Search Results (Searched for: gs swing arm)
Replied by galaxian on topic Need the gs swingarm pics
23 Mar 2006 11:52
Just to clarify
For a KZ650:
Swing arm pivot bolt = stock kz650
rear axle= GS1000
Rear caliper bracket = i drilled mine out or You could use a kz1000 one.
KZ and GS axle diameter is 20mm KZ650 is 17MM
Side note: If you swap this swingarm in onto a KZ650 it will lower the bike jsut a touch since the shock mounts on the swingarm are now moved back by about 1 1/2 inches. You will need a longer chain and a longer rear brake line. *** important *** if this is for a KZ650 make sure you have KZ1000 rear wheel spacers otherwise you cannot fit your wheel properly.
Post edited by: galaxian, at: 2006/03/23 14:55
For a KZ650:
rear axle= GS1000
Replied by donthekawguy on topic Need the gs swingarm pics
23 Mar 2006 00:03
Those are the ones. Now if I can remember to print them in the morning! Graveyard shift sucks!
Replied by 77KZ650 on topic GSXR Swingarm
22 Mar 2006 19:44
You can get just about anything to work, try doing a search here and in the archives for stuff like gsxr swingarm, or gs swingarm, or zx swingarm...stuff like that, Im building a 650 with a zx arm...
GSXR Swingarm was created by smoothsax
22 Mar 2006 18:49
Hi
I have a 97 gsxr swingarm that i wanted to put on a kz1000. Has anyone ever used this swingarm to do a conversion?
Replied by Shoe48 on topic Need the gs swingarm pics
22 Mar 2006 16:26
I tried to use the pivot bolt as an axle but it is to small in diameter .long enough though , uses the same nut as the axle . I had bushings made for each end of the swing arm .. What KZ pivot bolt did you use ?? I am now in the middle of drilling it all out to 20 mm with the larger bearings
Replied by baldy110 on topic Need the gs swingarm pics
22 Mar 2006 16:16
Heres my 2 cents. I used two 1/8" spacers on each side of the pivot point on the swingarm. I used the original KZ pivot bolt for the axle bolt because the GS arm is wider. I then used another KZ pivot bolt for the axle and since I did not want to swap out newer and bigger wheel bearings I simply turned down two spacers for the axle bolt to make up the difference in size between the GS axle holes and the KZ bolt. The KZ bolt is slighter smaller in diamteter than the GS axle holes. I then cut off the lower eyelet on my Fox shocks and welded on the GS clevis style mounts in their place.
kzrider.com/forum/viewthread.php?tid=11890
Replied by indykaw77 on topic Need the gs swingarm pics
22 Mar 2006 14:30
So swinger pivot bolt and rear axle bolt from kz will work.......??????????
22 Mar 2006 11:17Replied by Shoe48 on topic Need the gs swingarm pics
21 Mar 2006 19:48
all mocked up
i48.photobucket.com/albums/f245/shoe48/100_0513.jpg
21 Mar 2006 19:46
Pic is of my 650 . the shims go on each side of the swing arm pivot inside the frame ,, Make sure you clean up under the caps and grease the needle bearings , I used washers from the hardware store ,, it is a real nice fit ,, Baldy has better pics and dont forget to look in the arcives for past pics and info
i48.photobucket.com/albums/f245/shoe48/100_0501.jpg
Displaying 6931 - 6940 out of 7224 results.
