Search Results (Searched for: gs swing arm)
Replied by Shdwdrgn on topic 1981 KZ1000 J-to-K build
03 Jun 2016 17:34
It's too bad I don't get much of a chance to work on the bike during the week. Ah well. Got home tonight and sorted out a pile of pieces to sandblast over the weekend. I have a couple of frame brackets that I can whip out pretty quick, then I'll start on the battery box. I got one of them pulled apart, all of the electronics are off, but there's so many odd angles to the pieces that it'll probably take some time to fully clean up. And there's a lot of surface rust on the bottom, so I'll get that cleaned as well as possible before hitting it with the rustoleum.
Once I get through the smaller pieces, I also have the aluminum panels that the foot pegs attach to. Quite a bit of grease on the backs sides to clean up, but otherwise the pieces should be easy to finish off. Will definitely have to put down a thick coat of clear on those. After that I can get back on the fenders and chain guard again (blasting through chrome takes a LONG time with my little gun).
I'm starting to get down to the extra parts now. I have a rear swingarm complete with the brake, rear wheel, plus extra rear fenders and a gas tank. And I'm going to have a lot of extra wiring pieces, plus most of a motor. Just gotta get mine all put back together first to make sure I don't short myself any bolts.
Replied by SWest on topic So this happened...
03 Jun 2016 06:32
I like my drum brake because it is unaffected by water. The disks have a tendency to lock up too easy. The linings must have separated. You can have tabs welded on your swing arm for the caliper arm or use the one for the brake stay already there.
Replied by Street Fighter LTD on topic Bike of the Month.
01 Jun 2016 05:28
Good morning all !!! :lol:
Man oh Man is this a beautiful creation !!!!
Here is the scoop on the upgrades.
If I miss anything Im sure Mike can chime in and also answer questions
Frame is braced and powedercoated. The 6 inch over swingarm is chromed and ws made in Germany.
Mike used a LTD wheel on the rear as a starting point , then had it widened to 6 inches and diamiter upped to 17 inches
The front wheel is a Z1R piece widened to 3 and a half inches. Both wheels were then chrome plated and do they ever pop !!!!
Tires are Avon, 180/55/17 rear and Avon 120/70/18 front both are radial tires
H D Sportster 11 1/2 in rear shocks are used and progressive springs are up front with a Tarozzi fork brace, and a steering dampener
Rear stopping power is with a custom rotor , with Brembo caliper and a PMC master cylinder.
Mike had the gauges rebuilt and added blue face plates. Also a headlight switch was added for Stealth mode.. :whistle:
Custom body work and 3 inch tail extension and paint by McCall Colors , plus the Mural on the tail section. Mike is a huge Led Zeppelin fan
and had the Hermit off a album cover added as a extra touch. NICE !!!!! Mike sits on a PMC MK II seat. I see custom handlebars and other details but we will need Mike to fill in the details :silly:
Now to the motor :evil: Start with a MTC 1261 cc kit fitted in new sleeves in a stock block, Used APE studs and nuts to hold the motor together. Weld the crank, Back cut the trans and add 33 smoothbores with K N pods to make power :woohoo:
Dual feed with Pingel fuel petcock, Port the head , add Stainless steel oversize valves, shim under buckets , Better valve springs ,
Web .425 cams and MORE :evil:
MSD ignition box and wires, Andrews coils Whew,,, I need a cigarette LOL
All wrapped up in chrome covers, not to mention the other pieces I spotted on the bike while drooling over the pictures.
MIKe You got my vote for a AWESOME BUILD !!!!!!!!!!!!!! WOW :laugh:
So ,, All you KZR Fans Please share your comments with us all on our JUNE BOTM
Thanks to Mike Hess for letting me share his Pro Mod with the world
Street Fighter LTD
Street Fighter LTD
Replied by Skullcrusher on topic 82 kz750 CSR (twin) carb shenanigans
30 May 2016 19:13
Yeah that's the 73 cb750 mentioned in my signature. Cycle x 849 10.5:1 piston kit, cx3 grind cam, fully rebuilt and ported head with bronze guides, oversize lightened valves, kibblewhite springs, racing cam chain tensioner, dyna ignition, open velocity stack induction, mac header with a straight through glass pack muffler of my own design, koso fully electronic multi function gauge, rebuilt and restoring forks with billet brace, all balls steering head bearings, new swing arm bushings, tec cb900 shocks, o-ring chain with -1/+4 sprockets, custom built seat, custom bobbed fiberglass rear fender, old Harley tombstone tail light..... she's my master work.
Fast bike but nothing compared to the 03 Suzuki bandit 1200 I built that's in front of the kz... that thing is wild, 130 HP and 93 lbs torque to the wheel.
Replied by 650ed on topic cleaning carbs without removal
30 May 2016 13:52
Here are some tips that you may find helpful. If nothing else be SURE to read the section on JIS screws under the TOOLS heading.
Many newbies and not so newbies run into the same problems or issues with their bikes which could be easily avoided with a little preparation. Here are a couple recommendations that I hope you will find useful.
Before riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
MANUAL
You really should consider buying the Kawasaki Factory Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
When you get the manual take a look at the torque specs. MANY of them are in INCH pounds, and some of the larger bolts are in FOOT pounds. You will need 2 torque wrenches; one small one calibrated in inch pounds and a larger one calibrated in foot pounds. Trying to use a foot pound calibrated wrench to tighten the inch pound fasteners won't work properly even if you do the conversion correctly because the foot pound wrench will not be sensitive / accurate enough at its lowest settings. No torque wrench is accurate at ranges below 20% of its max setting.
TOOLS
WARNING! Do not even try to use Phillips screwdrivers on the Kawasaki cross head screws. Despite their appearance they are not Phillips screws. They are Japanese Industrial Standard (JIS) screws. The tips of Phillips screwdrivers are too long & pointed to allow the 4 blades of the screwdriver to properly engage the screws, so when you apply force the screw head slots will deform and look like crap. The fact is that Phillips screws were deliberately designed to have the screwdriver bit "cam out." This was done to prevent production line assembly from over-tightening, stripping, or breaking the screws. JIS screws do not have this problem. A proper fitting JIS bit can tighten a JIS screw to and beyond the torque spec without camming out. Here's the good news - you can easily modify standard Phillips screwdriver tips to fit the JIS screws.
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my homemade modified bits with the authentic JIS bits.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Ronald Reagan was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
Good luck with your bike. Ed
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
MOTOR OIL
1981 KZ1000 J Front Fork Swap for 1990 ZX7 was created by gunnar
28 May 2016 23:17
I have a 1981 KZ1000J and I want to do a front end and swingarm swap. I am looking at a 1990 ZX7 because I'm broke and it's really cheap.
The question I have is, would it be silly to do this swap? I am assuming the ZX7 front forks and swingarm are more advanced, being nearly a decade older, but I don't actually know much. The tires are different, the brakes are better, and the electronics and controls are a cleaner looking.
Here is the information I have so far:
All Units In mm
KZ1000J 1981
Front Forks
Top Bearing Set
Inner Diameter: 25 Outer Diameter: 47 Width: 15
Bottom Bearing Set
Inner Diameter: 28 Outer Diameter: 52 Width: 16
ZX750 (Ninja) ZX7 1990
Bottom Bearing Set
So, as you can see, the forks are identical in the sizes above, so the swap should be very simple. The swingarm has the same axle size, so bushings will be the only thing I need to make that happen.
Here is information on the tires:
ZX7
Front tyre: 120/70-17
Rear tyre: 180/55-17
KZ1000J
Front tyre: 3.25-19 which converts to 100/90-19
Rear tyre: 4.25-18 which converts to 110/90-18
So, I will have much wider tires on the ZX7 forks and swingarm. It is also my opinion that the big 19 inch tire on the KZ1000J looks way too big.
I am new to the forums.
I am looking for knowledge on fork quality, and also, if anyone has any information on fork tube lengths, I would appreciate it; I can't find information on the fork lengths anywhere.
All Units In mm
KZ1000J 1981
Front Forks
Top Bearing Set
Bottom Bearing Set
Bottom Bearing Set
ZX7
KZ1000J
Replied by 650ed on topic Bought me a new project, here I am :)
28 May 2016 11:00 - 28 May 2016 11:02
Welcome aboard!
Here are some tips that you may find helpful:
Many newbies and not so newbies run into or issues with their bikes which could be easily avoided with a little preparation or information. Here are a couple recommendations that I hope you will find useful.
MANUAL
TOOLS
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
MOTOR OIL
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
MOTOR OIL
So normally it takes me 2 hours to change the swing arm bearing , chain and sprockets. Not this time...seems like previous owners did not now about greasing the arm bearings. After 7 hours it's done and I'm very happy
KZ1000 alive after years in limbo was created by nitrokeeb
25 May 2016 14:47
Purchased this bike 3 years ago. 1978 Kz1000 LTD with '76 KZ900 motor. The previous owner had been been working to cafe the bike. Larger KZ tank, clubmans, and flipped footpegs.
It had some good parts, like a (supposedly) rebuilt motor, 34mm CV carbs, K&N's, progressive shocks, and new chrome Kerker.
But the wiring was a mess, the fork sliders were rusty, the swingarm bearings were shot, and the brake master cylinder leaked.
I did most of the work a couple of years ago, but the project got pushed to the side when my daughter was born, plus I bought a Buell to tinker with and ride.
Finally got back on the Kaw this spring. Sprayed 2K clear on the tank and tail. It still needs wetsanding, but it's already made contact with gasoline and brake fluid without melting. I sold off the Kerker for a Delkcovic. After 3 years of sitting it was starting to develop rust, and I wanted stainless. It's not the same quality as the Kerker, but it should serve me well. New front master cylinder, and cleaned out the rear. New seat from Z1E, superbike bars, and stock foot controls changed the attitude from a ratty cafe to muscle cruiser.
Rode it for the first time last week, just out to get gas and a state inspection. Took it out for a 10 mile ride yesterday. Brakes are still mushy, will likely need more bleeding. Also she wants to stall on takeoff. I have to rev to 2-2.5k to get her going. I read so posts on hear saying that was a symptom of a stuck ignition advance. Tore it down today, and finding no apparent issue, decide to install the Dyna S I picked up from Brian, a member on the site. Turns out the rotor is wallowed out where engages the timing advance.
So after 3 years, and my first ride, she's down again! I screwed up the adjustment on the points, so I think I'll just wait for my new rotor to come in from Dyna.
Attachment IMG_0177.JPG not found
Attachment IMG_0179.JPG not found
Attachment IMG_0180.JPG not found
Attachment IMG_0860.JPG not found
Replied by Irish-Kawi on topic 85 GPz750 Refresh Project
24 May 2016 10:58
Still making some small steps here and there, nothing major but lots of cleaning and touch up work. Got my front MC painted to get rid of the faded and scrapped off paint. Not perfect but wasn't trying to make it that way, just get it covers and sealed until I can remove it and strip it completely and put it back together. Same with the stator case and the other case on the other side (forget what is being it) of the road rash and put some paint on it to seal and clean it up until I can pull them off and sand it out and feather it back in and then paint again. Touched up some chips and corrosion on the cases and a few other things here and there. Spent about 1.5 hrs scrubbing and cleaning her up this past weekend too and even took degreaser and brushes to the wheels and swing arm and underside of the bike. All together she really cleaned up nicely and is looking great. Will keep making small steps as I can over the next several weeks
Brett
Displaying 1011 - 1020 out of 7256 results.
