Advanced Search
Search Results (Searched for: gs swing arm)
Replied by scubaanders on topic Who can resist a non runner? The Orson Welles project (1984) Gpz1100 1984
11 Nov 2021 10:03 - 11 Nov 2021 12:08
scubaanders's Avatar scubaanders
So the frame was now in the way, busting the frame or bending the axle was not an option!
But as the saying goes, when things doesn’t fit revert to old methods.
Brought old the old file and went the Millyard route, marked up where the swing arm hit the frame, and as the swing arm outer tube has some good +5mm of goods I went down.
Took of a good 2,5mm at the thickest point on both sides.
Then it fits and thats how Clearance came to be, if someone ever wondered.
That’s when I realized that there was something wrong with the ZR-7 rear wheel and the ZXR rear brake caliper, they just didn’t really like each other. . . . . . .
//Anders
Replied by Wookie58 on topic 82 kz1000 ground up build
08 Nov 2021 07:02
Wookie58's Avatar Wookie58
Nice project, you may want to consider setting the motor further back. I know someone who had an early GSXR1100 motor in a Harris that was built for a Z1000 motor. The front sprocket is so far ahead of the swing arm pivot that you will need to run the chain loose to avoid the suspension movement being affected as the swing arm goes past level (the longest point)
Replied by calum on topic 1977 KZ1000 Restomod
02 Nov 2021 14:36 - 02 Nov 2021 14:40
calum's Avatar calum
Trying to get the exhaust mount sorted. The original A1 mount is about where the orange dot is in the picture below. The red dot is where I'd like to put it if I stick with the current exhaust. I may end up going for a Kerker - if so it will be the KZ1000R model as I can get that a bit cheaper. Hindle is also still on the table (appears they have one version for all models A, MKII, J, R, GPZ1100).
I would like to weld the original exhaust bushing to the frame using some smaller diameter steel tubing (about 1/2" or 3/4") - the green lines in the photo. I want to get it located so that it works for all exhausts and it seems like the R or GPZ1100 mounting point will work with all systems (I have a bit of leeway with the current system as it's just held with a clamp). Can anybody tell me where the mounting point is on these bikes? Either relative to the points marked in the picture or, better still, measured relative to the swingarm pivot and another point on the frame (bear in mind there isn't much in the way of fittings left on my frame).
Replied by azman857 on topic An '82 KZ 750 LTD saved or Damn FB Marketplace!
31 Oct 2021 21:00 - 31 Oct 2021 21:01
azman857's Avatar azman857
Seems in good shape. No dents. Even the exhaust pipes are in good shape for being almost 40. I'm not too worried about rust as we are in southern Arizona. I should still look it over though. Thanks for the reminder.
The only history I know of on this machine is it was bought by the shop for partlng out in 2008. Coils and rear master cylinder and clutch and front brake levers were missing and the rear fender was minor dented. Starter is missing too.Other than things being dried out the bike is in fine shape and under my care, getting better. Today the swingarm bearings got lubbed, wheel bearings on the rear wheel got new grease.I think I found the source of a clunking sound, maybe. The chain was missing an outer plate at the masterlink! The engine is in gear and I haven't been able to fine nuetral.
Replied by larriken on topic Kiwi GPZ
26 Oct 2021 19:24
larriken's Avatar larriken
Nice work Larriken!
Just wondering  are you using the ZZR or the Gpz pivot knuckle and what hole distances did you put on your dog bones? Also a bit curious on your swing arm bolt bushing, got some measurements?
/A
Apologise for the delay in replying. I am terrible at checking on the forum! Knuckle was a parts bin surprise and I have absolutely no idea what it was from. I will measure the distances from the hole centres for you tonight if that will help. Dog bones were cut with the taller ride height eye to eye distance of 145mm and the lower was 160mm. When I whip the swingarm out next I can measure the swingarm bushings for you.
Replied by DoctoRot on topic Non o-ring D.I.D. K series chain
21 Oct 2021 11:23 - 21 Oct 2021 11:26
DoctoRot's Avatar DoctoRot
I have found its a false economy to buy cheap chains and sprockets as they typically wear much faster than higher quality items.  Unless you are drag racing there is really no need for a roller chain. Look at the chains top tier racers are using - all x-ring or some variant.
One guy being vocal on the internet does not mean much, if it were many people than it would be worth considering. Even cheap chains are incredibly strong and for it to fail catastrophically in that amount of time points to something else going on. Particularly since the guy claims he has been hot-rodding the bike and more explicitly the chain heating up is a clear sign of over stress.
If you have longer than stock shocks you need more chain slack. if he set the stock chain slack, or too little chain slack for that matter, and had overlength shocks (fairly common when hotrodding) that would put an incredible amount of force on the chain as the suspension compressed as it has nowhere to go. This will break chains or destroy transmission/wheel bearings in a very short amount of time, no problem. I have 2" over shocks on my KZs and the only way to properly set chain slack is to remove the shocks and tighten the chain until you feel pressure when moving the swingarm through the tightest point of its travel. then back it off a little. the overlength shocks make the chain appear to be loose by normal standards when the bike is sitting, however this is correct slack for swingarm angle. I then document the slack measurement and use that as the min slack amount in the future.
Other variables could have caused/contributed to chain failure:
Was the master installed properly? so many people F this up and over rivet the master or install the master clip the wrong direction.
are the sprockets aligned? did he buy the right sprockets?
Point is  - spend an extra $40 and get a good x ring chain. it will probably last another 20 years.
Replied by MauiZ1 on topic 1973 Z1 Maui
17 Oct 2021 11:15
MauiZ1's Avatar MauiZ1
Fasteners have been a real issue, hardly any were correct and I’ve had to decide how to proceed. The PO had a mix and match assortment on it, hardly a single original fastener save for things like the swing arm, axles and a few others. I’m having to replace my caliper fasteners due to some damage to them. All this has made for an expensive project. Since I’m here on Maui I’ve decided that easy to change fasteners will be stainless such as those you mention. Corrosion is practically an overnight thing here and if I’m going to ride this I would like to not fight it so much, hence the stainless spokes and nipples. Zinc spokes go very quickly here. So no, the bike won’t be purely correct.
I will install the lower part of the engine and then assemble the top end. My K3 750 Honda I did the frame lowered over the engine method, it worked well. I’m trying this two step method on the Z1 because it seems pretty straightforward. I hope I’m right.
I do have a mystery. I was cleaning up and I found the round rubber or plastic part in the pictures. It looks like I may have left something out of the carbs but I’m not finding any parts that look like it. I thought it was Collar B 16073-003 but images don’t really match. Anyone have any thoughts? I may just take the carbs apart and look.
Replied by Jahimbi Blammo on topic 1982 Kawasaki KZ1000 LTD and CSR build
14 Oct 2021 15:24
Jahimbi Blammo's Avatar Jahimbi Blammo
SO NOW THE FUN PART!
Time to start reassembling the bike!  This is always my favorite part getting to work with like new parts.  Nice and clean, easy to work with...just a fun time!
I have all the parts back from my powder coater and vapor blaster so I can start reassembling the bike and really determine what look I am going for.  I had both frames done - the textured coated one is the LTD I originally purchased.  The gloss coated one is the CSR I purchased as a parts bike.  I'm definitely  going to use the textured LTD frame and swing arm.  All new All Balls Racing bearings for the bike.  The wheels are at a shop getting fresh tires mounted  as I type.  Next step is to rebuild one set of forks and assemble a rolling chassis.
I CANNOT FIND A STOCK PISTON FOR THE ENGINE AND IT'S KILLING ME!  I need a piston to re-assemble the engine.
10 Oct 2021 12:18 - 10 Oct 2021 13:36
So now it’s time to try to fit the ZZR1100C swing arm.
The Gpz1100A2 frame is 260mm over the pivot, the swing arm is 252mm over the pivot and the swing bolt is 18mm in diameter. The missing 8mm is taken up the indented spacer and the swing bolt.
The ZZR1100C swing arm is 256mm over the pivot, 262mm over the pivot tube inc the spacer and the swing bolt is 20mm in diameter so some shaving of the swing arm is necessary.
I took 2mm of each side of the swing arm using a good old file, much like Allen Millyard and then refitted the seals.
Now the spacer on the right side also had to sacrifice 2mm to flush with the swing arm seal.
Even the pivot tube that now is protruding a little bit too much on the left side also has to take a beating in the lathe. I was I bit reluctant to try to shortening it in our lathe as the pivot tube was too big for the head stock and the pivot tubes are usually hard as hell and a bitch to turn in the lathe. But I had to give it a try even though it protruded in a scary way. Low and behold it was not bad and it didn’t judder even though I was cutting with inserts made of chineseium.
Then the swing arm can now be wiggled in to the frame and I could hang it up on the original swing bolt.
Looking at it, I guess I can just as well make a new swing bolt from a centerless axle instead of making a sleeve to make up the missing 2mm on the swing bolt.
With the Swing arm in place, I tried out the ZR-7 rear wheel. It’s not a perfect fit. It might be because I fitted a hanging brake caliper holder, as I am planning to use a brake caliper from a ZXR400/750. So spacer will need to be fabricated but first I need to center up the wheel in the frame and make sure that the chain will line up.
But before that can be figured out, the new swing bolt has to be fitted to make sure that the swing arm is fixated.
Except for that, the GSX-R600 K1 front brake caliper also showed up in the mail, that’s a given as I know that they works on the Zephyr 1100 forks. I just need to source two brake discs and turn out the top-hat spacers on the lathe in order to handle the M10-M8 caliper bolts and disc spacing situation.
Next up is the suspension linkage and figure out what shock and dog bones to use. I have got these from a GSX-R 600 wonder if they will work?
/Anders
Replied by Robb2018 on topic My 73 Z1 all done
02 Oct 2021 12:29
Robb2018's Avatar Robb2018
It looks really nice!
I saw a couple of things you may want to do.  First, the swingarm bolt goes from right to left.  The nut should be on the left side.  Second, there should be two cable ties on each side of the bars.
  Just switched the swing arm axle around.  It did shift because I couldn't find anything close to the diameter of the axle to hold it in place but it was easy enough to move the arm around to line it back up again.
Displaying 271 - 280 out of 7254 results.
