... I tell her to shut her trap and deal with it... NOTE to thyself: Divorce on the way!
BTW, received my offset sprocket (13.5mm = >1/2") 630 15 tooth from AmericanClassix all ready. I don't know why others have had bad results with these guys but they have rocked every time for me...
Extremely well designed and built. Rear sprocket and chain on the way. Figured I'll only need ~ 102 link or so but ordered 110 link just to be safe, cut and grind as required.
I'll post w/images once I get all components on the bike and aligned...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • mark1122
  • mark1122's Avatar Topic Author
  • Keep twisting it
28 Sep 2008 18:13
#239113
I thought i should finaly add a few updated pics.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mark1122
  • Keep twisting it
28 Sep 2008 18:29
#239118
Left side.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
28 Sep 2008 18:42
#239120
nice!bike turned out really well,good job.
  • mark1122
  • Keep twisting it
28 Sep 2008 18:48 - 28 Sep 2008 18:52
#239122
1 more
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 28 Sep 2008 18:52 by mark1122.
  • mark1122
  • Keep twisting it
28 Sep 2008 18:57 - 28 Sep 2008 19:34
#239123
Thanks Banshee.
Since i got a $300 ticket for having the breather filter in the kick start cover.(for altering the emissions system). I needed to remove the filter and add venting ells ware. I cannot make it legal, but I want to try to hide the obvious. so I decided against adding 1 to the valve cover(witch I think would wok well). I decided to just increase the size of the breather cups outlet. I thought this would be the most discrete method.
Here is a pic of the stock Z1 ,and KZ breather set up. I changed to the KZ since i felt it was less likely to spit oil.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 28 Sep 2008 19:34 by mark1122.
  • mark1122
  • Keep twisting it
28 Sep 2008 19:00
#239124
this is the newer KZ type. it has 2 levels.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mark1122
  • Keep twisting it
28 Sep 2008 19:03
#239125
I took the upper disk to work and had 2 new holes drilled and 2 nuts welded to the under side of the holes. Then I drilled matching holes in the cup. This will allow me to screw the cup to the upper plate , to hold the cup on. Then I had the cups vent hole drilled and tapped out to 5/8” NPT. I cut the nipple off the 1/2” threaded nipple so I could fit a ¾” hose over it. The nipple part was not 5/8” ID but the threaded part is. Now I will run a 5/8" or a 3/4” hose up under the tank and T off to 2, ½” hoses. Then I can run the 2 ½” hoses to the back of the bike under the seat.
The venting capacity of the inner rubber vent tubes is :
the rubber vent tubes are about .370 each. x 2 = an area of .21" total.
the stock cups vent stack tube/bolt has an id of .425" .area = .142".
the bolt hole in the case is about .260". (area= .053").(i removed this bolt so this is now more inner venting capacity.so i can add this .053" to .21" to get a total inner capacity of .253")
1/2" hose area = .196"
5/8" hoes area = .307"
here is a pic of the inners, and the cup. I found 2 rubber plumbing tap washers to fit over the new cup fastening bolts.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mark1122
  • Keep twisting it
28 Sep 2008 19:15 - 28 Sep 2008 19:28
#239127
1 more of the nipple cut off,and the bolts with the rubber washers.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 28 Sep 2008 19:28 by mark1122.
  • mark1122
  • Keep twisting it
28 Sep 2008 19:20 - 28 Sep 2008 19:32
#239128
here is a pic with the nipple cut off and the rubber washers and bolts.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 28 Sep 2008 19:32 by mark1122.
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
29 Sep 2008 19:42 - 29 Sep 2008 19:43
#239331
Besides being one of the coolest ways that I've seen around a problem...what kind of a prick takes the time to check your crank-case vent port for an add-on filter mod??? Where do you live?
-KR
PS>>>GREAT work by the way!!!
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
Last edit: 29 Sep 2008 19:43 by Bad Kaw.
  • Old Man Rock
29 Sep 2008 19:45
#239332
"what kind of a prick takes the time to check your crank-case vent port for an add-on filter mod?"
I was wondering this myself... Here in Phoenix, they wouldn't even know what it was let alone that it was modified...
Good question Kaw...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
