Search Results (Searched for: gs swing arm)
Replied by tk11b40 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
10 Aug 2014 02:37Replied by tk11b40 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
09 Aug 2014 22:55Replied by cyclhed on topic CSR1000 Project Build
02 Aug 2014 14:40davido wrote: Good luck with your mags Cyclhed,I think they look a lot better than the spokes. My bike came with the mags when I got it. I wasnt sure if it was really a CSR or an LTD..
Spdygon, youre right about the 180 in the swingarm .I know the GS1100 was made for a 140 but I reckon I might be able to fit a 160 into it without too much hassle.
So the search is on for a rear wheel that'll take a 17x160 tire. Im looking for something that'll match with the 3 spoke front ('95 ZX9R) . So far Ive come up with the 650 Bandit, the FZR 600R(94/95) and the ZX6R(95/96).
If anybody has any other ideas,please let me know. Im stalled until I can get this sorted.
(Something that takes a 20mm axle would be good)
Thanks bro! I think you can get by with a bit of offset in the front and rear wheel centerline, but I personally would try to get it as close as possible. Assemble it without spacers at the swing arm and wheel. Have the shocks bolted up. Align the sprockets and then build your spacers. Set the fore and aft of the wheel a bit forward of centered in the axle hole.
davido wrote:
Heres how it stands at the moment. Original forks ,swingarm and wheels.
Anyone whos looked into a swingarm swap on this website will recognize the GS1100 Swingarm.
[attachment:2]DSC04444.JPG[/attachment
Though from what Ive read, Fitting in the frame is a simple matter of spacing with a couple of washers. Its going to take a bit more than a couple of washers to fill this. The CSR frame must be wider at the pivot bolt than the other
900/1000 frames. Be aware.
Also The GS1100 should be 1 1/2 to 2 inches (3.5 to 5.0cm) longer than the standard swingarm. Not so with the CSR. Im measuring original swingarm at 46cm (18.1 inch)
and the GS1100 swingarmat 47cm (18.5)
Which is good news as it'll mean I wont lose any height at the back end.Though I will still need to change the shocks as the mounts are different.
I had the same problem with spacing the swingarm on my 78 KZ1000 frame till z1wiz told me how he did it.
He gave me 2 of the thick flat washers that are used on the top of the KZ triple trees.
I slid one on each side and was done. They fit perfect.
Looks like you need the swingarm dust covers and thrust washers also?
The dust cover part number is. 61262-49201 (82-83 SUZ GS1100 swingarm)
I don't have the thrust washers part number though.
www.bikebandit.com/oem-parts/1983-suzuki...s/o/m21337#sch243209
Replied by Dizzle on topic 1980 KZ750 (ZRX Swingarm, GSXR Front End)
01 Aug 2014 18:34bluezbike wrote: Are you looking for a single Corbin seat? If so I have a mint one to sell (the one in my avatar)
That nice...I will pm you
Replied by bluezbike on topic 1980 KZ750 (ZRX Swingarm, GSXR Front End)
01 Aug 2014 18:07 - 01 Aug 2014 18:08
01 Aug 2014 15:59531blackbanshee wrote: donnon,
the tail and seat can be used.
but,
you are going to have to create some mounts and probably weld them on.
you may have an easier time just wrapping the area in saran wrap and fiberglassing yourself a pan up so it fits the tail in the rear and the tank in the front.
keep up the good work,
and keep us posted.
Thanks Leon... They is no way I'm using this seat......way too ugly. I'll order a Corbin and make it work. And the carrier will be on the way as soon as I can figure out how much I need to trim off..
Replied by 531blackbanshee on topic 1980 KZ750 (ZRX Swingarm, GSXR Front End)
01 Aug 2014 08:47
donnon,
but,
and keep us posted.
but,
and keep us posted.
31 Jul 2014 19:20
The Tail. My Bike came with an Squared Tail/Fender, which I don't like. I love the Duckbill fender (which you see now). It is just sitting on there and not mounted. Does anyone have a suggestions on how I go about doing this? Also, I want to get a corbin seat. Would it be difficult to mount a seat made for a KZ900 (Duckbill) to my bike?
De Oppresso Liber
De Oppresso Liber
31 Jul 2014 19:12Displaying 1781 - 1790 out of 7257 results.
