Search Results (Searched for: gs swing arm)
Replied by tk11b40 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
23 Nov 2014 03:06
# am 23 November 2014...IT IS DONE.
Replied by Tyler on topic Oh NO! What have I done! My new KZ1300
21 Nov 2014 22:35
Got the swing arm and final drive all back together. I picked up some Progressive air shocks form e-bay on the cheap. I replaced the seals in them and put the correct bushings in. Still need to polish them up a bit.
I still have to go through the breaks and replace the fork seals. But my list keeps getting shorter.
The replacement rubber boot...
Back together again
Attachment IMG_4929.jpg not found
Back together again
Attachment IMG_4927.jpg not found
18 Nov 2014 21:50
Stock weight is 564 pounds.
Current weight is 440 with half tank fuel.
Thank you for the compliment.
Replied by DSummerlin on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
16 Nov 2014 21:28
Man, your bike is beautiful. I'm wondering about how much weight you were able to drop from stock?
16 Nov 2014 21:20
Feel free to use any of this stuff on your bike. I can tell you I have been stumped many times, and after looking at all your bikes, often an idea comes to mind. I would consider it a compliment if you did the same.
Thank you for the compliments.
16 Nov 2014 21:14 - 16 Nov 2014 21:14Replied by 79MKII on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
16 Nov 2014 10:37
Yeah, definitely a great idea. I never thought of a spring in that location....looks great.
Replied by spdygon on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
16 Nov 2014 08:15
great idea..........hope you dont mind me using that same setup. as i as well did not thought about the spring location.
thx for posting
thx for posting
15 Nov 2014 21:22
The Bronze bushing was 3 dollars, and had a .375 I.D. which after come massaging on the linkage with a file on the drill press, fit right over the vertical aluminum shaft connected to the master.
I then found a faucet washer, drilled it out to .375" I.D. and slid it on the vertical shaft to center the spring. Added an aluminum washer to keep the spring on top of the bushing.
The spring fits neatly inside the master bore where the rubber boot fits.
Pretty neat, and cost about 7 dollars.
15 Nov 2014 21:13
Waiting for the headlight brackets, I decided to fix a detail that has been bothering me. The rear brake does not have a real good return spring as I made the rearset from scratch and did not think about a spring mount. I was looking at Graves Motorsport, they have something close, but it will not fit the CR 450 master. So I went to Lowes and cheffed up something on my own.
Displaying 1651 - 1660 out of 7258 results.
