some progress. 21 Mar 2007 08:15 #122231
  • steell
  • steell's Avatar
  • Thank you received: 207
Ok Russ, just how is it that you have so much room in your garage!!
Somethings not right there, surely you moved stuff out to have room to take the pics!
Or you have a storage place somewhere?
some progress. 21 Mar 2007 09:23 #122251
  • solomrus
  • solomrus's Avatar Topic Author
  • Thank you received: 1
wheels, man, wheels.
everything in the garage is on wheels.
--r
198o kz1ooo Bravo Four
some progress. 21 Mar 2007 12:02 #122278
  • wireman
  • wireman's Avatar
  • Visitor
he puts stuff under beds and under dining room table and ....,oh wait thats me!:P
some progress. 21 Mar 2007 13:25 #122302
  • solomrus
wire, i'm about at that point tho!
i have parts in the garage attic, under both benches in the garage, and some in the basement now.
i'd hate to see the damage a camshaft would do if my wife banged her toe on it under the bed... or me for that matter. 8^)
check your email too, something in there, wanted your opinion on.
--r
some progress. 21 Mar 2007 18:27 #122364
  • 77KZ650
  • 77KZ650's Avatar
  • Thank you received: 7
I would really appreciate it if you could make one for me. please keep me posted. anything to keep costs down is awesome lol:P 1 bike was enough "project" for me....then I had to find a sweet deal on a ninja that I couldnt turn down.....bike fund took a solid blow there:laugh:
07 MDP Rookie of the Year
some progress. 21 Mar 2007 20:16 #122401
  • wireman
  • wireman's Avatar
  • Visitor
solomrus wrote:
i'll just start off with the pics. not a ton of detail this time, really just overall shots of the stance, and how the bike looks with tank/tail/seat/side's on it.
the upper shock mount is 95% welded in. i am waiting to do the last of it after i pull the engine to finish weld all the odd things, and do the gussetting work. then it's off to coating. probably just going to do a basic blac gloss. yeah, i know original.
the other color that i was considering was a ducati style red, with black or suede body pieces. that would be really cool, but that's uber-italian. not quite what i am going for.
i have the ducati 900ss oil cooler that i am going to use now. that's gonna mount low, down in front of the header. kind of a strange place, but it will be cool, trust me...
took a few minutes and measured up the wheels chainline. the 636 rear wheel is right at 4" for the line... so, barring me being an idiot, by my calculations, i will need a 3/8s offset front sprocket.
here's how i figure that out...
stock 900/1000 chainline is 3.625(3 5/8ths)"
636 chainline (appears) to be 4.000"(center of wheel to center of sprocket with cush drive fully inserted into wheel)
4.000"
- 3.625"
= 0.375"
.375" = 3/8ths"
so, that is what i'll need to make. just need a little bit of DOM tubing and some time on the lathe.
close guys, real close.
--r<br><br>Post edited by: solomrus, at: 2007/03/19 10:23
alright guys i saw it up close and personal again tonight,it looks a lot smaller up close than it does in the pictures.russ wanted me to sit on it but i was afraid i wouldnt want to get off of it if i did!:woohoo:
some progress. 22 Mar 2007 06:52 #122481
  • solomrus
you wouldn't have, and your wife would have been calling me to find out why i grafted your ass to my motorcycle...
8^P
i think i hit my first big hurdle last night...
those sprockets are HARD!!! my little lathe might not have the chutzpa to cut it. all i was doing last night was burning off little pieces of carbide from my cutting tool, and work hardening my cuts.
gonna do some checking, but i might not have the trick of that right now.
i need bigger tools. 8^)
--r
some progress. 22 Mar 2007 08:04 #122498
  • 77KZ650
  • 77KZ650's Avatar
I believe that I read that the sprockets are "case hardened"(??) you may need to heat them, Im not sure....:unsure:
some progress. 22 Mar 2007 08:26 #122502
  • solomrus
yup, that they are.
i read that thread you liked me to over at dragbike.
didn't see where they heated them before turning them down. would make sense tho, as re-heating will anneal the surface, and make it soft again.
hmm.
did he re-harden the sprocket when he was done?
--r
some progress. 22 Mar 2007 08:32 #122503
  • steell
  • steell's Avatar
A couple of ideas:
Try Cermet instead of carbide.
Grind through the case hardening (which is only ~0.010"-0.020" deep or so, normally).
Check the required speeds and feeds for Cermet if you decide to use it.
Are you using indexable or brazed carbide?
I'm fairly certain that Cermet is only available for indexable.
Annealing works with heat treated material, I don't believe it works with case hardened material. Case hardening is a process of adding additional carbon to the metal after it has been finish machined, and I don't think heat will remove the additional carbon.
Post edited by: steell, at: 2007/03/22 11:35
some progress. 22 Mar 2007 08:47 #122506
  • 77KZ650
  • 77KZ650's Avatar
I reread the dragbike thread. they only said to preheat before welding, so they must have used something different than you to do the machining. it doesnt say anything about rehardening the sprocket afterwards.
some progress. 22 Mar 2007 08:53 #122508
  • solomrus
1/2", brazed.
i thought about just grinding the teeth down, then hitting that with the lathe.
won't work to cut the center out of the other sprocket tho.
i'll look into cermet, see if it's cost effective to tool up, or just have joe's do it for me. i called and he'll do it for two hours labor, basically 100$.
good info. i wasn't aware that case hardening was a surfacing treatment vs. heat treatment.
that would explain why heating with the welding doesn't affect the surface treatment. 8^)
--r
