Advanced Search
Search Results (Searched for: gs swing arm)
Replied by MAR on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
23 Sep 2015 11:12
MAR's Avatar MAR
I alreadty checked with them.
The drainplug they have is for the oil fliter and not the motor.
I am looking for the larger one with the magnet .
Replied by SWest on topic Z2 750 crank (Bossie the Kaw)
21 Sep 2015 14:40
SWest's Avatar SWest
I was going to move the shop. Talked to a guy with a wrecker. It was 12'X14' up on blocks so I could move it. Had I brought it close to the house, the Meth Heads wouldn't have gotten my cases and engine parts. They weren't worth much then, but now, CRAP. :angry:
The spare crank was wrapped in double black garbage bags and a spare swing arm they didn't see. Some small parts I need now and needed earlier. They all burned with the shop. :(
Replied by blakeem on topic 1982 KZ1000p project progress
21 Sep 2015 13:57
blakeem's Avatar blakeem
I think I have most of the electronics stuff figured out.
I'm not sure if I need this rectifier, it appears to only be connected to turn signals and the hazard switch but I have no idea why. Does switching it to AC to make them flash or something?
I started on the piece of aluminum sheet where most of the electronics will mount under the seat.
Drilled some holes and mounted it up. I test fit some of the required electronics to get an idea where I could to put it all.
The regular/rectifier on the right, the igniter in the middle, and the starter solenoid on the left. I think this is all I need to wire up besides the m-unit.
I think I want to put the starter solenoid in the battery box that will contain a small lithium ion antigravity battery. I want to mount this here under the swingarm where the side stand used to go. I don't want it attached to the swingarm due to unsprung weight and vibration.
As for the ugly plastic rear brake reservoir I'm thinking of just using a clear tube like on some motogp bikes so I won't need to add a bracket. I should be able to pick up a kit that fits the GSXR rearsets.
Replied by 577nitro on topic frame dimensions
21 Sep 2015 12:23
577nitro's Avatar 577nitro
davido wrote: Monkeydoodle,
You need to be more specific. There be a lot of dimensions on a frame . A lot of widths and a lot of 750/900,1000 frames. Even if you take just one of them,say the 750. You have many variations (I have no idea how many) all with differences , some slight some major. Depending on the year, some models may just have a cosmetic upgrade.some will have a major overhaul with a different engine .
If you have a KZ750e, (19??) you already have all those dimensions to hand. So which dimensions are you interested in and why. If you explain a bit, others ( with 900/1000s) will know what youre looking for and may be inclined to help out by going out to thier shed with a dingle and measuring bits of their bikes.
It would be nice if someone had a list of all the dimensions of all the years of all the models of all the KZs ever produced.But they dont.
Someone posted this on the Z1OC site recently, An interesting read and gives some idea of how big and complex the Z/ KZ stable is.
www.z-power.co.uk/merchantmanager/view_information.php?pId=22
I know from an earlier post that youre looking to swap your swingarm. Here are the measurements from my project;
KZ1000CSR(1981)
Inside from face to face of pivot sticky out bit on frame; 23.7mm
GSXR600(????)
Outside width of swingarm(including dust seals);23.3mm
If you need any other measurements,let me know what and ill have a look. Hope this helps.
Hi, I'm considering the same swing arm for my gpz1100 B1 project, I'm using 18" gsxr wheels, and need to know the length from the inside back to see if the 18 wheel and tire would fit. Can you measure that please?
Thanks
577nitro.
Swingarm bearing kits for KZ900/1000's was created by Rockranch
21 Sep 2015 01:11
Rockranch's Avatar Rockranch
I'm looking for opinions of people who have installed and used the replacement roller bearing kits (that replace the stock bushings) for KZ900/1000 swingarms. The set I'm looking at is from Z1 enterprises. This kit has 2 bearings per side (4 total). Any opinions of people who have installed and used these kits would be greatly appreciated............Mike
Replied by 650ed on topic I am a new member
20 Sep 2015 10:04
650ed's Avatar 650ed
Welcome aboard!
Here are some tips that you may find helpful:
Many newbies and not so newbies run into or issues with their bikes which could be easily avoided with a little preparation or information. Here are a couple recommendations that I hope you will find useful.
Before riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
MANUAL
You really should consider buying the Kawasaki Factory Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
TOOLS
WARNING! Do not even try to use Phillips screwdrivers on the Kawasaki cross head screws. Despite their appearance they are not Phillips screws. They are Japanese Industrial Standard (JIS) screws. The tips of Phillips screwdrivers are too long & pointed to allow the 4 blades of the screwdriver to properly engage the screws, so when you apply force the screw head slots will deform and look like crap. The fact is that Phillips screws were deliberately designed to have the screwdriver bit "cam out." This was done to prevent production line assembly from over-tightening, stripping, or breaking the screws. JIS screws do not have this problem. A proper fitting JIS bit can tighten a JIS screw to and beyond the torque spec without camming out. Here's the good news - you can easily modify standard Phillips screwdriver tips to fit the JIS screws.
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits.
PICTURE 1
[IMG
PICTURE 2
[IMG
PICTURE 3
[IMG
PICTURE 4
[IMG
PICTURE 5
[IMG
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
Good luck with your bike. Ed
Replied by SWest on topic Doing your own work
15 Sep 2015 18:16
They looked cheesy as hell. The Lesters were good looking. Yamaha came out with a look alike.
Love that swing arm mick. The Mags look good too.
Replied by Timfields45 on topic Just picked up my first KZ!
13 Sep 2015 12:36
Timfields45's Avatar Timfields45
650ed wrote: Here are some tips that you may find helpful. If nothing else please take a look at the TOOLS and MOTOR OIL sections.
MANUAL
TOOLS
PICTURE 1
[IMG
PICTURE 2
[IMG
PICTURE 3
[IMG
PICTURE 4
[IMG
PICTURE 5
[IMG
MOTOR OIL
Thanks Ed, that is a wealth of information!
Replied by 650ed on topic Just picked up my first KZ!
13 Sep 2015 10:52 - 13 Sep 2015 10:52
MANUAL
TOOLS
PICTURE 1
[IMG
PICTURE 2
[IMG
PICTURE 3
[IMG
PICTURE 4
[IMG
PICTURE 5
[IMG
MOTOR OIL
Replied by tk11b40 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
12 Sep 2015 18:24
tk11b40's Avatar tk11b40
I got so excited when I saw the photo that Myke put up. I care about the bike, it is clearly n good hands.
Thank you Myke !!
Drainplug:
www.z1enterprises.com/ItemDetails.aspx?i...KZ750&item=ZSM66-024
Displaying 1361 - 1370 out of 7257 results.
