Advanced Search
Search Results (Searched for: gs swing arm)
Replied by 531blackbanshee on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
30 Jul 2014 06:11
531blackbanshee's Avatar 531blackbanshee
very nice!
Replied by tk11b40 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
29 Jul 2014 21:32
tk11b40's Avatar tk11b40
So many details !!
29 Jul 2014 21:31
29 Jul 2014 21:30
29 Jul 2014 21:28
The bracket bolted to two bosses already on the underside of the top clamp, works.
So with my little band saw, and small drill press and a couple hours with a file I finished the bracket. Then I milled a slot in the bracket so that the wires from the tach and speedo had a neat place to go. This also lightened up the bracket considerably.
I had to saw off the ignition switch boss from the Suzuki top clamp, so much massaging was needed there. Now the whole set-up looks like the factory did it.
Next I will have both the bracket and top clamp powder coated satin Black.
Replied by 650ed on topic Steering Stabilizer?
29 Jul 2014 19:42 - 29 Jul 2014 19:43
650ed's Avatar 650ed
For your steering stem use tapered roller bearings. Here's the All-Balls kit:
www.allballsracing.com/22-1014.html
Dr. Gamma is correct about the swingarm. Here's the diagram:
Attachment 00006_2014-07-29.jpg not found
Replied by Motor Head on topic Steering Stabilizer?
29 Jul 2014 19:12
Motor Head's Avatar Motor Head
I'll add Fork Brace. This is the single most improvement I made on the front end of my 82 KZ1000 LTD.
Upgraded springs, emulators, new internal bushings, of course seals and oil for the forks.
New stem bearings, with the correct pre-load.
Swing arm bearings, and you can under brace it easily if you can weld.
Rear shock up grade. Well I bought a set of progressives, one failed rather quick, out of warranty and not rebuildable. So I went with a set of Fox Racing Shocks off of a snowmobile. No problems so far, and $100 bucks shipped, fully rebuildable and tunable. Lesson learned. ;)
Replied by 531blackbanshee on topic Mono shock conversion on kz1000
29 Jul 2014 14:24 - 30 Jul 2014 05:50
as turboking said.
i have custom machined tophat bushings to take up the difference on the swaps i have done.
these are on a zx6r swingarm to kz.
Replied by Dr. Gamma on topic Steering Stabilizer?
29 Jul 2014 12:16
Dr. Gamma's Avatar Dr. Gamma
Now that I think about it, the '77 KZ1000 already has two needle bearings in swing arm stock. I think the '78 had four needle bearings (two per side) in the swing arm. No need for the bronze bushings.
Check the amount of play between the frame, and the stock swing arm bolt. If its over a few thousands thats too much. I had my local machine shop make up some oversize swing arm bolts to take up that extra clearance. I had to tap my swing arm bolt into the frame. I then honed the stock inner swing arm sleeve to fit the new oversize swing arm bolt. I left just enough clearance for just a coat of grease on the bolt.
If you have 15 or 20 thousands play at the swing arm bolt to frame. Just think how much play you will have at the end of swing arm!!
Replied by kzdcw on topic Steering Stabilizer?
29 Jul 2014 11:50
kzdcw's Avatar kzdcw
Dr. Gamma, That's the direction that I'll probably take. I have a set of bronze bushings and sleeves from a H2 project that I didn't use. I'm pretty sure they will fit the KZ1000 swing arm or would you happen to know?
Displaying 1801 - 1810 out of 7258 results.
