Advanced Search
Search Results (Searched for: gs swing arm)
Replied by KraZyRIDER on topic what did you do to your bike today?
18 Jun 2012 19:01
KraZyRIDER's Avatar KraZyRIDER
531blackbanshee wrote: nice to see it up on it's own two feet sir :evil: !
...hahahaha, cute!
...once I get the rear brake bit situated, I'll send the frame out for powder coating. Then I can start for real.
...eh, I'm not really in a rush with the other bike sitting there, so I want to do it right.
...mocking it up I've already figured out that the tank needs to be moved back 1/4 of an inch for front end clearance. I also found out my legs are a bit long for the mid size 650. I'm going to need to move the rear sets a bit further back than anticipated. But, hey, that's why we roll 'em, first!
...the swingarm looks great. Thanks again! :)
Replied by uneasy_rider on topic GSXR swingarm questions.
18 Jun 2012 15:33
uneasy_rider's Avatar uneasy_rider
Thanks, alot of good info on there. We are doing quite a few of the same mods. Plan on starting my own build thread as soon I get a little further along.
Replied by gravit8 on topic TIRE TALK - when the rubber meets the road
18 Jun 2012 04:35
gravit8's Avatar gravit8
faffi wrote: Not normal. Things to check would be tyre/rim runout, air pressure (at least 36 PSI in the rear, can go as high as 42), wheel alignment, steering stem bearings and swingarm bearings.
Bike rode well on the old tires, I haven't changed anything on the steering stem or swingarm bearings aside from installing the rims, everything went back together without any issues AFAICT. Hoping it was just an over-inflated front. Seemed like the bike settled once I was in the usual left/right groove on the road, changing lanes and riding the center crest was what gave me the 'wobble'.
I'll update soon. Waiting for an accurate tire pressure gauge and some other stuffs
Replied by faffi on topic TIRE TALK - when the rubber meets the road
18 Jun 2012 04:23
faffi's Avatar faffi
Warning: Undefined variable $end_tag_params in /home/kzride5/public_html/libraries/kunena/External/Nbbc/src/BBCode.php on line 2298
Z1B project almost done was created by Move0ver
17 Jun 2012 16:34
Move0ver's Avatar Move0ver
greetings all,
Just about done with my Z1B.
The day I got it:
How it sits now:
and here's whats been done:
-Dual front disk conversion with braided steel brake lines
-Rebuilt front forks (with aftermarket damper rods)
-Rebuilt wheels with Alloy rims (Akront)
-mulholland shocks
-Full Dyna makeover
-Fresh clutch
-New Carb boots and balanced and rebuilt carbs
-Needle bearings in tree and swingarm
-Kerker exhaust
-Fork brace
-Clipons
-Tarrozzi Rearsets
-Knoscher Half-Fairing
-Corbin Gunfighter
-Fresh paint (the tank and seat are the same moro blue as my S4 in the background)
Things left to do:
-Swap out the rear tire for a better one (I have an 18x3.00 spitfire that I've been meaning to put on)
-Brace the fairing a little bit more
-Sort out the front brakes rubbing
This last one is my biggest thing... The brakes work fine however the pads don't fully retract and ever so slightly rub on the disk. I had taken the brakes apart and done a quick rebuild... but I may have to do a more thorough rebuild. First however, I'm going to see about wire wheeling the paint off the outer edge of the pads to see if that does anything. Otherwise, is anyone out there selling a pair of Z1 front calipers? :)
Any help would be much apprecitated
Green Ghost was created by Proxy
17 Jun 2012 15:27
Proxy's Avatar Proxy
Ok finally got some time.
My father and my uncle were in love with the KZ650. So much so that they spirited away a couple of bikes and a bunch of parts. Both had the intention of resurrecting one from the ashes of both. They wanted an original green one. Both have passed from this mortal garage but their project is now underway. Only one frame was titled and contained a very shot engine with a very crispy wiring harness. The other has a nice engine with 16x miles and a great harness. I also have a pretty good completely stock exhaust, a set of Lester Mags, a Derale oil cooler and a lot of other bits and pieces. Just before he passed my father picked up a set of bodywork in original green in very good shape so the project begins.
I rolled out the titled frame and I don't know why but decided to get the wheels sorted out. I pulled the Lesters and slapped a nice set of Avon Roadriders on them. New brake shoes, progressive rear shocks and wheel bearings and she is a rolling chassis. The swing arm seems fine but I am contemplating just changing that bearing too. I also want to make sure the steering bearings have been updated too but might wait until I get some progressive springs for the forks.
The headlight and ears had taken a ding and were tweaked so I got a set of universal holders and a old Suzuki small headlight was fitted. I'm not sold on it yet but for now OK. Had a set of handlebars in the larder to replace the bent ones. Also a set of small LED blinkers. So here it is as it now sits. I will soon swap the powerplants and wiring. Then clean up a set of carbs and fit the exhaust. Don't hold your breath as I am slow and busy. But it will be done by summers end. I'm lucky I have a 81 650csr bobber to play with while she gets done. Just thought I'd stick a placeholder here for now. Enjoy your rides and ride safe. Wish I had my father and my uncle here to bust my chops and prod me along. Later...
They should really sell this green again. It really is beautiful.
Replied by 341 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
17 Jun 2012 11:49
341's Avatar 341
Maybe the wife wants it out of the backyard because it attracts chicks and she gets jealous. In case that isn't what's happening, shoot him in the leg for me too. Troy341
Replied by tk11b40 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
17 Jun 2012 04:05
tk11b40's Avatar tk11b40
Troy,
Mr. Dave is trying to break my heart with the other bike sale.
I am going to need to shoot him in the leg now.
Replied by porchev914 on topic GSXR swingarm questions.
16 Jun 2012 23:29
porchev914's Avatar porchev914
There are many that I have read, but this was the first to pop into my head. Donor bike was an earlier 90's GSXR 750 I believe, but shouldn't be much different. The concept is identical.
kzrider.com/forum/11-projects/340793-tes...kz1000-fighter-build
GSXR swingarm questions. was created by uneasy_rider
16 Jun 2012 22:27
I have been scouring the buidls threads, but cannot find what I am looking for. I am installing a 01 GSXR1000 swinger on my 1981 KZ750 and am wondering what everyone has done to the pivot area to mate the 2 up. I am wanting to use the stock pivot bolt and have a few ideas, but would like to see what the guys on here have done. Thanks
Displaying 2791 - 2800 out of 7260 results.
