Advanced Search
Search Results (Searched for: gs swing arm)
Replied by njp1956 on topic 1978 KZ750 Twin B3 that used to be a off road bike
20 Jul 2016 06:36 - 20 Jul 2016 06:48
njp1956's Avatar njp1956
Hi timbox take look through this The guy's name is Rolf Witthöft he won the German Enduro championship in 1978 in the over 750cc class it was bored to 701cc .Sorry the article is in German but there are a bunch of pic's to look at '
www.winni-scheibe.com/ta_portraits/rolfw.htm
I had started a 77 for off road I had XR500r front forks on it and the single shock with swing arm the rear suspension was fairly easy to a adapt to the KZ .But it was stolen before I could finish it .
I have a 76 and a friend just gave me a 90's Yamaha WR250 so my 76 is going to be made over to a adventure touring bike .
Here is a couple of things for you . I run GM HEI ignition , a early HEI dis. 4 prong ignition module .with the KZ 750 electronic pickup plate and mechanical advancer
also a 4.3 V6 HEI dual output coil , and NGK resistor Iridium plugs . You don't have to run a screw on cap with these plugs . I got 20 more miles to a tank when I went to the Iridium plugs .
things to note with using the GM module .
1 cut off the plastic pin on back of module ,it must be then mounted on a small aluminum plate using CPU heat sink paste with a good ground to the plate .
2 if the bike doesn't start a first just swap the wires from the pickup from one prong to the other on the module.
My bike runs great .I have a 4 plug head on it now but am only using 2 now , a machine shop teacher at a tec school helped me put the 2nd in .was an easy mod .
Well got to go If you have any ? just ask .Paul
just go to google images to look at the 4 pin GM HEI module wiring diagram . note these modules will run anything with a magnetic pick up and mechanical advance . Will replace early Kawi 4 cyl ignition boxes also
Replied by Bigmd on topic Swingarm question
19 Jul 2016 06:52
Bigmd's Avatar Bigmd
Ok thanks. I believe you jus cleared it up. The brake stay is at bottom. It looks like I have to 650 arms. With that said , can I just order new bearings? I already have end caps. The z1 bearing kit shows spacers . Do I need those?
Replied by floivanus on topic Swingarm question
18 Jul 2016 15:58
floivanus's Avatar floivanus
Bigmd wrote: Well the more I look at it they seem to be identical. It's possible it was listed wrong on eBay.
The VAST majority of kz parts are listed like alphabet soup on eBay (kz z1 650/900/1000 Z1R dragbike GS is usually in the title or description, which muddies the waters)
18 Jul 2016 15:38
I believe the swingarm pivot tube ID and the inner sleeve are the same, the bearings should be able to interchange, pivot tube needs to be shortened to 650 length.
The 1000 arm is wider at the pivot. Shorter than the 650 arm (I think) and uses a 20mm rear axle where the 650 has a 16mm rear axle.
Swingarm question was created by Bigmd
18 Jul 2016 13:49
Ok guys currently rebuilding a 79 KZ 650. It's not a complete motor out resto but a fix, replace , restore as I go build. I bought a swingarm off eBay to rebuild and have powder coated . It came with 4 bearings and I later found out it was from a KZ1000. The guy that's working on my bike said it won't fit. So I found another one on eBay from a 1977 650. I just got it today and it seems identical to the 1000. Is there a difference between the 2 of them? I also want to convert to bearings as it currently has bushings. I have the sleeve from the 1000 swingarm. Do I just need to order 4 bearings? Thanks in advance.
Replied by Johnno on topic KZ1000 Muscle Bike Build - ZRX Swingarm, ZX9R Fork
17 Jul 2016 16:01 - 17 Jul 2016 16:17
Johnno's Avatar Johnno
Ok, so I spent the day sorting through the rear sets on the bike. I had previously purchased a set from a CBR600, but when I got them home and looked at them on the bike, the foot pegs were arranged way too far back. So I ordered a set of aftermarket rearsets intended for a GSX-R1000, and they were much closer to what I was going for. I was able to use the master brake cylinder from the CBR set on the new rearsets, so that is a plus.
You can see in this picture the difference of where the foot pegs are located:
So my idea for mounting the rearsets was reusing the top stock footpeg mounting post as a standoff for the footpegs, and then making up a post that could be bolted to the frame through the frame reinforcement around the swingarm pivot bolt. Below is what came off of the lathe.
Next I chopped off the threaded section of the top footpeg mounting post:
And I drilled and tapped it for the correct screw.
Finally, I marked and drilled a 1/2" hole for the mounting post, and bolted it all together.
It ended up being nice and strong, I jumped around on it for a little bit, and it is definitely more solid than what the KZ had before. I may work up a small bushing to go over the original mounting post to make it look the same thickness, but that does it for now. The other side involves grinding off the rear brake mount, so I'll probably end up getting to that next weekend.
17 Jul 2016 06:23
Rear Swingarm
Next I went on to fit the ZRX1200 swing arm. The swing arm needed some slight grinding on the right hand side of the pivot point to fit in the frame, about 1/8" off. I'm also in the process on making an adapter to replace the swingarm pivot bolt, which I'll post when complete. Like others have found, the swingarm swap requires that you grind off the rear brake pedal mount and install rear sets. I'm currently machining a few parts for the rear set installation, so that'll come later.
I've got a Dyna 17" Street Bob rear wheel coming my way in the mail to replace the green mag, but this should be roughly the same wheel/tire size in the final product.
I think that is it for now. I'll keep you posted as things continue to progress!
17 Jul 2016 06:22
Front Wheel
The front wheel is from a 2013 Harley Dyna Street Bob. It has 25mm bearings, which perfectly match the zx9r front axle. I did eliminate the speedo drive for now, and plan to run just one front brake, though the wheel can run dual. I'm still testing the fitting here, but it looks like you have to run brake rotors with zero dish, which is what came with the wheel. I machined some axle spacers to get the wheel centered. I think it looks pretty good.
KZ1000 Muscle Bike Build - ZRX Swingarm, ZX9R Fork was created by Johnno
17 Jul 2016 06:21
Hello all!
Long time member, I just wanted to start a thread to share the project bike that I've been working on for the summer. The project is still going, and as I tackle some of the usual issues with these swaps, I wanted to share how I'm approaching them.
The bike is a 1977 KZ1000 A1. I started out riding on a KZ750 Spectre that I unfortunately crashed into the back of a truck that pulled out in front of me. While in the waiting room at the hospital, I paged through a local classifieds ads and found this bike. Immediately after getting discharged, I went over to look at the bike and ended up riding home with it.
The bike had never been in a pristine state, and was raced in the 80's. so there is a lot of non-standard work done on it. I put some clubman bars on it and rode it for a few years, but I always wanted to do some kind of suspension swap. I really think the KZ 1000 has a muscle bike look to it, so I'm going to try to play that up.
The plan:
- Swap in a front end from a 94-97 Zx9r
- Install a ZRX 1200 swingarm
- GSX-R1000 Rearsets
- Harley Dyna street bob spoked wheels
- New Exhaust
- New Seat
- New Wiring Harness
- Engine Rebuild (Winter project)
- Paint
So here it is at the starting point.
Replied by MAR on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
16 Jul 2016 18:16
MAR's Avatar MAR
Anyone have any leads for a new speedo/tach assembly?
I have a new one however both are failing big time.
I found an OEM one. However it is not in perfect condition.
Thanks for the help.
Myke
Displaying 961 - 970 out of 7255 results.
