Search Results (Searched for: gs swing arm)
2001 gsxr swingarm on 74 z1 was created by Z1GSXR
07 Jul 2006 10:23
IS it possible to make a 2001 gsxr 1000 swingarm fit on 74 z1 and if so what all has to be done... and is it also possible to make it a monoshock using gsxr suspension? looked in other posts couldnt find anything to really help me.
Sarver
Sarver
Replied by timber on topic The Great Swing Arm Debate: GS1100E -vs- GSX-F750
07 Jul 2006 08:36
if your handy with a welder and and think outside the normal you can make anything work and fit. it takes time & money. now the gs swing arm has been done and spelled out really well by other here on the forum.
so do you want a weekend project that takes your basic tools or a winter project that will take some fabbing and thinking out side of your factory frame.
Replied by 77KZ650 on topic The Great Swing Arm Debate: GS1100E -vs- GSX-F750
07 Jul 2006 07:06The Great Swing Arm Debate: GS1100E -vs- GSX-F750 was created by KZKrayzee
06 Jul 2006 23:53
I reallly like the look of mpaquet4's mono swing arm! Can you tell me what the pro's
and con's:evil: of a conversion like he did involves and what the differences in performance are? That bike looks fun but I havent heard very much talk about that conversion! Which conversion do you perfer in performance and style?
KZK
if you want pics of mpaquet4's 78 kz650b mono swing arm, go to " kzrider.com/component/option,com_comprof...erProfile/user,5141/ ?"
'78 kz650c
NW 559
Whoo Hoo!
Post edited by: KZKrayzee, at: 2006/07/07 02:55
Post edited by: KZKrayzee, at: 2006/07/07 02:57
Post edited by: KZKrayzee, at: 2006/07/07 02:58
KZK
'78 kz650c
NW 559
Whoo Hoo!
Replied by KZKrayzee on topic '78 KZ650C Rim Swap Upgrade
06 Jul 2006 18:18
Now that I am a little more educated about this site, I have to apologize to all of you KZR Veterans! I just learned how to use the archives section and I can see that this topic is covered top to bottom! I found some crazy forums and some great points and tips! My wife laughs at me and now named my conversion quest "The Great Swing Arm Debate" because of all the differences in opinion. I couldnt help but laugh and share that with all of you! Once again sorry bout that, but dont shoot me... I shoot back ;-!
Happy Clutchings To U All!
78 kz650c
NW 559
Post edited by: KZKrayzee, at: 2006/07/06 22:16
78 kz650c
NW 559
06 Jul 2006 14:18
I have been hearing alot about the gs1100 swing arm conversion. I heard it was a pretty popular swap and the mods are pretty basic. Has anyone swapped out a stock kz650 swing for a gs1100? If so,how did the conversion go for you and how is the finished product? Any tips if I decide to go with a gs1100?
Replied by rstnick on topic '78 KZ650C Rim Swap Upgrade
06 Jul 2006 08:47
Welcome.
Try a search on this main site and in the archives.
GS1000/1100 aluminum swingarms seem to be a popular choice.
You can get a 130 rear tire on the stock set up.
Replied by StreetfighterKz on topic swing arm
05 Jul 2006 18:24
I took a mono-shock swingarm for a 86-88 Gsxr1100 and had some mounts welded on and the arm almost slid right in. I had to do some grinding on the back of the brake pedal mount but that was the only frame alteration. With the right rim/ sprocket carrier/ sprocket combo you should be able to run up to a 180mm tire. And if you want you can swap back to the original setup without anyone knowing.
Replied by timber on topic swing arm
05 Jul 2006 16:25
here is another
GS1100 Swingarm on eBay
Post edited by: steell, at: 2006/07/05 20:52
Post edited by: timber, at: 2006/07/05 22:32
Replied by Pterosaur on topic kz top speed?
04 Jul 2006 23:45
Hey - lookee what I found:
I recalled that I'd written up the top end post in Notepad, and sure enough, I had a copy of the post I made on the topic lying around:
Just in the interest of psuedo-scientific mis-information, I decided to conduct as reliable a top end test as I could muster short of finding a state trooper, flipping him off and playing a game of "catch me if you can" yesterday afternoon.
The setup:
1. Checked valve adjustment.
2. Did a compression check. 1/163, 2/157, 3/168, 4/161.
3. Installed a new set of points and condenser, set timing.
4 Adjusted cam chain tension.
5. Changed oil & filter.
6. Greased swingarm.
7. Checked tire inflation, set at 38psi.
8. Filled the tank to the *Idiot Level* with Sunoco 94.
The Bike:
1978 KZ1000C1A, 29,468 original miles, 1 year on fresh OEM rings, valve job, guides, seals, and entirely new cam chain/idlers/sprockets and guides. 15 tooth countershaft and 39 tooth final sprockets - stock gearing.
When the jugs were inspected at roughly 28,000, the bores were so clean and close to spec that we decided to go with a two-step bar and then ball hone, keeping the original pistons. The "acceptable" compression range is 155 to 185, and I figure that the ring-only installation is why the compression check readings were at the lower and of the scale.
The bike is equipped with the standard flat windshield, floorboards, saddlebags, crash bar and Vetter trunk box. The bags held about 30lbs of assorted tools among other things, The Vetter box held about 15lbs of assorted stuff; chaps, jacket, etc.
The bike is as plain box stock as can be found these days aside from the cop add-ons.
Me, 5"10', 225, depending on breakfast.
The course:
Two measured miles on a recently re-topped rural interstate - one to accelerate, one to measure. The end of the second mile shortly afterward lets off into a quickie off ramp - good for the possibility of getting lost were one to attract the wrong audience.
I've got a set of (originally) calibrated twin speedos that municipal judges thought were fair enough back in the day. One of the neat features is that inside the right speedometer is a solenoid that traps the needle against the glass when a switch on the right block is thrown - before mobile radar, a motor cop would follow some scofflaw, then flip the switch and lock the right speedo.
I also have one of those little digital clocks with an elapsed second readout stuck to a piece of velcro on the windshield frame. Using the 3600D/T = S (3600 (seconds per hour) multiplied by number of miles (1) divided by number of elapsed seconds T = speed S gives the timed mph.
Then there's the odd bit of serendipity; while topping up at the Sunoco, what happens along but 2 guys, one on a CBR600, another on a 2005 ZX-6R. They pulled up alongside the next pump and exchanged pleasantries.
"Don't see many of them. Is it fast?" ZX asked.
"Funny you mention that - I'm about to find out."
That got their attention. In the course of a short conversation, they decided to get in on the fun. The plan was modified such:
They were equipped with walkie-talkie cells, so CBR would get out ahead on the overpass on the exit and keep an eye out for troopers while ZX kept pace with me on his digital speedo. We'd do a last check and then start the run. If any Barneys showed after the run started and we made the exit ramp, scatter in 3 directions became the plan.
Out on the berm at the start, we did a final check with CBR. No Barneys. About 2 minutes later, ZX-6R and I pulled up on the ramp to meet CBR600.
My right speedo needle was stuck on 112 when I flicked the switch. 6R said he'd been reading between 100 and 114 during the run. I clocked 33 seconds, which by the formula comes out to 109.9. The truth is right in there, somewhere.
So how does that compare to a street stock KZ900?
Well, without getting NASA involved, we can come relatively close using some engineering approximations.
The biggest single source of drag on a "C" model cop bike is that big 'ole barn door of a windshield. The bags add some, but less than you think because they exist in what's called "turbulent flow" at the rear of the bike. The Vetter box may in fact offer an aerodynamic advantage because it extends the faired area well behind the rider, delaying the formation of a low-pressure area in the slipstream. If you've ever watched "Mythbusters", there's an episode where they found that fuel efficiency was actually improved by leaving a pickup truck's tail gate in the *raised* position. Same principle applies here.
In order to get a number for the horsepower penalty imposed by the windshield, we have to find a number known as its *co-efficient of drag*, or CD. It's roughly 3 feet by 2 feet, or 6 square feet in area.
The Cambridge University Fluid Dynamics lab has a neat little program that will approximate the windshield CD by substituting a cylinder 2.5 feet in diameter for roughly the same surface area. In air, at 160.23 feet per second (109mph), an aerodynamic drag value 32.893 pounds per foot of length is generated at a CD value of .04102.
Plug those numbers into an Aero Drag calulator and 6 square feet of frontal area at a CD of .4102 at 109 mph, and the horsepower penalty of the windshield comes out at 21.2.
Shuckey darns. The last few paragraphs are missing.
The upshot of the missing part was that because *"...dynamic air pressure is proportional to the SQUARE of speed, the horsepower to attain that speed goes up as the CUBE of that speed change."
In other words, if a stock KZ puts out its rated 82 horsepower at 123mph, if all other factors are equal, it'd have to be putting out in the neighborhood of 110hp to wind her up to 145mph.
That bit of mental arithmetic bears out when you read Lorcan's posted numbers - last I saw, he was seeing 198mph at 230hp. The ratio of increase in speed to horsepower gain isn't linear - it's logarithmic.
And there you have it...
*A concise discussion of horsepower and drag measurements:
pweb.jps.net/~snowbum/hpcalc.html
Post edited by: Pterosaur, at: 2006/07/05 03:53
The setup:
The Bike:
The course:
Displaying 6801 - 6810 out of 7224 results.
