Advanced Search
Search Results (Searched for: gs swing arm)
Replied by davido on topic 77 KZ1000 stock to modern fork swap
15 May 2016 09:14
davido's Avatar davido
kaw-a-holic wrote:
davido wrote: Not to distract from the handbag swinging going on but,getting back to the ground clearance thing
Kawasakikid wrote: GSXR Swingarm for me. Ground clearance is an issue if you pick up fat chicks in the trailer park. Seriously though, I am real close in tight turns but I run a firmer but not uncomfortable preload and dampening on front and back. I catch flack once in a while however Kzs aren't known for peg dragging anyway so slammed to the ground isn't an issue.
Kawsakikid, Im not so worried about peg dragging and Im not planning on picking up any fat chicks from trailer parks ,or anywhere else,( Im building a mono seat bike for now) what worries me is with the dive of the bike under heavy breaking and potholes and ramps.Things like that.Looking at your photo,your bike look pretty low.Have you had any problems there?
David,
My bike is in the weeds with the GSXR 750 front end. I am going to change it to a GSXR 1100 front end to gain another 1 1/2 inches. Now I have a reasonable drop on the custom triple my brother and I are designing. Should have the 3D model of it shortly.
In regards to your question, I currently only scrap on right handers if I dip to much. Speed bumps are a major issue.
Jon.My question was directed to kawaskikid.Theres a photo earlier on in this thread of him on his bike.It look pretty low to the ground (Like yours and mine) I was wondering what problems,if any,he was having with it (apart from scraping the pegs!). I know weve talked before about how to raise the front ends on our bikes and I know youve been looking at dropped triples but Im still undecided.Im still leaning more to the cheaper fork extension method,(though the whole thing has been shelved for now. Im still waiting on the powdercoater to give my wheels and swingarm back.Im busy with electrics in the meantime * ) I reckon,Ill just put it on the road as is and see how it goes.
I talked with my local bike shop about nose dive under heavy braking but he explained that as the front goes down,the arse comes up.Which makes sense. Though how thatll work in the real world ,Im still not sure. The speed bumps. Yeah,thats another concern.We have a lot of them around here,most Im familiar with,its the ones I dont know that worry me. (Theyre not well marked here and come at you out of nowhere!)
Anyway,kawaskikid. Your bike looks pretty low sitting to the ground and you look like a big fella,Have you still got any chrome (or steel !) on the underneath of your downpipes ??
* While Im waiting on the powdercoater,Im also getting the stuff together for an anodising setup.Another thing Ive not tried before. Looking forward to it and Ill post results in my build thread Hopefully some nice tasty black anodised aluminium parts will be added soon. Ha Ha!!
Replied by kaw-a-holic on topic 77 KZ1000 stock to modern fork swap
15 May 2016 07:31 - 15 May 2016 07:33
kaw-a-holic's Avatar kaw-a-holic
David,
15 May 2016 01:30
Replied by 650ed on topic 77 KZ1000 stock to modern fork swap
14 May 2016 16:04
650ed's Avatar 650ed
?????????? Now you tell me! I've dragged both footpegs, the centerstand tang, and even the right side muffler cover on my stock KZ650-C1 with S&W shocks set pretty stiff. Dragged them so much I replaced all but the center stand (which I could just paint)! Maybe you could try either buying stickier tires or stepping up the pace if you've never dragged the footpegs on a KZ. B) :laugh: :laugh: Ed
Replied by davido on topic ZX7/ ZXR750wheel into GPZ11 unitrack swingarm
14 May 2016 03:20
First wheel I tried was an old GSXR with a 180 tyre.Way too big. Then I got a ZRX400 wheel but it had very little meat on it.Not enough to safely shave down. I was more concerned about that than anything else.I wanted to be sure that I wasnt going to weaken the sprocket carrier.I ended up using a Bandit 600 wheel. I think I took about 10mm off the face of the carrier.Plenty of meat left on it to keep things safe and no problems with the bearing. Also had to shorten and rethread the bolts but that was no problem.Shiftting down the chain size was a big help, I dont think it would have worked with the old chain (630 or something,I cant remember).
1981 KZ1000 LTD Swingarm Swap was created by iwish4a69camaro
12 May 2016 17:13
iwish4a69camaro's Avatar iwish4a69camaro
Guys-
I'm working on my 1981 KZ LTD. my goal is to end up with an AMA style tribute bike to the early days of The KZ being the first Jap bike to win the AMA here in America.
Think Reg Pridmore
The goal is to use mostly period correct race style mods only. I'll retain factory brakes, factory forks, etc. while not stock but try to use period correct modifications, or modifications that appear as period correct.
It seems all those early AMA guys did different things for swing arms. It looks like the original Vetter bike ran some kind of aluminum swingarm. Eddie Lawson's bikes seem to run some kind of braced factory style swingarm that winds up looking like a ZRX arm.
So to the question. What kind of swap or modification would be semi-correct and be a fairly straight forward swap. I want to retain dual shocks and the factory cast 18" wheel. So I guess a 20mm axle. I've seen this done with GS1100E arms as well as ZRX arms.
I'm on a budget. I can source spacers or turned axles if I need them. Not afraid to weld steel or aluminum.
Any advice or suggestions would be super helpful.
Replied by knitt31 on topic '75 KZ400 Break it Loose!
11 May 2016 06:36 - 11 May 2016 06:53
knitt31's Avatar knitt31
Update and a question!
Working on my swingarm.
Looking for a little help understanding what's supposed to move in here. The shaft comes out easily. The SLEEVE seems to be stuck in the bushings, and definitely not turning. Judging by the grease fitting location, I'm guessing that the sleeve is supposed to turn inside of the bushings when the swingarm moves?
Do I need to use a press to remove the sleeves?
A couple photos of progress. Exhaust in and wrapped. (Wrapped because it was quite rusted/pitted. I knocked all the rust off, hit it with high temp paint to seal it, then wrapped it.
Bike is fully apart now, frame painted, and starting reassembly (Hence the swingarm question)
[IMG
[IMG
kz750e Resto-Mod was created by Daftrusty
10 May 2016 12:41
Daftrusty's Avatar Daftrusty
Welp...
I finally am getting around to organizing all my photos from when I started this build about two years ago, so I can document what all I screwed up and learned along the way so maybe others can learn from my mistakes. I have champagne dreams on a beer budget and literally none of the proper tools needed for customizing a motorcycle, so this entire venture is an exercise in doing as much as I can with as little as I can for as long as I can until I have pay a professional. This whole project is really like a self taught shop class for me. I am constantly having to research for weeks on how to accomplish the next step as much of this I have never done. So I may have really struggled with things that other folks could whip out in an afternoon in the garage. So bear with me!
I previously did a ground up restoration on a 1990 zr550 and in the in the process I ended up with literally enough spare parts to build a whole other bike. So after seeing lots of guys in Japan grafting on Zephyr400's (Zephyr zr550 in US) swing arms and front ends onto z750gp's and z750fx2's and 3's, I knew what I was going to do with all my spare Zephyr parts. I wanted a kz750e as they were easier to find than an dual shock gpz or a kz750L or kz700 ( plus I didn't want to irreparably alter a rare bike like those.) It took me a long time to find a bike that wasn't to nice to modify or to trashed to bother with.
Eventually I found a 1981 kz750e with 27K miles that was on it second owner. It had been garaged and taken care of all its life until the second owner, who spray bombed it all black, put pods on it and never figured out the jetting, so it was forgotten in the garage. The gas tank was covered in tinny dimples from a failed attempt at cleaning out the inside with large nuts and bolts, and the rear brakes were frozen solid. But it did start and it ran even though the petcock was fashmoganed and the carbs gushed gas as soon as the engine stopped. So this one was perfect for me to start with.
The day I brought it home.
I wasted no time in beginning to test fit the zr550 parts on the kz just to see how easy or hard this was all going to be. And was pleasantly surprised to find the swing arm fit between the frame bosses with millimeters to spare and the zr550 front end bolted up almost as if it was designed for it, even using the incorrect kz bearings.
So far so good!
Now that I knew that the Zephyr suspension bits were going to work, I made a list of things I wanted to accomplish. I had one and a half entire zr550 parts bikes I could use and the internet to find the rest.
I will skip forward to this past winter when I mocked up all the parts I had amassed to see how and if it would all work together. All the powder coating, suspension work and wiring had been completed at this point, but I never had the engine and the carbs and the gas tank in the same place at the same time, so I was hoping it all was going to fit. And thank God it did.
At the time of writing this, the motor is apart and I just finished painting all the engine pieces...so now it will all have to be sent off to the machine shop for the cylinder boring and valve job.
I ended up with:
1. kz750 frame and motor
2. zr550 front suspension, front and rear brakes, handlebars, headlight, swing arm and wheels
3. zr550 entire wiring harness including ECU, Ignition pickup, coils, fuse block, regulator....the entire thing.
4. zr550 speedo and tach and switchgear
5. zr750 (zephyr) cvk32 carbs and intake manifolds
6. zr750 ignition timing rotor
7. 810 piston kit
8. 1984 gpz750 cams
9. zr-7 sprag style starter clutch and secondary shaft
10. zr-7 high capacity oil pump
11. zr-7 oil sump with oil cooler ports
12. zr550 oil cooler and lines
13. 1984 gpz550 6-speed transmission
14. cheap ebay rear shocks until I can find something affordable and worth using.
15. Kerker exhaust
16. kz1000e (shaftdrive) gas tank
17. zx600d rearsets
I will now try to work my way through illustrating all the steps in between and document reassembling the engine when life stops getting in the way.
Replied by StreetfighterKz on topic My z1000 lives again...part 2.
08 May 2016 19:20 - 08 May 2016 19:25
StreetfighterKz's Avatar StreetfighterKz
Fast forward a bit to December. The storage unit where I was storing the Kz and Gsxr experienced a bit of flooding. The bikes were moved to higher ground but it wasn't high enough for the record flooding. After 4 days underwater, the flood receded and I found the bikes knocked over but with minimal amount of damage considering the situation.
During the time in storage I was slowly collecting pieces to update the Kz. I found a Zrx1100 swingarm and an installed but never used Z1 carved seat. I also bought a pair of RFY shocks that were rebuilt by CL MotoTech. I also picked up a set of Carrozzeria wheels but their fate is still undetermined.
After the recovering the Kz from the flood, I was able to get the bike running with a carb clean and a couple oil flushes. With the biggest hurdle conquered, I set about getting the swingarm to fit. I had to shave about 1/4" or so from the pivot and turn up some spacers to adapt the 20mm pivot of the arm to the Kz pivot bolt. Luckily, the arm missed the stock muffler brackets.
I ended up with a spare Brembo rear caliper so might as well put it to use. I pulled out some 5/8" 6061 plate and made a simple mount. I'll get some pics of the finished part later.
To be continued...
Later, Doug
Replied by Bowman on topic 76 KZ750 B1 Twin
07 May 2016 14:24
Bowman's Avatar Bowman
From what I can tell as far as these things can ever be called "done" I'm pretty darn close it seems. Just for shits and grins I thought I'd make a list of whats been done to the old girl. Likely forgot a few things but:
New Shinko tires
New spokes
Rims powder coated satin black
Dual front disk setup from KZ650/KZ1000
Brake calipers front and rear rebuilt
All new Spiegler s/s braided brake lines
New front master cylinder
All new brake pads
Front calipers powder coated satin black
Fork lowers powder coated satin black
Rebuilt forks
New All Balls wheel bearings front and rear
New All Balls steering head bearings
New swing arm bushings
New mini signal lights
New headlight chrome ring
New HID headlight
New Acewell electronic speedo/tach
New Motogadget RFID ignition switch
New Antigravity li-ion battery
New regulator/rectifier
Frame and frame fittings sand blasted and painted shiny black
Bodywork painted shiny black
Kawasaki green pinstripe applied on tailpiece
Side covers replaced
New clutch cable
New Gazi rear shocks
New chain
New plugs
Carbs rebuilt
New fuel petcock, fuel lines, filter
New K&N pod filters
New handlebars
New bar-end mirrors
Exhaust headers powder coated high temp satin black
New Supertrapp slip on exhaust
Valve clearance adjusted
Cam chain tension adjusted
New points and condenser
Timing adjusted
Carbs tuned and jetted
New full synthetic motor oil
New oil filter
So about $6-7K for new and used parts and things I can't do like painting and some other things. Plus about 100-150 hours of my time (likely more). All this for something that's loud, uncomfortable, dangerous and useless to me for 6-7 months a year. Oh, and any decent rider on a new Ninja 300 could probably humiliate me on the road or at the track.
I couldn't be happier B)
Displaying 1041 - 1050 out of 7257 results.
