Father and Son 77 kz650b1
  • GollyGee
  • GollyGee's Avatar Topic Author
11 Jul 2021 06:35
#851559
Hi Everybody,  New guy here, new to older Kawi's but not to bikes or cars.   My son picked up a new z900rs earlier this year and wanted a project (cafe or brat). We found a 77 kz650 b1 in incredibly complete condition,  only thing missing is the rear brake switch.  So instead of a cafe or brat it's a restoration- the bike is way too complete and original to chop!  22000 kms!  There's a few things that need replacing due to age though. The guy we bought it from says it was an estate barn find and he was going to restore it (he even had the carb rebuild kits)but lost interest and was moving.   We have cleaned  the carbs ultrasonically,  rebuilt with said kits, restored the left and right handlebar switch assemblies, tested the ignition system and gave it a thorough cleaning.  Compression is good 120 across all cylinders.  Now we're  waiting for intake boots, flasher,  fork seals and boots, and other small items.  Thanks to all of you for a great resource for these old machines, without it many great bikes would be scrapped.
  • Nessism
  • Nessism's Avatar
Re: Father and Son 77 kz650b1
11 Jul 2021 10:22
#851564
Welcome and enjoy!
Be sure to check the valve clearances straight away.  The clearance reduces with mileage and once it's all gone the valves will hang open and carbon up or even burn.
Also realize that the huge majority of problems people have with getting an inactive bike back on the road traces back to incomplete carb cleaning.  There is a lot more to restoring the carbs than replacing jiet (which are often the wrong sizes when purchasing "carb kits") and performing a basic cleaning.   This tutorial is for Suzuki Mikuni's but it's basically same for KZ VM carbs... members.dslextreme.com/users/bikecliff/i.../vm_carb_rebuild.pdf   You might want to read through to see if there is anything you missed.
  • GollyGee
11 Jul 2021 10:52
#851566
Thanks for the link and tip on valve clearances. I own a couple of old Yamahas that require the occasion carb clean and they are really sensitive about cleanliness.  These carbs were in relatively good shape besides some varnish.  We checked/ measured all parts from the kits vs the installed parts.  These carbs don't appear to have been disassembled before.  We have a valve cover gasket on order.  I think it's better to have one on hand before disassembly.  Waiting on a lot of parts on order, there's quite a bit to do before it's rideable, front and rear brakes- I don't trust 44 year old brake shoe lining adhesive,  rebuild master and caliper, brake hoses, we need air box boots, rear brake switch, turn signal flasher, chain and sprockets, fork seals/ clean and rebuild,  steering head bearing clean and grease,  swing arm bearings clean and grease.  It's in amazing condition overall but there's safety items that I can't help but replace and or service before going around the block even.  I'll post some pics once I'm allowed to.   Thanks again!
  • TexasKZ
  • TexasKZ's Avatar
11 Jul 2021 11:08
#851568
Welcome aboard!
If you have been lurking around here long, you know most of the members are picaholics. A project thread with plenty of pictures will help feed the addiction………
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
11 Jul 2021 12:57
#851578
Welcome and thanks for keeping the sawzall away from it!
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
13 Jul 2021 19:02 - 13 Jul 2021 19:02
#851705
Welcome to both of you.
Looking forward to your project.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 13 Jul 2021 19:02 by rstnick.
