The Great Swing Arm Debate: GS1100E -vs- GSX-F750
- KZKrayzee
06 Jul 2006 23:53
I reallly like the look of mpaquet4's mono swing arm! Can you tell me what the pro's
and con's:evil: of a conversion like he did involves and what the differences in performance are? That bike looks fun but I havent heard very much talk about that conversion! Which conversion do you perfer in performance and style?
KZK
if you want pics of mpaquet4's 78 kz650b mono swing arm, go to " kzrider.com/component/option,com_comprof...erProfile/user,5141/ ?"
'78 kz650c
NW 559
Whoo Hoo!
Post edited by: KZKrayzee, at: 2006/07/07 02:55
Post edited by: KZKrayzee, at: 2006/07/07 02:57
Post edited by: KZKrayzee, at: 2006/07/07 02:58
KZK
'78 kz650c
NW 559
Whoo Hoo!
- 77KZ650
Re: The Great Swing Arm Debate: GS1100E -vs- GSX-F750
07 Jul 2006 07:06
07 MDP Rookie of the Year
- timber
07 Jul 2006 08:36
if your handy with a welder and and think outside the normal you can make anything work and fit. it takes time & money. now the gs swing arm has been done and spelled out really well by other here on the forum.
so do you want a weekend project that takes your basic tools or a winter project that will take some fabbing and thinking out side of your factory frame.
- KZKrayzee
07 Jul 2006 11:05
Those are good points. I am looking for some more hands on advice. Has anyone outr there done this conversion? Has anyone rode on a bike with the Katana swing? If so, how was the performance with the mono compared to the dual? For those who have done this conversion, if I do decide to go the Katana route, what trouble's should I lookout for? Thanks for the advice!
- timber
07 Jul 2006 11:29
i have something in the works right now. in another week or two i will be ready to cut, weld, fab, curse, bust some knuckles and do a different swing arm set up that hasn't been done here. it should go pretty easy. i let to much out of the bag already. keep a eye out cuz i will start soon.
- KZKrayzee
07 Jul 2006 11:56
I am curious as to what braking system is best to use with a gs1100 conversion. I am a little uneducated on this topic. Can I only use the gs1100 rear brakes or is keeping the current system an option? What works best?
- timber
07 Jul 2006 12:11
the simplest way to go in my opinion ( you know about opinions) is to use your stock kz650 rear disc caliper with the gs1000 swing arm. the axle hole is 17mm and you need to drill that out to 20mm (about 3/4") that way you save some $ not switching what you already have. now if you can get a gs rear end complete, swingarm, axle, wheel, brake caliper, etc that would be easy. if you go with a kz1000 rear wheel it matches what you have already and can be found around here pretty easy. i looked into switching out the wheel bearings from my 650 so i could use that rim. well the bearings along cost way more than a kz1000 wheel.
so there is my humble opinion.
- KZKrayzee
07 Jul 2006 14:56
So your saying I can use a 82 gs1100e swing, a 82 kz1000 rear wheel and I can stick with my stock brakes? I know where I can find all of these parts! Just want to be sure before I spend my money!
- timber
07 Jul 2006 15:57
yep, its all been done by others here. look in the archive for the gs1000 that is what galatica did.
- KZKrayzee
07 Jul 2006 16:07
Great! I am looking forward to this project now with confidence! After this portion is completed I will concentrate on the front end! Any suggestions on whats been working for the kz650?
- timber
07 Jul 2006 16:19
i havent done anything with the front end yet. i have heard that the gixxer front ends work out with the least amount of work into them and a zx front end if you chnage the stem out it works. that is from the threads that i read here have said.
- Shoe48
- Live each day as it is your last
07 Jul 2006 16:27
The GS1100 swing arm is an easy swap on the 650 .. If I did it anyone can ,,,
