Advanced Search
Search Results (Searched for: gs swing arm)
Replied by SWest on topic Hardtail back to shock conversion ext Swingarm.?
27 Aug 2019 20:08
SWest's Avatar SWest
You can move the shock mounts to raise the back end and I suspect they cut or put shorter springs in the front end. Is the frame raked? Pics of the steering head would help.
Replied by Forrest on topic New Owner of KZ650
23 Aug 2019 16:13 - 23 Aug 2019 16:27
Forrest's Avatar Forrest
You are welcome anytime Lakshan. And appreciate your compliment on my 650. We have the same year, so hopefully we can exchange some ideas as you progress through your new bike.
One other item that may have been covered but worth mentioning again; Did you get the Owners Manual with your bike? And, you may want to get a Service Manual on this specific model. They are out there. If you need one I will check to see if I have a spare.
One item I did not mention would be:
Suspension - The front fork fluid likely needs replacing. There are various weights/thickness of fork oil. There is likely a thread around here somewhere or post your questions here. My bike was prone to tank slapping at high speed before the fork springs were replace with stiffer Race Tech units for my weight. The rear shocks were barely adequate for the day when new. I replaced mine with a pair of Works Performance and love them. The stock rear shocks made the bike weave and even wag when running fast in sweeping curves. The new shocks eliminated this. It is now on rails when up to speed. What I am saying some of the first upgrades worth doing are for the chassis. BTW, I worked with the Works Performance engineer to make the correct length shock for the 1977 KZ650. It's swing arm is a different length than later models. The result were shocks that truly fit the bike. If you order be sure to let them know they have produced another.
As you can see, there are a lot to items to consider for something that appears quite simple. Best advise is get it refreshed and think about what you might want to do with your bike. You can customize from there and make it yours.
Replied by Kofla on topic Looking for a swing arm to fit a custom KZ 650B frame (noobie)
18 Aug 2019 19:58
Kofla's Avatar Kofla
z1kzonly wrote: You should have plenty of resources over in the UK.
Find a custom, fab, cool (TV show style) shop to help you out.
Dime City, Legends, Ace. Even ask The Harley Guys! Business is money.
Go with the GS 1100, Or GSXR your cheapest alternatives. I have a picture with dimensions in inches of a GS 1100 Suzuki swinger here.
Give you the basic idea size.
Thank you for posting this image, it does answers most of my questions.
Replied by baldy110 on topic 76 KZ900A rescue / project
17 Aug 2019 13:50
baldy110's Avatar baldy110
While waiting for the frame to get back I scrounged up a 1982 Suzuki GS1100E swingarm. Cleaned it up and found out the finish was in really bad shape so I sent it to the powder coaters for an aluminum finish.
[IMG
[IMG
[IMG
[IMG
[IMG
Replied by Scirocco on topic anybody measure swing-arm bushing using rear axle end-play?
16 Aug 2019 16:50 - 16 Aug 2019 17:12
Scirocco's Avatar Scirocco
You Need new swing arm brass bearings!!! (upgrade to needle bearings). What bike do you talk about?
Time to turn my kz1000 into a resto mod. was created by Bulletkz
07 Aug 2019 08:24 - 07 Aug 2019 08:25
Bulletkz's Avatar Bulletkz
I got all the bugs worked out on my 80 kz1000 so I bought a zx7 cheap and I'm collecting parts for the build.
Swapping in the front end and rear swingarm with the mono shock.
Glad there is so much information on what I need on here.
1983 KZ650 / CSR now GPz 1-off was created by Uncle Freddy
27 Jul 2019 08:47 - 27 Jul 2019 10:26
Uncle Freddy's Avatar Uncle Freddy
almost there on my full restore of my 650, which I have owned since new in '83 ....once over pistons & rings, GPz 750 cams, APE valve guides & springs, Barnett extra plate clutch, Earls cooler / steel braid / ANs, steering damper (adjustable), ATK fork brace, Supertrapp, Sproket Specialists front & rear, rear turn signals chopped & tucked in tight, front turn signals mounted on headlight sides, Spectre tail light, rear fender chopped 6.5 inches, chromed: side cases / crankcase breather cover / rear foot peg mounts / starter cover / oil fill cap / bars brackets, racing bars, DID Pro Street 530 chain; all new swing arm & steering head bearings, new fork seals & oil, Dyna coils & hi-per wires, all new spokes & show polish on the factory DID cast aluminum wheels, CR smoothbores, Japan after market shocks, all new igniter / rectifier / ignition / relays / fuses / battery ......know I am leaving some things out !!! (note level of lay-down ability via foot peg grind downs, it loves mountain & back roads) .....color: Ferrari Fast Red ....will post finished pics & vid in the not too distant
Attachment not found
Replied by Zilla on topic Kz 1000 police piston rings
22 Jul 2019 08:33
Zilla's Avatar Zilla
I’ve seen where ppl change the front forks and swingarm to mono , it looks good but I’d rather put my money in the engine and get it healthy.
Shock absorber suggestions wanted was created by nhsteve
16 Jul 2019 13:38
nhsteve's Avatar nhsteve
After a pretty extensive rebuild of a '78 KZ1000 LTD last winter, I have been able to get it out and riding it a fair bit. Really pleased with it (it is essentially standard) so far. As a bonus, we have found that my wife enjoys it on the back as well (she hasn't always said this about other bikes I've had, so this is a good thing!).
During the rebuild, I stripped, flushed, and rebuilt the forks (well, cleaned them inside and out in the wash tank, and replaced the seals/wipers and fork oil. As a start. Taper rollers in the neck, renewed all 4 needle bearings in the swingarm, new tires/tubes, etc.
Yesterday found me on a short section of dirt road. I am not afraid of them at all. Actually kinda look for hem as they can be interesting. But the potholes really upset the 40 year old Boge Muhlholland shocks, so I am thinking of replacing them.
My question is : what are other members using for a GOOD quality shock? I see links for Progressive and IKON (have had them both). Never tried Hagons but can't seem to find a dealer. Ohlins and Race Tech & some others may be more $$ and probably more than I need.
I can see myself going to cartridge emulators at some point, but the back end really posted me a couple times on a couple of kind of minor potholes.
Suggestions?
Replied by SWest on topic Clutch nut removal
15 Jul 2019 09:51
On mine it's a R/H thread. I have the tool against the foot pegs. Looks like it can slip off the swing arm pivot bolt. Best to use a 1/2" ratchet and a cheater bar or torque wrench. Impacts can be dangerous.
Displaying 551 - 560 out of 7254 results.
